    Hey Joit!!
    a waste of time, really..
    Yes, i know that allready, and we had a long Discussion about that in an other Thread.
    Allways fun when some Guys think her Simulator is the best and they can proove anything.
    When you build it, it allways turns out different, as her Sim did show it.
    My main purpose was anyway to make the Timer circuit more apart from the rest of the Circuit, that anyone can look simple on it, and got it easier to rebuild it.
    Not all here can simple see the single Parts from a Schematic, some have a harder time to understand how its all connected.
      Ok the main specifications on Wave is to be ASTABLE ...
      Btw Can you clarify more what that means, the Wave need to be astable,
      The Gate Trigger Signal or the Wave what the Transistor creates?
      Astable like what, like rising and falling from the Amplitude?
      • Astable 555
        I hope this may help - 555 Oscillator Tutorial (Astable Multivibrator)
        Vtech
        PS. This isn't directed to you Joit, but those who didn't work with 555 before
        General D.Eisenhower
        http://www.nvtronics.org
        • RADIANT ENERGY LIT NEON
          • What do you think about a double diode setup? I believe their may be something in that and I will tell you why.
            The analogy is hydraulics with two check valves, the two check valves can hold pressure between them in the circuit and often you need a check valve on the return line to hold the fluid in the system. In the electrical system it may hold a small potential, exactly what you need to polarize the radiant field, this may maintain radiant in the coil, without flow, ready for the next pulse. This way there will be no lag while we wait for the radiant to polarize and enter the wire. This can also be used in pneumatics giving a more responsive system, if radiant is gaseous in nature it makes sense, Just a thought I had
            • Originally posted by mbrownn View Post
              Hello Mbrownn,
              Very interesting approach and concept !..However, have to understand how this works...
              Since you've mentioned Hydraulics and mechanical concepts, I will use same them also to explain how this works...
              In a gas engine there is a Crankshaft that is sequenced to take in Piston Up while another one is down...synchronized in a fashion that they are 'stable'...a Push-Pull approach, where actually one Piston coming down (vacuum-exhaust stage), assist the other going up (Build Pressure-Explode) and is transmitted by the crankshaft in a harmonic way.
              This system is very similar...The pulsating signals are 'amplified' by the MOSFET's...into the Coil energizing it, let's say at "pressure time" , a current is produced in the Coil at T-On of MOSFET (Closed Drain-Gates), that produces a magnetic field in the Coil. Then when signal collapses vertically to zero, it generates a "Magnetic Vacuum" in the existing area where it was previously, creating an opposite magnetic field of greater intensity, that is the Radiant Field attraction, transformed through the coil and passed through the diodes into the system (my output after diodes). Therefore, diodes are valves or gates (just like you've said) to free that cold electricity through the output. if they were not there...cold electricity will crash with the "Hot" flow in every cycle, like we have been doing so far...those are the spikes, transients, parasitic currents, back emf etc,etc...
              Therefore you do have a great approach by trying to keep at least a bit of energy enough to keep polarized radiant field, but when Hot impulse enters into the coil, then it will wipe it out...taking over and canceling it. The advantages I see, is that the radiant field could be induced into a secondary coil, isolated from the "Pumping Effect Fields"...and greatly, this Radiant Induction is much faster than hot current, it reaches full levels when hot is still at mill volts, I have also tested that already...
              Radiant Energy Field had been entering all our equipments ever since the first coil was excited by a current...like "Ghosts in the machine"...but we keep fighting against her...flywheel diodes do exactly that...Snubbers, Chokes, etc...
              I had run brushed motors with cold electricity, they perform better than on Hot side, faster and freezing...and almost none to very light sparks on commutators...using minimal amounts of expense from our Hot side.
              Thanks for your comment!!
              • Hello Ufo,
                I would like to thank you on starting this thread, I think it is really good of you to be sharing what you have learned with people here, I do not have a great deal of experience in electrical circuits but have learned a little about electricity from the people you have mentioned and people in this forum.
                With respect to the driver circuit I am having alot of trouble trying to find a Tantalum capacitor rated at 0.01uf if yourself or anyone can show where to get some it would be a great help. The lowest available seems to be 0.1uf 35v
                The 1uf Tantalum capacitor I can find is rated at 35v is this ok?
                Thanks again Ufo for the time and effort to show us what you have learned.
                netica
                • THanks for a great Post Ufo Politics and Great Followups Guys .. i am optimistic to absorb this, though very new at it.
                  0P3N S0UR(E 3NG1N33R1NG
                  • Originally posted by Netica View Post
                    Hello Ufo,
                    netica
                    Hello Netica. I believe you can use tantalum 0.1uF. I don't remember seeing 10nF tantalum in my life . 35V rating for 1uF is just fine here.
                    Vtech
                      Hello Ufo,
                      netica
                      Hello Netica!
                      With great pleasure Netica, love to share with others...
                      Now, you could use a Ceramic one...it works as well, That cap between legs 7.6 & 2 is meant to be tried at different values...looking for better outcome results in pulses ...and 35 volts is fine also.
                      • Originally posted by Nasa Nate View Post
                        Hey Nasa Nate!!...I have seen you on FB...Is that you?
                        Is great to see you around!!...and yes you will make it!!
                        Cheers!!
                        • Thanks Ufo and Blackchisel, I'll get a 1uf 35v tantalum for C3 and see whats about in ceramic for the other 2 .01uf caps to start of with.
                            Cheers!!
                            Hello UFO
                            It might be me you are talking about on FB, I sent you a friend request the other day and you accepted, thanks BTW
                            I am watching all your videos and reading everything in this thread. So far I am following along alright, though I don't have enough components at this time to try and help with the replications. I am looking through my old TV and CRT monitor circuit boards for more n-channel mosfets, but I can't seem to find a matching set. I will keep hunting for parts, and when I have enough, I will build something if I can.
                            Thanks for sharing all this, and I hope it leads us somewhere great
                            N8
                            The absence of proof is not proof of absence
                            • How about simpler theory ? We are living in Earth magnetic field. On Sun there is an effect called magnetic reconnection which cause massive solar jets. Sure, magnetic reconnection is possible in Earth too. We just have to push field and collapse very very fast the pushing force field. Earth field lines returning back to the original place makes high frequency current. You see why it is only possible with fast rise/fall time.
                              Just my old theory.....
                              • Guitar is very nice analogy. Strings can produce sound only from impulse, you cannot do that holding strings in hand ,pushing and pulling rhytmically (that is analog of AC current).
                                Exactly like field lines.
