I'm trying to get an ignition coil to create sparks running it with a Mosfet powered by a 555 timer. The Mosfet is definitely switching. I checked it with resistor, ampmeter, and o-scope. Everything is behaving predictably but when I use it to power a car Ignition Coil, I don't get any sparks. I can tap the terminals of the Ignition coil by hand -- Even with it connected up to the mosfet circuit -- and get sparks. But when I try to let the mosfet drive it, there are no sparks. There is definitely current flowing. And if I change the frequency to super low (like a pulse every second), the ampmeter is registering the pulses. If I change the frequency to super high (like 100khz), I get averaged current flow on the ampmeter. But I don't get sparks!!!!! I also switched out mosfet with other kinds (different ratings). Didn't fix it.
Anyone else ever run into this problem???
Here's a schematic similar to my setup:
http://www3.telus.net/chemelec/Proje...Car-Coil-1.png
Hope someone else has had this problem before and can help!!
Jim
Jim
