Originally posted by Matthew Jones
That video was to "Show Off", to attract viewers into the channel, must people are not knowledgeable of High Frequency-High Volts Low Amps...They compare with 120V AC 60 Hz, High Amperage(20-30A), and that they know it will shock you and(or) kill you, if you get your hands on water like I did .
So, let's get my previous video before coming here, behind, and then move forward. So it is clear I was not trying to use that video to impress you...or others here.
Now:
I am still interested in the current, and how much shows up at the load, also a scope shot would be nice. One of your previous videos has a scope present but I am not sure that was the waveform or not.
"how much shows up at the load...Shows what?...Voltage, Amperage, Frequency?
Ok the Scope showing waves...that is clear, however...Why don't you do something to help me here, here is the model number of DSO[DS1052E/ 2CH 50 MHz 1GSa/s] , go online check manual and tell me the exact set up you want on it...I think that's a better way.
Now as far as the shock goes, that look good. Normal current, and high frequency current will penetrate. Your muscles will want to twitch. A cold current will just run the surface so you'll feel it and its not comfortable but do not need to pull away. I'll leave that up to you to tell us how it felt.
However, if I turn on the Volume to almost blow bulb at very High Voltages...then I feel it more, but same sensation..in the video it actually did not shock me...but got me by surprise...it never did it before..but then I realized it does it in greater scale when both hands were in water at same time..
I am just guessing that I was being "bridged" by her, through both arms. But it was a bit higher than this one because I was lighting up at Higher frequency...and I have notice it increases when I turn in the neon blue lamps I installed for viewing meters better in videos, and also looked nicer...
Now there is something I just found out...when converting this videos and make me go back and stretch them in that particular frames...it is something weird.
After I turned off the light, right after there is a green pulse, just one(frame) so play back normal barely see it, but I kept stretching...and also by seq of 4-5 pictures...I noticed, and it is clear at slow motion...Before the green flash shows, I can see my cam capture a Spectrum of violet light, like a light cloud...around where coil and lamp are...but seems moving toward center, this is 1-2 frames,and as soon as is gone the green light strobe comes...this happens so synchronized, that have to go really slow...but in this video, if using a good editor, could be also done. I am uploading this also...but is longer...so takes time.
Any way, am glad You 'like' my Radiant Now'...
