  • @Cornboy
    If all the above does not help, take out the 5v ic and power up. Measure the copper leads where ic was and if there is 12v at more than one post, something is wrong with the board.
    Dana
    Nikola Tesla
    • Thanks DANA, the caps are ceramic RS # 5373909, will remove 7805 and check.
      Cornboy.
      • Cornboy
        I do not see the jumper placed in which is just above the MIC4452YN label. That is part of the 5v circuit. Maybe that would help.
        Nikola Tesla
        • Hi Cornboy,
          sorry for answering late. I as not available last days.
          I guess the center pin at 7805 reads 11.5V as well .
          What you see is typical for a voltage regulator with GND leg not being connected. This leg gives the reference for 5V. If it is open all voltages float up like air bubbles in water. Their ceiling is some mV below input voltage.
          Check-1: Yes, jumper is essential - I checked layout today. Sorry I didn't mention it. Jumpers are not part of the schematic because they can be inserted deliberately if required when doing the PCB layout.
          If still having problems:
          Check-2:
          - Connect your meter GND lead to GND at power-in connector.
          - Measure at center leg of 7805 at solder side and directly at leg on component side. If you have any difference the leg is not soldered correctly.
          • Have you ever heard about the RF jammer kit? And do you know in what aspects it can be used for and where can be the best place to own one high quality and multi-functional RF jammer? If so it is really necessary for you to come, stop your step here and know more about RF Jammer, and seize the chance of getting this high quality product from here.
            • looking on Amazon at different Arduino boards and am a bit lost. Which one should I get?
              • Hello Zardox
                All will work but the Leonardo is what most are using and I have seen some on Ebay this week around ten dollars. If you are going to get into sensors also, get two.
                Dana
                Nikola Tesla
                • Got 5v
                  Hello all, Deeerrr, it was the jumper, i removed the reg and caps, and tested for shorts everywhere.
                  Good practise, never used a sucker before!
                  @ John Stone, ready for next step, please don't feel bad about not being here, all the time, we all have human things to tend to.
                  @ DANA, thanks for your help on this, as you have experienced first hand, i am not very knowledgable on electronics, i am a learner.
                  We really do have a great team here.
                  Thanks, Cornboy.
                  • CornBoy How do you keep the Corn Borers out of your corn ? Do you use IMIDACLOPRID ?
                    Or some other toxic chemical ? Or are you not in a Borer area ? Do you plant at times in
                    the season to avoid them ? Or use BT Corn ?
                    I'm interested to hear how you deal with them in larger crops without using
                    Chemical Pesticides.
                    • Demeter.
                      Hello Farmhand,we probably shouldn't take up space here, because this is dedicated to control electronics, but to answer your question.
                      I am certified Bio-Dynamic farmer, the thought of even using Round-up is foreign thinking to me, i have found that all things start with the soil, look after it and the rest falls into place.
                      The corn i grow is for stock feed for my free range chickens for eggs, and a little damage is completely acceptable, in fact i have more damage from hungry critters, like crows and rodents, than from anything.
                      The overriding theme of a Biologically - Dynamic farm is one that is self contained as possible, i have managed to close the loop on my farm except for packaging and of course energy, but i'm working on that as you know.
                      My soil is at such a level now that i have double cropped my growing areas, 5 yrs without any fertiliser inputs, except the anual Bio-Dynamic Preparations, which cost $1.20/ acre.
                      The garlic, in the pics that i have posted on threads, was planted into completely unfertilised soil.
                      Of course the local feed companies and chemical resellers, are not too friendly with me, but i can live with that.
                      If you wish to know more on Bio-Dynamic farming, go to Demeter.org.au
                      Warm Regards Cornboy.
                      • Monster Jumpers.
                        Hello all, as you know my problem with the monster board was a jumper to GND, there seems to be two more jumpers to do with feeding the opto, is that correct?.
                        Have enclosed pics, hope they are clear enough.
                        Thanks Cornboy.
                        • Jumpers
                          Cornboy
                          Yes, I do see two more jumpers there also. Not sure why they were put there as there is room for regular copper but they are there now so put them in.
                          Dana
                          Nikola Tesla
                          • John Stone data acquisition unit ~ next step
                            The next step in our data acquisition system is centered around the Adafruit 4 channel ADC board, https://www.adafruit.com/products/1085 a fully expanded system could support 4 of these boards for a total of 16 channels, more details can be gleamed by reading this pdf file http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad =rja&ved=0CCkQFjAA&url=http%3A%2F%2Flearn.adafruit .com%2Fdownloads%2Fpdf%2Fadafruit-4-channel-adc-breakouts.pdf&ei=mq8WUqCPG8Hv2QW-1oC4Aw&usg=AFQjCNEFYkeNocBwsgb6eNmd5NFRKQfKFA&bvm= bv.51156542,d.aWM
                            To have any code we create work correctly the first thing you are going to have to do is import a new Library into the Arduino (start reading http://arduino.cc/en/Guide/Libraries to get a sense of what we are doing) a copy of the needed Library and all the files necessary can be found and converted from https://github.com/adafruit/Adafruit_ADS1X15
                            Feel free to do all these steps, but to try and make it a bit more user friendly we have put a copy of all the folders and files you need at https://www.dropbox.com/sh/vv2yzp02fuaiw9d/fY7XZrHg5F Just copy it all into the Arduino/Libraries folder on your PC. Then the next time you restart the Arduino IDE, navigate to Sketch > Import Library and you will see Adafruit_ADS1X15 has been added to the menu. Also if you look at File > Examples > Adafruit_ADS1X15 you will find that sample code showing how to do Comparator, Differential, & Single-ended readings has been added. For our first setup we will be doing single-ended readings with channels 0 & 1 but this could easily be expanded to whatever we want.
                            @John Stone ~ looking for the needed drivers for the BT board that you recommended, we may have to find another version of that hardware (unless you have a copy of them John) no worries mate ~ always have a plan B . . .
                            Hitby13kw
                            Research continues,
                            Last century you were not sophisticated unless you lived in a house with Hot & Cold running water, the tables are about to turn, we plan to make this century go into the history books as the time every house gets wired for Hot & Cold electricity.
                            • Regarding OPTO part:
                              • Assemble both jumpers at bottom left corner of PCB
                              • Assemble components yous ee in circuit diagram for opto functional block
                              • Use an IC socket and do not assemble IC just now. It will be added while testing.
                              The resistor at connector is for convenience hooking up different types of pulse sources. For hook up of your preferred generator we need to know what output it has:
                              • Arduino will operate in push / pull (5V) mod, NE 555 as well (5V ...15V)
                              • Others with i.e. LM339 will be able to sink current only but the circuit might incorporate a pullup resistor.
                              • Lab generators are available with so called digital TTL output (5V). They need to be able delivering 10mA minimum (read manual or spec)
                              Connections and value of resistor mentined above will vary with generator output.
                              I am at work and have no circuit diagram available (dropbox is blocked -> wise company )
                              More advise during weekend.
                              JS
                              • Hi,
                                thanks for hints
                                Those BT modules do not need any Arduino driver. They perform as fully transparent com port from Arduino serial port and perform far above usual PC COM 115000bit per second..
                                Please note some implications:
                                BT boards called :
                                • JY-MCU are mech. and some electrical adaptions only - no BT on board. They are labelled as "baseboard..."
                                • True populated BT I/F incorporate 2 ICs on top side - for some few more bucks. Usually they make use of the adapter board referred above.
                                  Required:
                                  - Slave module
                                  - Power 3.3 .....5V operating voltage (3.3V only also available!!!!)
                                  - TX/RX are 3.3 anyway. Arduino accepts happily 3.3V input but TX 5V from Arduino needs to be adapted by two resistors to 3.3V. See silk printing below.
                                Please stand by! We need to look for 3.3 vs. 5V issue for power and RX/TX signal.
                                JS
                                Hitby13kw
                                Research continues,
