  • Bob I am very glad!!
    Originally posted by bobfrench@fastmail.fm View Post
    UFO et al,
    WOW! That's what I'm talking about!
    I ran my new build last night and FRIED a neon, super lit a 65w CFL, and did a little bit of battery charging. I will provide pics if I can negotiate Photobucket. I'm not the best computer guy. I have drawn the circuit from a compilation of pages 4, 12, & 13 and Dana is going to computerize it. It will be posted soon. The circuitry, except for the pots and MOSFETs, are on a 2" by 2" PCB. Everything, except the coil, is mounted on a 4" by 6" wood board.
    First, I started with the most resistance on the frequency pot and mid-range on the duty cycle. I never changed the duty cycle which measured around 8%. I never got my frequency up much past 133Hz, which is where it started. The CFL was so bright from the very beginning that I was afraid to turn things up much.
    UFO said that my coil was "a monster" (a good thing) and he was spot on! I think the 1.5" ParaCore works!
    Second, my MOSFETs started heating up so I shut things down after about 5 minutes each time. They got into the high 90's, even to 100 degrees. So is this a function the duty what cycle, or low frequency, or what?
    Thirdly, I guess that I need something bigger to run than a CFL, like a motor. I would like to turn up the frequency and see what this baby can do. Maybe if I get the CF coil together, I will have to look for a small city to light up.
    UFO, you have made this wonderful device possible and I want to thank you for everything you've done and endured to make this come to life. I'm having a blast!
    Thank you,
    Bob
    Hello Bob,
    I am very glad that the set up worked out for you and for all others who have tried!!
    WELCOME TO A NEW WORLD
    Now get ready, because this is...
    JUST THE BEGINNING
    I am sorry if I have not been able to get back to you before. I am working now on the Motor-Generator applications of this same Technology, and will be posting it very soon.
    I have developed a whole New Type of running machines, machines that "do not make any sense at all" to the typical existing ones...
    Motors and Generators.
    It is quite lots of Material to be disbursed out, many different options, many different set-ups, tons of diagrams...
    The only question I have...
    Should We Open a completely New thread for Motors and Generators?
    What is your opinion?
    My Love and regards to all!!
    ...You guys made me feel great!!, Ever since I have decided to start disclosing out all of this information, without the smallest bit of greed nor ambitions...This has been my best of times so far!!
    Thank You Bob, Thank You Dana, Thank You Torpex (I am sorry I have not answered back your message, pero te queria dar una sorpresa...[in Spanish]) , thank You Cinan (great electronics man!!), Thank You ZeropointEnergy (from first time you always believed me, and I really appreciate that), Thank You ALL!!
    My Love and very warm Regards!!
    Now fasten your seat-belts for what's coming next!
    • Hello Torpex!
      Originally posted by torpex View Post
      Hi all
      I have updated to the 31GF6 diodes.
      New coil (other circuit) 100 turns bifilar, one layer, OD:32mm, parallel connection.
      To adjust frequency, i have changed C1 to 10nF and short R6.
      Power source: 36v
      Control circuit: 13.95v
      I have added a capacitor of 68mF-385v in parallel to the load.
      Drain current: 390mA for 100% Brilliance eco bulb 11W 240v
      Drain current: 390mA for 100% Brilliance eco bulb 15W 240v
      Drain current: 390mA for 100% Brilliance eco bulb 30w 240v. I suspect the factory label should be bad.
      At this point I am a bit lost. I need to compare my results.
      @Ufo, I sent a private message to you, Have you received it?
      I keep on working in the new coil.
      Hola Torpex,
      Como estas amigo?
      The Factory Label is perfect Torpex...You just made an Over Unity device!
      I have Lit 120Watts CFL (replacing 800Watts Hot) with 36V System in my first video Radiant Energy....and submerged in water...while On.
      Welcome to a New World Amigo!!
      Warm Regards Love and Light !!
      Namaste!
      • Heat Sinks and Cooling Fans for MOSFET's...
        UFO et al,
        Thank you,
        Bob
        Hello Bob,
        MOSFET's will get Hot normally...make sure You have pretty heavy heat-sinks on all of them, I incorporated a small fan right at center of circuit to blow Voltage Regulator and MOSFET's Bus Bars...it keeps everything at normal temperature.
        To protect your MOSFET's you could add a diode of lesser value than Intrinsic Diode on MOSFET right next to each one...Source To Drain connected.
        A Brushed typical short-circuit DC Motor will Run very smooth and no sparks at all on Commutators, but mainly READ TEMPERATURE on Motor while ON at full blast, please!!...You will be amazed...
        You may feel a small delay in the acceleration of motor at start...keep going it will "balance out"...
        While you are turning Frequency On, leave it steady at bright bulb (not too bright or full blast) then try playing with duty cycle in order to reduce Hot Time On (T1)...Increasing Time Off...then turn Frequency higher.
        All my pleasure my friend!!
        Warm Regards
        • Ufo, you are welcomed. It seems like now you are getting excited It was good idea to open this thread and share facts &findings. Everybody has its own limitations and if we put heads and efforts together, we should squeeze good stuff out
          regarding new thread, I thing its relevant to open it. As this thread is discussing basic technology and coil itself. We can develop it further, amplify, finish whole design to be useful, etc.
          Motors are rotating machines and I wouldn't mix it here. But its only my opinion. And both forums can be interconnected anyway.
          cheers,
          Cinan
          • To All Successful Tests
            To Bob French, Dana and Torpex,
            So far you guys had hit the right spot on Magnetic Resonance or Feedback of your circuits, now, I know you are all excited, and that sometimes do not let you do things right...
            Please do not change that set up!!, leave it like it is without taking a single turn of wire off your coils!!, make another coil to experiment with it...but leave that one alone
            Take measurements and annotate all parameters as possible!!
            Measure-calculate your coils spec's, impedance, resistance and capacitance.
            Measure your exact output levels before the oscillator goes on peak levels.
            There is a very low point of Frequency where you start getting a very fast strobe of Blue-purplish Light, on CFL's, mixed with some green that bothers your eyes... measure that Frequency...I know if you keep "dialing up" it will get brighter and steady, however, that point of first heavy flashing is very important, because that is your exact frequency(ies) where Radiant Field starts coming On, it could be a range of Frequencies...But this will bring us a steady parameter to -in a future- just turn it to that very point and then keep dialing.
            Electronic Oscillation Circuitry should be focused on that particular point...to Increase it without the need to increase Hot Input. I believe in a near future we will be able to increase Radiant Feedback while leaving Hot pulses at that steady low rate, maybe at very short Times On Peaks, but, of Higher Voltages from Hot.
            So we need to compare this values together to come up to where Magnetic Resonance-Feedback comes In.
            Great Work Guys!! Congratulations!!
            Let's keep Rolling!!
            • I agree with You Cinan
              cheers,
              Cinan
              Hello Cinan,
              Yes, of course I am excited!...
              I do agree that "Rotating Machines" (I like that term... ) should be in another Thread...and to those entering in it for first time should come here first and read this thread to understand second one.
              However, let's see what other members say about it...
              Ever Heard of Asymmetrical Motor-Generator's Stators and Rotors NOT BLDC or Three-Six Phase?
              No, right?...Well you will soon.
              Related to the third video: I am still working on it..will release soon, it is about Isolated Secondaries set-up in both planes of Radiant Field: Horizontal and Vertical.
              • Pics of new UFO Device
                To all,
                Here's the link to Photobucket for "Bobfrench's Album":
                Pictures by bobfrench - Photobucket
                There are pics of lighting a 65w CFL, the circuit (hand drawn), and the device.
                Sorry I don't know how to post it so that you can just link to it by clicking on it. Someone needs to tell me how to do that.
                Enjoy,
                Bob
                • Link worked anyway.
                  The link worked any way...cool.
                  Bob
                  • Congrats to all
                    And especially UFO.
                    Thanks for all hard work and great info.
                    I hope I will join soon with a succesfull replication.
                    ps. Backup your Pc files, just in case..
                    Bert
                    • Beautiful Work Bob!!
                      To all,
                      Enjoy,
                      Bob
                      Great Job Bob!!
                      Pictures look awesome man!!
                      Like I said...and now looking at it...That COIL IS A MONSTER!!...
                      I imagine the great and strong magnetic field you are generating there!
                      A Quadfilar of 19 awg is an awesome Coil set-up!!
                      However Bob, for the kind of withdraw that Coil is demanding, Your Transistors will get stressed out, that's why they get so hot.
                      You could parallel more, with same arrangement, (I had up to six mosfet's in parallel) just adding more branches of 330 Ohms and 47 K's to gates...then they will disburse their super-fast switching more "relaxed". They could also use a bigger Heat Sink.
                      Now for easier uploading of your pictures files, keep scrolling down on post writing screen, and after "submit replay/preview post" you will see a button "Manage Attachments", press that one and another window will open...select to "Browse" from your PC Files and then press Upload right at selected file pictures.
                      Then go back to reply window and your picture file name should appear on it...right below "manage attachments". then post or preview the reply post.
                      Let me know if it worked out...
                      Great job Bob, and thanks for coming back to share it with all of Us!!
                      You are a great man Bob!
                      • Success with a Neon
                        Hello Bob,
                        JUST THE BEGINNING
                        Hey Ufo,
                        Thankyou for your kind words. I made Cinan's circuit first but did not have any luck, not sure what I done wrong so built a astable 555 timer circuit that started at 30Hz. (other circuit was in the MHz range )
                        I just used a NPN transitor to obtain a result and now I will remove the 2 x IRF740 MOSFET's from the Cinan's circuit and solder this together.
                        I was so inspired to make this a few days ago that I spent from 12-4am making Cinan's circuit and was getting down on myself that I failed.
                        The sqaure wave has a discharge curve in the middle of "time high" and will have to trouble shoot that circuit another time.
                        I'm glad you put pressure on me to replicate your results and here is the start of the progression. Circuit set to 30Hz and the neon began to glow with more brillance than I had ever seen when leaving the secondary battery terminal unhooked to show off Radiant to mates on my Bedini rotored or SS SSG's.
                        and thus had to stop the test instantly and record my results to post up pics here to prove my results
                        Data:
                        Input voltage = 12V
                        Current draw = 300mA (this was at 90% duty cycle)
                        Input frequency = 30Hz (at 220Hz the current draw was 800mA)
                        I'm going to email Dana and Bob to chat and replicate their circuit they have been working on, LM317 and a few other parts arrived today so I can test out that section. The NTExxx parts are coming from the US and I thought would only take 3-4 days to reach me in Australia, has been that now so I'm growing impatient
                        Hope you enjoy my pics, I will add 2 that clearly show it (camera did not pic up all anomolies) and I'm looking forward to more
                        Zero
                        • Coil dimensions
                          Great Job Bob!!
                          Hey Ufo,
                          My coil is 4 x 150ft of AWG#23 (0.56mm) plus 150ft of 0.4mm (not used) and each strand measures 3.8 Ohms. I only used one for my test but I'm about to add 3 in parallel to obtain 1.6 Ohms and re-test/record.
                          Coil is litz to keep the capacitance/inductance as linear as I could using a drill making the coil.
                          I had that coil made up for other tests, new coil is going to be 200T of AWG#18 (1mm) on a 50.4x50.4mm Acrylic coil (will have made up) and 57x75mm PVC tube to test the Radiant properties.
                          Or have you done these tests?
                          P.S - Will have to use Photobucket soon as running low on upload space .
                          Zero
                          • Great work Bob
                            To all,
                            Enjoy,
                            Bob
                            Hey Bob,
                            Great job mate, nice, neat set up and thanks for posting your combined circuit. I have to scale my results up past the neon with MOSFET's in parallel all I obtained from the 240V/10W CFL was buzzing
                            Zero
                            • Hello ZPE
                              Originally posted by ZeropointEnergy View Post
                              Hey Ufo,
                              Zero
                              Hello ZPE!
                              Nice pictures!!...Yes I can see the Neon Purple light...that's great!!
                              Is a good idea to talk to Bob and Dana about building your circuit, even though the schematics look pretty clear...it looks like the LM 339 (Dual LM393'S) is much better than the 555 timer...We have to thank Kapen and specially Mad Scientist for bringing it in here..
                              Well, yes I have wound Coils on Acrylic and also on PVC...However the best core-spool material to me is Fiberglass so far...I would have loved to use Carbon Fiber...but it kills Radiant in a closed CF cylinder...do not work at all...
                              Now according to Bob French results (He kept frequency at the lows 130's Hz)...
                              we all could make up that the more strands of wire in the "Multifilar" Coil...the lower frequencies required to run Radiant at full range-blast.
                              I have to go on my Bifilar Coil up to 800 Hz to get Radiant at high peaks.
                              We have to realize it is MOSTLY about the Magnetic Field strength and not much about the electrical parameters (like resistance, voltage , etc...what we are all looking to "Enhance" here...
                              Making Multifilar in Parallel generates very heavy Magnetic field from Hot at very "Low Cost Values"(low frequencies, therefore less spent energy on our side)... generating a great Radiant Field resonance-Output.
                              And this is the idea.."To get more for less"...
                              However, there must be compensation at the MOSFET's level, when we have very low resistance values, because of Higher number of strands in the Parallel Multifilar Coil...in order to run a "Stable and Relaxed" system.
                              Good work ZPE, and be patient you will get parts soon!!
                              • Clip of the plasma/Radiant effects in the neon
                                Hello ZPE!
                                Hey UFO,
                                I could not help myself and made a video with a fresh neon bulb.
                                Have you found that after a few mins the neon stops generating the white/purple Radiant flashes and only has the plasma across the 2 legs?
                                Circuit is set to 44Hz at 89% duty cycle TL. I was only running the tests for 2-3 mins to let to NPN transistor cool down. I'm sure I will solder a full astable timer circuit, including the LM317 in the next few days untill the op amp (LM339 is from the UK) and the US parts arrive .
                                Enjoy my friend and looking forward to your comments
                                Plasma Effects in a Neon Bulb due to Radiant Anomolies at 44Hz - 15th May 2012.AVI - YouTube
                                Zero
