  • Hello Cacharreo, This is my Opinion...
    Originally posted by torpex View Post
    Hi all
    On this occasion did not touch the pot, was a rough shortcut.
    I'm still working with 12v,but I have decreased the frequency of the circuit (at 208 Hz) and I see the effect of purple neon light, also some white flashes (ball shaped).
    This is my circuit:
    L1.- 100 turns air-core 32 mm. OD
    Q1 y Q2.- IRF822DFI
    R4.- Adjusts the frequency. (less R increases freq.) Start at 30% of the pot
    R7. - Sets the pulse width. (less R decreases the duty cicle) Start at
    20% of the pot
    C1.- 22nF (Frequency range 90-400 Hz)
    C1.- 15nF (Frequency range 138-576 Hz)
    Only Q1.- Not see the purple glow
    I adapt the circuit to your specifications slowly . Thanks Ufopolitics for his explanations .
    Hello Cacharreo,
    I am glad that -at least- you saw the purple light!!
    However, I will tell you some issues in your circuit...
    1- Your 12 Volt power source is too low voltage to also drive the Drain-Source outputs.
    2-Your Coil is too short of Turns, you need to go at least 200 Turns, but with higher voltage...and better MOSFET's
    3-Your MOSFET'S are too slow (RdsOn 3.0 to 4.0 Ohms) it needs to be in the Milli ohms range, like 0.02Ohms !!...They have to be very fast switchers. Also, their Amperage at Pulsing rates are too low...(IDm=7.0 Amps), they should be at least 15 Amps.
    I uploaded the Data Sheet of your MOSFET'S below, just without the last three letters "DFI"...
    To my opinion you could see the purple light because that occurs at low frequency and low voltages of Hot pulsed voltages...but in order to go full blast and light up heavier loads you need to make your circuit more robust...
    At least a power source of 24V / 4.5 Amps, and reducing voltage with a Voltage regulator (like LM317) to supply 555 timer source to 13-14 Volts...but using the Full 24 V to drive MOSFET'S Source-Drain lines output.
    When you do that, then you have to add 220 or 330 Ohms resistors between MOSFET's Gate and 100 Ohms R1, that goes to leg 3 of 555. Also the Gate Biasing Resistor (R3) would have to be increased to -at least- 40-50K...(try simulator for best results...I used a 47K at 36V 6.6 Amps.
    Now for the Oscillating circuit you did a great job!!...and that is why you are getting Radiant at Neons...
    Now, when you step to higher voltage circuits, should not go too high on neons or will blow them into just an orange light, similar to typical, but brighter...but will never see on them again the purple-white plasma ball.
    Purple light is beautiful isn't it?
    • Hello Ufopolitics, thanks for your fast response.
      Cacharreo not have a good translation, maybe junkyard, maybe homemade gadget, something like.
      I appreciate your advices and I have in mind them. But I take the opportunity to investigate the material I have around.
      I armed 2 rails with 3 mosfets following your especifications (330 and 47k),
      mosfets are not good yet, only test, i know it.
      I also want to try a new coil and different turns, to compare my previous results.
      On the power I want to use 3 batteries of 12v and power the oscillator with the battery 1, żok?
      Yes, the purple light is beautiful.
      http://Cacharreo.com.es/foro
      • Originally posted by torpex View Post
        torpex,
        if you are running MOSFETs paralell, you need good driving current. Connect output from generator to TC4422 chip - http://www.farnell.com/datasheets/79492.pdf
        Connect one side of 33ohm resistor to MOSFET gate and second side to driver TC4422 pins 6,7. Do it for all of them. One TCxxx driving paralell MOSFETs. This solution gives you very steep pulse and enough energy for driving
        See datasheet of TC4422 and DO NOT exceed power supply and let me know how is going.
        regards,
        Cinan
        • Radiant effects via camera
          Matt,
          Now there is something I just found out...when converting this videos and make me go back and stretch them in that particular frames...it is something weird.
          After I turned off the light, right after there is a green pulse, just one(frame) so play back normal barely see it, but I kept stretching...and also by seq of 4-5 pictures...I noticed, and it is clear at slow motion...Before the green flash shows, I can see my cam capture a Spectrum of violet light, like a light cloud...around where coil and lamp are...but seems moving toward center, this is 1-2 frames,and as soon as is gone the green light strobe comes...this happens so synchronized, that have to go really slow...but in this video, if using a good editor, could be also done. I am uploading this also...but is longer...so takes time.
          Any way, am glad You 'like' my Radiant Now'...
          Hello Ufo,
          Welcome to the forum and thanks for sharing your insights.
          I have seen these anomolies and was wondering if you are documenting them in the three stages?
          IMO, from my data I collected the Radiant appears as we all know when the switch closes. However, this can be analized frame by frame and obtain a clearer understanding of this anomoly.
          1.) As the switch closes the Radiant is drawn in as segmented sections/pulses as seen in one of the pics I have.
          2.) There is a green flash that acts like a gaseous substance, or smoke like in appearance that has a scalar component. Also, there is a plasma discharge that is not linear and I have placed the capacitor in different positions to see if the effect was perpendicular to the magnetic field, it was random and thus could not be directed like a conventional EM wave.
          3.) As the Radiant gas dissapates the current flows and generates sparks that we expect to see at the close of the switch in EM theory, not after like when Radiant is present.
          The clip on YT you uploaded "Skin Effect Radiant Energy" you can see that with the naked eye the green flash when you short the Gator clip together (close switch) and when I paused the YT clip at this closure point the green anomoly is there for all to see.
          I'm only up to page 4 of this post as only starting reading this today and this has demanded my attention and so I hope you don't mind my late entry in this discussion.
          P.S - I will attach the pics I captured from your YT clips and I have some of these effects in the "Help with my first Bedini SSG" post.
          Zero
          • Ultraviolet-Green Effect/Slow Motion Video
            Originally posted by ZeropointEnergy View Post
            Hello Ufo,
            Zero
            Hello ZPE,
            Interesting comment and !!
            Yes, a few days after that comment I posted...I started to edit video at slow motion stages with Adobe Premiere, I made Three clips starting from Low to Lowest at end...And definitively there is an Ultraviolet Spectrum followed by the Green Strobe...right after I turn the Oscillator Potentiometer to lowest position...
            They are completely independent frames (Ultraviolet and Green Lights) and they only come up in a couple of frames, meaning, our normal sight will not be able to see them.
            After I found this, I started debunking other videos..(sounds weird, I am "debunking my own videos...
            This two effects, green strobes and Ultraviolet Cloud occurs only when I start "dialing" Up frequency to excite Radiant Field...or when I start decreasing to lower Freq. to shut off oscillator...
            At start it is amazing to observe how they pump in-out till light gets fully lit...
            Below is the video I edited, I have it as 'Unlisted' on my Channel...so you could not see it unless you have the link to it...
            RADIANT_ ENERGY_ULTRAVIOLET_SPECTRUM_GREEN_STROBE - YouTube
            Great to have You around ZPE!!
            • Hi folks, Hi ufo, Hi zeropoint, if you notice in this video i just made, you will see that same green light effect when i turn off the cfl, just thought you might like to know, since your mentioning it here.
              http://www.energeticforum.com/renewa...tml#post191665
              Super Joule Ringer 2.0 With Peanut Butter Base Mod - YouTube
              peace love light
              tyson
              • Slow Motion of same effects at starting pulses
                Hello SkyWatcher and ZPE ,
                Here is a video I just uploaded (also unlisted on YT) that shows same effects, but at start.
                Ultraviolet-Green Effect at Start of Oscillations - YouTube
                Now, there are also "Capturing Errors" here, that I have also noticed in other videos..like the Purple Neon, and that is Shutter Speed versus Real Timing ...it can not keep up with pulses from Light emitted pulses. So we get to see the CFL lighting half way up, however, can see the Off upper part of bulb...that is because our digital capturing system utilizes Interleave layer progression or overlapping layers/frames...so, we are watching the off part from previous layer...while shutter is sweeping/masking new lighted layer in ...
                However we can also see clearly the parts/frames where the bottom part of CFL and the wood is lighted up with purplish light-shadows, as we also see reflections and refractions of purple and green light on the walls of oscilloscope and other areas...so this lights are real, no capturing errors there.
                • Effects later in YT clip
                  Hello ZPE,
                  Hello UFO,
                  I'm glad you found my comments of the stages of the Radiant events interesting and I believe you confirmed 2 of the 3 stages in your YT clips.
                  I seen the anomoly clearer further along in your clip, except your hands are covering most of the light in the background. The second clip you posted is much clearer to see the green/ultraviolet effects at the swith closure in the CFL.
                  Zero
                  • CFL effects
                    peace love light
                    tyson
                    Hey Tyson,
                    That is good news that the Joule Ringer circuit can generate Radiant effects as the transistor fires the CFL. I have not made that circuit but from what I have read or seen it contains interesting properties.
                    Thanks for posting your findings in the circuit.
                    Zero
                    • A new thing to try capture on film
                      Hey Ufopolitics,
                      First let me congratulate you on capturing these anomolies and placing the effort to look frame by frame at the stages of the Radiant effects appearing in the CFL.
                      The DSO in the background was clearly ( to me ) showing the inductive spike generated from the collapsing magnetic field and the scalar wave present after the instantanious voltage in the coil. I will have to snap a few pics from the YT clip to see the frequency change at this point, or is this in the 2000Hz range that you uploaded pics of in the first post?
                      I noticed in the clip that some of the Radiant anomolies were present in the CFL when the DMM was reading 13Hz ( or less ) and not sure if this was due to the lag time in the shutter processing in the overlapping frames that you mentioned.
                      I do have one thing for you to try if you have not as of yet, move the digital camera back to capture a meter or more around the CFL. During the Green/Ultravoilet effects in the CFL there should be a unidirectional pulse that appears after the Radiant, there is also an effect that sometimes can be seen as Radiant sucks the energy from the outside environment.
                      I seen this clearly when I shorted a Radiantly charged cap after I turned off the light and then checked it frame by frame on the computer.
                      Have you pinpointed the frequency yet that this inductive spike obtains the Radiant effects?
                      Finally, I'm sure you have seen Eric Dollard's experiments in "Tesla's Longitudinal Electricity" when he obtains these effects on the outside of the light in series with the Tesla Coil ( you can see the green flash in the globe ) and is speaking about the Radiant form compared to the conventional EM energy.
                      Now to the point He places a capacitor's positive leg over the light and is able to extract power from the Radiant gas the appears on the outside of the globe. The negative leg is connected to a sink to provide the earth ground needed for his experiment.
                      You CLEARLY have this same effects in your CFL and could replicate Tesla's patent from the Dollard experiments shown.
                      Thanks for showing an interest in the anomolies present in your findings as everyone I talked to about these FACTS has not seen the significance of what is happening. I'm happy that many people are viewing your post and will have a chance to see this effect.
                      Maybe this can be used as a tool to measure the amount of Radiant energy extracted by the amount of gas present on film and then we can refine the principle to yield greater amounts?
                      A simple experiment that all one needs is a capacitor, camera and CFL to capture the Radiant as a plasma corona discharge on the outside of the bulb. Then scale up as needed.
                      I will have to spent the night reading this post so I up to speed on all the topic covered so I do not waste your time asking questions from earlier pages. I could not help myself when I seen in your clip that you achieved the same radiant effects that I have in capacitors.
                      Zero
                      • Paramagnetic material
                        Originally posted by Neight View Post
                        Have you thought of using a para-magnetic material as a core?
                        A while back Min2oly used a coil with a para-magnetic core, and got good coil saturation, and it had less drag on the rotor.
                        I couldn't find the video on his channel anymore, so he might have removed it, but his results interested me. I can't remember what he used for the core, but I tried molybdenum, and couldn't get it to glue together well enough to fill a core with it.
                        Either way, it might just fit the bill for what you are looking for, and figured it was worth throwing out there
                        N8
                        Hey N8,
                        Has been a few months since we on the same post, how is the 3 battery generating system working out? I commented on your YT clip mate.
                        Paramagnetic material will not retain any residual magnetic flux induced by the ferromagnetic materials. Also, the black sand that Muller utilized in his motor had the the same paramagnetic properties to obtain the faster RPM due to no drag from the magnetic field in the shorted generator coil.
                        I can grab the link from BM2 if you like for the Paramagnetic material if the supplier has any still?
                        Zero
                          N8,
                          My name is Bob French and I introduced the paramagnetic material to the Monopole2 group last year. A friend of mine had me test it for paramagnetism and it turned out to be the most paramagnetic material that he had ever found. It has worked for me as a core just great. Min2oly has been using it successfully also, as have others. I call it ParaCore and my friend, Jerome Chambless sells it. E-mail him at "jeromechambless@ymail.com" to purchase some. I don't think he has much left and has had trouble making contact with his supper due to their winter work schedule back when he was trying.
                          Paramagnetic means that it is not magnetic, but becomes magnetic and polarized when in the presence of a magnetic field. So it is perfect for a core material in many instants. On a rotored machine there is next to no kogging (drag) at low speeds (at any speed for that matter) and retains no magnetism during switching operations. Min2oly shared that his rotor speeds about doubled with it. I ran my 6PM (100% stock parts) at over 10,000 rpm on 12v using this as the core. And the spike of the "h" wave was straight up and straight down.
                          I think that it might be of great use with this technology. As I understand it, the reason an air coil works is because the air has some O2 which is paramagnetic. Oxygen in the air is not dense, so I think something like the Paracore, that is very dense (sort of like rock dust), might be much better than an air core. (?) We'll have to see.
                          This is my first post. I just finished reading the whole thread (over three days) and I'm totally impressed and anxious to start building. Many parts are ordered. If anyone would care to suggest exactly what to build (particular timer setup, particular voltage regulator setup, and particular "mine" circuit setup) I would appreciate the input. I already have numerous coils that may work. I will have to determine the N-S of them. They are all wound the same direction (if looking down from the top, the wire wraps around in a CCW manner; is looking from the side, it starts on the left and continues across the front to the right and then around the back). Can someone tell me if the inside wire (beginning) is + or -? N or S?
                          Lastly, I'd like to say how happy I am that UFO has graced us with this knowledge and has been so kind as to disclose all details and encourage others to do the same. UFO, thank you! thank you! thank you!!! I am looking forward to your next video and the info forthcoming.
                          Thanks all,
                          Bob
                          • Originally posted by cinan View Post
                            Dear all,
                            yesterday after whole day of hard work, firmware and software for PICgen was made. Its v1.0 and i am expecting some issues there, but we need to start with something. I will release it soon. If anybody is interested, jst let me know.
                            Cinan
                            Hi, Cinan, I am back home again after a long trip. And feel very happy to hear you have finished the firmware and software of the PICgen already! I am interested to have them for my replication of your circuitry and for driving the UFOpolitics coil.
                            I have to buy photo sensitive PCB to copy the circuit board yet, not done due to the long trip away from home. Sorry.
                            aaron5120
                            • Getting started
                              Hello Cinan,
                              Ok, here are the spec's of the latest Coil on my last video, that outputs power to five 120V/23 Watts CFL's, to my believe it is a good Coil for you to start winding...
                              Outer Diameter of Core =2.0 Inches
                              Height of coil= 2.0 Inches
                              200 Turns 18 awg wire (double strands), connected in parallel start with start, end with end.
                              After finishing winding the outer wire diameter gets very close to three inches.
                              The way I wound it:
                              1-I make my own spool ends or caps with fiberglass sheets, in a fiberglass tube that I also mold/make...now, this one was made over acrylic clear tubing just for video purposes...but I like fiberglass better since it can stand better the heat. (I use Polyester Resin with Methyl Ethyl Kethol (MEK) Hardener. The end caps prevents from wire to slip out of control and could result in a loose winding that will make too much noise and vibrations...
                              2-I start on top turning Clockwise and tight going down, at bottom start coming up, and so on...200 turns.
                              3-Now the Orientation, I really do not want to confuse you, but my start wire is my positive...and end is negative...still North is on Top, next to Positive (You've said is not possible, I will re-check this coil again..to make sure, maybe my compass is "shifted"...lol)...but like I told you before, this concepts of magnetic poles are relative for the purpose you are going to be testing, magnetic polarity does not matter, and you could test it with a compass or a defined polarity magnet.
                              4- Just define the positive above, at the starting wire, so install diodes according to that set-up.
                              I will prepare a set of pics and maybe a short video to show you my coil polarity and magnetic poles. However, on my latest video Coil, could be seen pretty well.
                              Ok, any more you need let me know
                              Sorry for the delay to respond.
                              P.D: I will keep posting here, I meant, I will also go on other sites Forums...
                              Definitively you will see video 3 here soon, I am kind of swamped with work...but eventually will make it pretty soon...and yes there are a lot of ideas I have in order to set controller for the secondaries to run-perform better.
                              So, I will be here
                              Hey Ufopolitics,
                              I'm up to speed with all the posts now and ready to start replicating your build.
                              I have most of the parts on hand but will have to order the MOSFETS and the NTExxx fast switching diodes, but will use the 1000v @ 200mA 1N914/1N4148 series that I have already if the FET's arrive first.
                              PVC tube I have for other projects is 57mm OD and will match your 200T of #18 copper wire or the 1.4 Ohm coil perameters, height will be 50.8mm. Sound ok?
                              I enjoyed the second YT clip with the anti-gravity effects in the bloch wall of the coil where the Radiant is greatest. I now see there is more to the relationship in the polarity of the magnetic field ( Radiant or EM ) in proportion to the magnetic particles in a constant state of flux.
                              The Faraday motor is a simple example that most of us have seen or made. However, your experiment achieved the same result off the coupling with the Radiant EM field and the speed of the rotation is determined by the position in the coil in relation to the bloch wall.
                              Zero
                              • 1n914/1n4148
                                Hey Ufopolitics,
                                Zero
                                Hello ZPE!
                                HOLD ON!!
                                This Diodes will blow as soon as you turn that dial!...they are low power signal diodes...they are good if, set after the UF505/NTE576 in series...Voltage does not matter, high repetitive current will increase/replace Higher Amperage...they are great as filtering once the ultra fast rectifiers are on line.
                                If you have the 1N4003-4004 up to 4007 they will work fine...not as fast as 576...but safe.
                                Yes, the speed of motor depends also on pulsations...I am making a more robust model where the rotor is made of aluminum cylinder and two magnets...stator is the main coil...split in two parts, there is a way to "trick" Radiant Field to flow/manifest right at center between two coils...However this is not the best of best of examples..
                                I am very glad you have almost everything ready to go!!
                                Anxious to hear how you've achieve it.
