  • Hello JS
    I finally got some time to put on another two fets and there is not even 1/4 degree temp rise above ambient starting temperature. This is compared to finger burning with two fets. Scope shows same sharp square wave. As this board is working great, I will test driver tomorrow on another board without fets attached. Motor runs well with this one four fet board at 25 thru 35 frequency but circuit squeals above that freq.
    Dana
    Nikola Tesla
    • Originally posted by prochiro View Post
      Hello JS
      Dana
      Hello Dana, did you do exactly the same tests, with the 4 fets, as with the 2 fets, if so do you think the driver is overdriving the two fets on these boards?
      Regards Cornboy.
      • @Cornboy
        Months ago I built a three fet setup and reported that for the first time on many single JS design boards there was no heat and motor was happy. John convinced me to go back to two so I did but added a lot of solder and that also yielded also no heat and happy motor. I set up four boards on one and made the larger boards I now use for the Imperial and Imperial was happy. Now along comes the black beauty, JS design and I built Eight. All got hot with two fets, even on a smaller motor. I added two more fets and got no heat and happy motor.
        Yes, I think we were over driving a bit and as I have stated several times, I think the heavy solder was taking up the slack as capacitance. I think the problem is that John built a circuit that is too powerful for two fets. (Over-driving) is a good description. In my humble opinion, we now have all the control needed for the Imperial running a generator and running a bike that we need. The last word still need to be said about this, but I feel at this point that JS will agree this is the next direction with black beauties. anyone can add another fet on reverse side by simply soldering one (be careful about keeping all fet pins together correctly) to the opposite side. Kogs, if you love your wife, DO THIS.
        Dana
        Nikola Tesla
          Hello JS, and all, have been doing more testing, and confusing my self, havn't got a handle on this scope yet.
          This shot is 1us of 30nf cap load.
          Regards Cornboy.
          Sorry for late answer - interent was broklen for a day.
          Well, this is another pit you fell in - sorry for that. But lots of education possible.
          Any automatic function is exatly what it says - it perfomrs a predefined algorithm and is not able to account for non expected or false results. Your scope shot is just an example of that. depending on how much of the true graph your automatic rise time calculation sees, it computes different results. In this case it accounts the time up to the peak value displayed.
          Let's alter our strategy in order to get you an solid grounds:
          • catch your pulse at scope
          • oprate zoom up to 5nS / div in order to see edge zoomed
          • read the steepness of the slope just in linear area
          How can you perform that reliably?
          Let's take this pic as example:
          - Set GND level of your beam to bottom grid line
          - Increase vertical amplification to about 2V/div in order to use as much screen as possible.
          Now we are going to measure relatively in order to get the steepness.
          - operate x/y signal shift dials at your scope in order to align the estimated start point of linear section to the next cross point of screen grid.
          - now follow the linear signal path 1,2,3... horizontal or vertical grid lines (depending on length of linear section). In fact you take the last grid line intersection with linear signal area (vertical or horizontal)
          In the above example your reading will be about 4ns per 5V. As we are interested in 10V (FET fully open) we note 8nS per 10V.
          Thus we can estimate switch on or off time at any condition.
          If you are still confused please post 2 different pics with zoomed signal (GN D= bottom grid line, amplification 2V per div) if possible start of linear area adjusted to a cross point of grid lines (but not essential)
          Sorry no shortcut just now - but tons of chances to learn.
          @ALL: If anyone of you get monster PCBs from Oshpark with double sided copper please I prdict that copper sucks lot of soldering heat. As it is double sided it will suck heat twice. With normal recommended soldering tempoerature you will not get it soldered. You need to increase temperature above 380 centdegree and solder quick.
          JS
          • Hello JS
            I am positive that your boards will be double copper sided. That changed as soon as Sam asked them to do it. I solder quickly at 800 F and if you just stick the tip of solder into flux, no real visible amount, it flows smooth. One other tip for first timers, keeping the tip of your iron clean by sponge or metallic pad keeps the oxidized material off the tip and heat transfers fast. When cleaning tip, keep the angle low to pad so the cleaning is even over the length of tip and not just at the vary end. The finer the tip used, the better.
            Dana
            Nikola Tesla
            • Hey Dana
              That's great news, that you tested the double fets. I was going to change those resistors this weekend, but I will double fets first.
              I got the other imperial rewound last night, I tried to go a little faster, less working wires initially, to see if i could get production costs down. Not good, only doubled the work on the outer coils. You need to work these coils from number 1 to 28. Really intense motors to wind.
              Milling a plate today to try and use imperial frame in gen without shortening frame, looks good so far.
              Machine
              • Count of FETs used:
                I accept your findings, more FETs to stay cooler and I can explain it. Remember I talked in the past of proper cooling!
                Look at the diagrams below! Please note those values regard 50% duty cycle:
                A: First diagram shows how much power (watts) will be dissipated at what amperage. Observe higher resistance and heat dissipation of FETs go hot (single FET: 0.041Ohm @ 25°C and 0.096Ohm @150°C)
                B: Second diagram shows how hot the FETs get internally (max 150°C accepted!!) if they have NO heat sink except their bare housing (62 Kelvin / Watt)
                C: Third diagram assumes a heat sink of 2"X"2X1.5"
                Things get better
                D: fourth digram shows how we can make things even better if we use a simple CPU cooler with fan (1K / Watt). I really refer to simple ones out of old PCs like Pentium. Current sophisticated ones go down to 0.25 K/Watt and better.
                As you can see 2 FETs being cooled properly can be as good as 4 FETs being hot at their limits. For high performance you need 4 FETs superiour cooling included.
                Basically heat dissipation and temperature perform linearly. But our feeling regarding power is fooled because the current enters squared into the formula. (P=I*I*R) Humans need to be thoroughly trained in order to get such behaviour estimated correctly. We here - including me - get fooled if we are not alert!
                I hope all of you can now read those diagrams and estimate what type of measures you need to decide for and where to be alert.
                If you feel this is no "cool" design - IT IS! Compared to transistor circuits it is damn cool! Sorry! Above notions is bare and true physics. Unless we operate bare radiant we can't omit cooling.
                The temperatures given above in diagrams refer to internal semiconductor chip. Of yourse you will not mearue them at the ends of your heatsink. Heat flow behaves like resistors in series (resistance against heat flow):
                • Semiconductor chip to case : 0.26 K/Watt
                • Now you decide if without cooling: 62 K/Watt
                • Or you decide for CPU cooling: 1 K/Watt
                • Or anything inbetween: ????
                Knowing the power to be dissipated (Watt) and summing up the heat resistance we get the thermal limits.
                Her we can easily accomadate 4 FETs.
                BTW: I was somewhat reluctant driving 4 FETS with that Micrel driver but last measurements taken seem to suggest it to be safe and viable. I will take thorough measurements as soon I have PCBs in order to post ultimative limits of this design.
                Next design: I figure to make next design for 4 FETs arranged around a simple CPU cooler, double sided PCB, still through hole but smaller caps (0.1 ....10µF) in SMT, smaller PCB area, bus bars for high current area, genuine screw terminals. It will not happen soon because we will get our current design working fine for further experiments.
                JS
                • Pulsing Pulsed Motors...
                  Originally posted by adversarius View Post
                  Hi All
                  I asked in the Asymmetric Machines thread what the advantages are of pulsing the motors. Is it just to bring down input power and/or for recovering the field collapse of the coils?
                  So, it seems to me now that turning the coils on and off is achieved by the asymmetrical architecture of the motor and not by a pulsing-circuit (like in the Bedini circuit)?
                  The first pulse motor I learned about was the Bedini, so my knowledge of those motors is quite influenced by this principle. The Bedini circuit can remove the BEMF as well and allow for storing the energy (of the field collapse) in a secondary battery, so it does not oppose the rotation. Is this comparable to the principle of asymmetric machines?
                  adversarius
                  Hello Adversarius and Welcome,
                  I am sorry I did not respond before, I was extremely busy for the past few weeks...and still would be...but I made a "stop" to keep Thread posted and up to date.
                  I will try to be brief, you have made very good question(s)
                  The Asymmetric Machines I have displayed in my other Thread does pulse "Internally" by intrinsically Opening (Off Time) and Closing (On Time) all their operating coils/pairs or groups during rotation. They could be fed linearly like it has been observed so far in all of them...However, picture it this way...when we pulse also, our Source (Feed) to this Machines, We are creating a Network Protocol of In-Out Signals between a server (Our Controllers Assembly) and the client (Our Motors).
                  For example, If We pulse a Symmetrical Machine, which is based in a Constant Closed Circuit within to perform a rotation...Our Server (Controller) Signals would be crashing/collapsing in a front end collision at all times within that Symmetrical Machine...they are a "Dead End Street"
                  In Asymmetrical Machines we send a pulse that will trigger a certain number of coils ONLY[Not ALL like Symmetry Does](depending of the Time On duration, Frequency, Duty or more clever configurations like the Four or Six Monster Pulsers through Arduino Microprocessor, etc)...Then those triggered/energized coils would go Off at certain angle of rotation in order to allow other incoming coils to repeat process.
                  If You get a Four Brush set motor and simple pulse-control (like with a simple 555 timer oscillator in Astable Mode) just pulsing Motor Input (Two set of brushes) while reading your output on generator side ...You will get the Machine response/pulse out, it is operating at...so the proper adjustments could be done to "align" or equalize Input Signals to Operating Motor signals...it is NEVER a "Dead End Street" here.
                  As you could also do this testing with even smaller versions of just Two set of brushes...One set Input, One set output.
                  No matter how we do this pulsing..We will NEVER be sending our controlling pulse signals to a "Front End Collision Center" like in Symmetrical occurs...But, instead, it would be a "Looping" of signal communication between Controller-Machine...a much better approach as all could realize.
                  What I am trying to basically explain here, is that We have a real Networking Protocol of Communication between our Machines and our Controlling Signals that will allow a much better driving at any speed torque we desire to take them to.
                  I will try to give you an example in Automotive Driving...
                  When we drive a Stick Shift or even a Manual transmission Vehicle...(and of course, we all 'supposedly' know what we are doing...lol)...
                  When we accelerate with one gear on, we must watch our RPM Meter...to see where it remains steady ...it will go No Further...so we change to next gear...when next gear is coupled, RPM's will decrease drastically...then it is our time to accelerate the gas pedal...till we observe again the RPM's steady to a Max point...and so on...right?
                  Well, this is a "Manual" method to establish a Driving Protocol...and actually we are "Pulsing" the Gas Feeding at the right timing based on just the RPM's parameter...So say we feed this vehicle in a "linear fashion"...not observing RPM's...we end up "Burning Up" or wearing out the Clutching/Engaging Mechanisms...
                  In our Machines we could establish an "Automatic Cruise Control" circuit, based on Motor feedback from our Input signals...and that's the stage we are now, by adding not only RPM's sensors...but Amperage/Voltage and Frequency to our Systems.
                  We will move further on...into "Brushless Asymmetric Machines"...with Hall Sensors driving coils timing, just like a Symmetric BLDC Motor does. Limitations in the beginning would be the use of permanent magnets...However, further on we will be able to have wound and independent (self feed) rotors by Capacitors/Inductance Feeding...not now, not yet.
                  Hope this post helped You to understand Your concerns.
                  Kind regards
                  • A Question to Sir John Stone...
                    Hello Sir John Stone!
                    Hope everything is well on your Family/Personal side...as also your Asymmetric Motor is coming out excellent .
                    I have a question which is related , however, it would take us a step further on the EV Systems that also would apply to Stationary Systems like the Motor-Generator Sets.
                    In my E-Bike, I have a BMS (Battery Management System) that is a "Buffer" between Gauges, Batteries and Controller, as also when I charge batteries it receives the Charger Terminals to its FET's switching bank. This BMS Module does an excellent job when it comes to "Balancing/Equalizing" the 24 Lithium-Ion Battery Bank that reaches up to 85 Volts when fully charged...It does this balancing not only at charging time...but while disbursing energy to Controller at acceleration, Deceleration and Regeneration stages...as it has a TXD and a RXD Channel for Data Transmit/Receive from Controller as it is also sent from BMS to Gauges for I(Amperage) and RPM's and Speedometer reading.
                    The only problem the "Old BMS" had (I replaced it with another one that would eventually develop same Issue) was the Heat Sinking of Four 300 Watts FET's (IRFB4310)...A very tiny strip of copper attached to Board with tons of soldering was the only means of heat sinking this four FET's had...so at charging time they actually melted that strip soldering which was enclosed within BMS sealed steel box, the "soldering blob" walked along all circuit...shorting galore...FET's cracked because of heat...causing serious shorts at other circuits related and connected to BMS...
                    So I took the Four NEW FET's out of the Box...attached through bolts to board (no soldering)...and a remote ventilated location...and since they shared same Drain, I used Four Heat Sinks attached by a Copper strip, and cooling their fins through a small BLDC Fan...every Two FET's had different Gate signals...as Two different Negative Sources (Batteries and Charger)...while charging batteries...FET's went through 160ş F...without Fan On...very hot...so after turning fan they dropped to a relaxed 105ş F...problem solved...
                    The previous Controller got fried due to this short circuit...so I had to order a Kelly that runs the 5000W Hub BLDC motor perfect (I wrote "perfect" for a Symmetric Model best output...however very noisy at start/end of signal send to Motor hall sensors from Throttle Hall Sensor handle , but that's "normal" operation for this design)...however, Kelly's Controllers does not have the TXD nor the RXD Signal capabilities to communicate with BMS, therefore to gauges...so, no speed, no amp reading, no RPM's...as the "controller" word at Cluster keeps flashing, meaning "no controller found". The Kelly Controller comes with an RS232 Plug to connect to PC in order to program operations...it has the RXD and TXD pins 2,3...but only to communicate with PC to run program...so, not good for BMS signals.
                    BMS receives/sends through independent connections from each Battery Cell (it brakes it into Six(6) Banks that comprehend Four(4) Batteries each...and Battery Gauges constantly show the Cycle it goes through at ALL Times ...since we turn key on, or while charging, the reading from each cell in each bank from 1 to 6...and that side works excellent now...when it charges, it "sets aside" already charged cells (they blink)...concentrating charging energy just to the lower ones...this operation also works at balanced disbursement when driving vehicle...
                    My question is:
                    The Old Controller got only one channel out of Three burnt FET's...but the microcontroller circuit is fine (I think, I hope...still have to check it out)...so :
                    If I take off ALL the 30 total FET's from Old controller, as also all the Capacitors between 72V +,-...meaning all HV Circuit will stay open/inactive..And I feed Old controller with 5V and Return Negative...while attaching all three Hall Sensors...would it convert Hall Sensor signals through its existing RXD/TXD Output...?...Using the signals from New Controller?
                    I know If, the Microprocessor works with 5V...and Hall sensors low voltage signals...it would not need their own (built in) HV Circuit...and this will work.
                    However, If the Microprocessor takes "internally" within board, the signals from FET's Drains...then it will not work...
                    According to your expertise, John, the Microprocessor system here should be independently ran with just the 5V from internal or external feed...?
                    In other words what I am trying to achieve...is to use the Old Controller Hall Signal Processing Side to Send/Receive Data to BMS and therefore Gauges...without "acting" as a Motor Controller anymore...as that would be done by the new Kelly Controller.
                    Sorry about this deviation on topic...However, I believe this "experience" I am going through, I should share it with you all, since it will teach Us a lot about new systems that eventually would need to be incorporated to our work with Motor Driving in the future of EV's and Static Systems for Energy Production, Handling and Consumption.
                    I will post a simple diagram of all this later on.
                    Kind regards
                    • Question for ufopolitics on running a brushed motor at cold temp
                      Dear Ufopolitics,
                      I would like to ask you about getting a conventional brushed motor to run cold.
                      First, I would like to thank you – and all others who have pitched in - for posting so much information on such a fascinating subject. I am just beginning in my efforts to understand what you are doing, so I’m afraid my query will be rather basic.
                      I have started by building your circuit (ufo_555_controller_1.jpg), with some modifications (using LM_317_VOLTAGE_REG_UPDATED.jpg for the regulator; and a pulser circuit that uses 555/383 ICs, enabling dual frequency and duty controls). I am currently using four mosfets, though I originally tried six and then one. I went from six to one in case synchronous timing was a problem, but didn’t really notice a difference; but with 1 mosfet, heat dissipation is an issue. The coil is single strand 18 AWG, 3 times 130 turns approx; total resistance 1.7 ohms; inner diameter about 52 mm, empty core (though I have also experimented with stainless steel rod insert). Power source is 3 in series 12V sealed lead acid batteries, each rated 3.3 Ah.
                      I tried the circuit on a CFL (40W), and on 30.6 and 40 VDC brushed motors.
                      Here are some sample findings. With the CFL, it starts flickering at 38 hz and duty 22% (scoped at oscillator output, going to mosfets); at that stage 1.86A is being drawn from battery; there are 0.05A flowing through light (i.e. after the diodes); and there are 25V across the light(i.e. after the diodes running off both ends of the coil). Going up, it can get to a bright constant illumination at about 100 Hz, duty at 33%. At that stage, current drawn from battery (i.e. feeding the pulser and coil) is 3.83 A; current measured through CFL is 0.33 A. Voltage across CFL is 38V. (Of course this voltage is an average calculated by meter). Playing around with duty, one can get the light to start pulsing and then get constant illumination at different frequencies (in general, lower duty seems to require higher frequency to get things going). For example, I can get bright constant illumination at 250 Hz and 40% duty; or at 500 Hz at 30%. In the former case, current drawn from battery is 2.11 A, and through CFL is 0.37 A. In the latter case, current drawn from the battery is 1.35A, and through the light is 0.29 A; and voltage across the CFL is about 90V. Constant illumination initially can be a pale white light; if one continues going up in frequency, there is a range in which bulb goes out, and then starts again with a more yellow light. I have not seen the green light shown in one of your videos.
                      With the 30VDC motor, when cycle is 250 Hz and duty is 40%, I tested it under no load and load (load is clamping the shaft until it has very noticeable decrease in rpms). No load: current drawn from battery is 2.16 A; current flowing through motor is 0.14 A. Load: current from battery is again 2.16 A (i.e. no change); current flowing through motor is 0.24 A (i.e. increase). Of course, I can also get run it to run at lower/higher cycles and duties.
                      Similarly for 40 VDC motor, with cycle at 250 Hz and duty at approx. 30%. No load: current drawn from battery is 2.71 A; current through motor is 0.35 A. Load: current from battery is again 2.71 A; current through motor increased to 0.55 A. I also tried this at a higher frequency and duty, 650 Hz with 37% duty. No load: current drawn from battery is 1.43 A, and through motor is 0.38 A; voltage across motor (i.e. after the diodes) is 71V. When under load, again battery current does not change, while current through motor increases to 0.5; and voltage drops, to 38V. Current drawn from battery seems to drop at higher cycles.
                      I have two main questions to start with, one specific and the other more general. I apologize if my questions are ignorant; or if you have already answered such questions (in which case, please refer me to where I can find the answers – I have read hundreds of the posts here, but not all).
                      First, what I would really like to see is a reduction in temperature of the motor – you have stated that it is possible to do this, indeed to get it to a freezing temperature. How do I achieve that? I take it, it is not enough to drive the motor off the circuit as at present – for I have noticed that after a while, the motor warms up. So what must I do to get it to cool down?
                      I have seen somewhere (“noobs guide to ufopolitics”, which seems to be a collection of excerpts) that you have written that: “you could figure out the turn ratio per contact of brushes-commutator to rotor coils, in order to build your coil accurately.”
                      I don’t understand that statement. Would you please give an example illustrating what you mean? For instance, with a two brush motor, for each brush there will be so much wire with so many windings. From there, how does one wind the primary-secondary coil, I mean what are its characteristics? And, is it necessary for there to be some correspondence between the motor windings and the primary-secondary coil? Of what sort, and why?
                      More generally, I would like to know, given the set up I have now, how can I be sure when I might be drawing RE?
                      One final practical matter. Must the power source be batteries? Could one use a benchtop DC power supply instead?
                      Thank you very much in advance for any advice. And again, I want to commend you for everything you have done in this area, and for your generosity in sharing information.
                      Kind regards,
                      ntc
                      • Hello and Welcome NTC
                        Originally posted by ntc View Post
                        Dear Ufopolitics,
                        Kind regards,
                        ntc
                        Hello and Welcome ntc !
                        I am very glad you have made so many testing with this original Coil set up...It's been a while since I do not "play" with this...
                        Ok, a CFL depends on its Wattage for it to draw a certain amperage, I have run up to 125 W CFL rating (equivalent to 600 Watts Incandescent Lamp) .
                        Have you watched my YT Videos related to Radiant Energy ?
                        RADIANT FREE ENERGY - YouTube
                        As I also recommend:
                        DEFINING RADIANT ENERGY FIELD (Part 1) - YouTube
                        The Green Light is just an "Spectrum" that occurs in very short time...to a point it is not visible to our naked eye...just play back your own videos...then your camera IR and Electronic fast Capturing shutters will do show it...
                        Watch RADIANT_ ENERGY_ULTRAVIOLET_SPECTRUM_GREEN_STROBE - YouTube
                        Notice that I have to replay video at very slow motion...in order to see the Green Light in normal development for our eyes...However, also notice the UV Spectrum...spreading at environment nano seconds before green strobe...
                        Related to the Motors you are running...they are too High End for the small coil and set up you have...and that is what I meant when I wrote that sentence...Fields, Magnetic Fields MUST be balanced in order to achieve the Effect. If You try a smaller motor, like the Goldmine Five Poles (550 Body) they will run cold.
                        Why Coils must match?...Why do we need a bigger battery bank to run properly certain Symmetric Motors?...same thing. Our Radiant Field Capacity depends upon the Geometry and size of our Coils...Think about the Wardenclyffe Tesla Coil...
                        You could have a bigger Capacity Coil and run smaller motors very cold...however, when you install a brushed symmetric motor that would demand a higher draw from coil...it would overheat either one of the two Fields (Motor Coils or Supplying Coil ).
                        How do You know your Symmetric Motor Total Coil Resistance?...Easy, just find the attaching point where two wires reach same commutator element hook, it is normally one single wire that "lands" to each hook then keeps going to coil, then to hook and so on till that finishing ending hook...that's starting and end point when they wound it...separate it by spreading/opening hook...just release from hook one terminal (normally is the last wire that was hooked)...then measure resistance from terminal at hook and loose wire end...that's the Total Resistance from Coil when your Motor is running...then replace wire and press hook back...Your Coil Must be Equal or Above that resistance value.
                        There is more about this...and it occurs that when using a higher capacity motor...drawing more current...then Hot flow over rides Radiant flow within circuit...that is when I did the "Happy Motor" Circuit...and Member Kogs (Ian Koglin) from Australia has made many tests with this set up.
                        The Happy Motor uses a Secondary Coil to run from Primary...where there is no ferrite nor steel core, but Air...what happens is that we are weakening the Hot Field by doing this...since Hot will only induce a Secondary through a ferrous core...then Secondary would be a higher percentage of Radiant Energy and minimum hot.
                        At this point I could not find my original diagram for this...so if anyone has it...please post the "Happy Motor" schematics, thanks!
                        How could you know it is Radiant?
                        Simple, use a neon bulb at the reverse side...Radiant is a Purple Plasma Ball, Hot is an Orange light like the Normal one you always see on Neons......it will manifest ONLY at very low pulses 6 to 8 Hertz...
                        RADIANT ENERGIZED NEON - YouTube
                        Finally, related to Batteries versus Power Source Unit...I rather use batteries...preferably SLA (I have used LiPo's...but they say they are dangerous...) so I only recommend them at your own risk......However, a PSU We could administer the Amperage draw...so, it would be interesting to see the development when lowering current input under load at Coil Output.
                        Thanks again, and hope this helped you.
                        • Hello NTC
                          Hope this helps
                          Dana
                          Nikola Tesla
                            In my E-Bike,..... I will post a simple diagram of all this later on......
                            Hi Ufo,
                            still waiting for diagram!
                            Basically your intention seems to be viable (as I understood your words). The implication is usually that controllers perform all kind of checks and supervision at important circuit parts. This might cause them to enter a safety or emergency mode and that is not what we expect.
                            @ALL: As Ufo experienced a FET driver needs to be double supervised in order to prevent total loss. The problem is that FETs increase their resistance if they get hot. One FET failing causes others to increase their resistance as well ..... -> that is a so called domino effect!
                            This is the reason industry likes IGBTs for severe power applications. They behave inversely and hence somewaht more safe. For our applications it is not necessary using IGBTs.
                            Measures for safe FET operation:
                            1. Use a fuse being adapted to your current application.
                            2. Provide an emergency switch at your setup in order to imediately stop current in case of damage.
                            3. Use of a temperature sensor at FETs (definitely an issue for next driver desing)
                            JS
                            • For ufopolitics - thank you and questions about cold dc motor
                              Dear Ufopolitics,
                              Thank you very much for your welcome – I am really glad to be here! – and for your response.
                              I understand that I have two options to get a conventional brushed motor to run cold (i.e. temperature of motor reduces) – please correct me if I am wrong.
                              First, I can keep my current coil (3 x 130 turns, 18 AWG, resistance 1.7 ohms - as described in previous post), provided that I find a motor where the total motor coil resistance is less than or equal to the resistance of my coil.
                              That’s all there is to matching?
                              Thank you for explaining to me how to figure out the motor coil resistance, and for suggesting the ‘Goldmine Five Poles (550 body)’. I’m afraid I’m not familiar with that motor, could you point me to where I might find it?
                              By the way, I neglected to mention that when I run motors off the coil, I have two el capacitors (10uf, 250V) across the wires after the diodes, i.e. on the cold side. (I got that from a post on this forum, thank you netica!) Are they needed? Will they affect the motors cooling down?
                              I will try this first option as soon as I find a suitable motor, and let you know the results.
                              Second, I can build a new coil with a secondary wound over top the primary (i.e. as described in your happy motor diagram). Now, in this case, may I ask you some questions. In order to get the motor to cool down, must the total resistance of the coil be less than or equal to the total coil resistance of the brushed DC motor (as above)? If yes, is it the total resistance of the primary PLUS secondary, or just the resistance of the primary coil alone?
                              I see that your Happy Motor circuit diagram has been posted – thank you prochiro! – and I find that very useful. Are all diodes the same (e.g. NTE 576), or are there two different types?
                              I am sorry to have so many questions, and sincerely appreciate your patience, support and explanations.
                              Thanks for the links to the videos – they are very helpful, and stimulating. The slow-mo replay of the CFL glowing green is quite something.
                              I am going to find a neon bulb, and hunt the purple plasma!
                              I will stick with batteries for now, but may try a PSU later. I am trying to learn as much as I can about your circuit with testing, but I seem to spend a lot of time charging …
                              All best,
                              ntc
                              • Hello NTC
                                All the diodes are the same. Electronic goldmine is the company and G18945 (Clickable) is the number of motor we use.
                                Dana
                                Nikola Tesla
