Dead batteries charging
Hi Chris, one of the things I've tried ,is when you finish several runs ,and that dead battery has charged (which were trying to avoid).
Hook it to a plug-in wall charger, I've been able to bring dead batteries back to life. It doesn't work with all my dead batteries , but it does work with some. (more capacity than they started with ,but not like new)
Also I found that by running the same battery in position 1 ,will damage that battery, You have to rotate.
I'm still using this system and will continue.
Definitely has some interesting aspects
The more things I do, the more questions I get.
Try everything you can think of,....the answer's there somewhere.
artv
3 Battery Generating System
@Dave
Well I just started started to investigate this restoration project. A small scale with a tiny motor and 2 watt load. Approx 4 hours run time and some improvement with being able to eliminate the bulb and resistor load. So, the resistance of the small bat 3 has gone down. To make use of my solar panels, I will have to move to larger things. Maybe I will try and get something bigger going on in my well house. The weather seems to warming up somewhat where I live.
@Randy
I see what you are saying. I could tell my bat 2 seemed to be supplying the resistor battery in 3rd position. I will remove bat 2 and put it in the well room. I have an old car battery that holds 12 volts for position 1. The lawn tractor bat will move to position 2 and leave small bat as it is in 3rd position. That way the newest battery next to resistor bat. I want to explore resonance with it in my more comfortable studio with wood heat.
In the well room I have two deep cycle marine batteries for position 1 and 2 and the three identical old SLA bats for position 3. Have several old radiator cooling fan motors laying around I can try for the motor. Also have two very old 6 volt golf cart bats. I can hardly move these things around anymore as I am getting old at 77. Really want to finish a lot of projects this year so I can relax.
Chris
Chris,
This has been my experience with this setup. It is an RLC circuit with a spark gap. The battery plates do provide capacitance. The motor, is the L and sparking. The 3rd battery, the R. It is important to place the battery you to want repair in the 3rd position and use two good batteries in position 1 and 2. This is your power supply and provides little repair benefit to those positions. Position 1 does provide a little. I refer to position 1 as the power battery closest to the motor.
Most meters can't follow the mixtures of current, frequencies, and harmonics that take place in this simple circuit. It is definitely an AC/DC circuit. The interesting harmonics happen between the motor and the third battery, before a certain point of repair.
Good Luck,
RandyLast edited by tachyoncatcher; 01-30-2014, 02:57 PM.
Frequency
Chris,
Thanks for this input, and you are correct. There has been lots of talk about frequency and resonance, but not any data or any measurement from folks replicating. I will definitely start looking at this, especially when I have the thing working like it is supposed to. Getting the right frequency couldn't hurt!!
I haven't been posting here, except to respond to the posts of others, but that doesn't mean I haven't been working on this. Not a day goes by that I am not running some kind of experiment with the 3BGS, and usually more than one setup at a time going.
Maybe what you have posted will get some folks thinking and maybe thinking will lead to action, and action to results. Or maybe this thread will just die out. Who knows. But thanks for posting. We need people working on this.
So, are you having any luck restoring those bad batteries? LOL
attempt to restore old batteries
Hi All,
Most my big batteries are in my well pump room, unheated. I wanted to try and use 3bat system to restore some of them. Most the old batteries I have are probably good candidates for a bad battery. But, I am not ready for that right now. I have some solar panels I want to set up next spring. If I can reclaim some of these old batteries, so much the better. This is easier than building a Bedini setup.
Anyway, I fired up the wood stove in my studio and drug in some smaller batteries. One good hardly used two year old lawn tractor battery from walmart, one 12 year old SLA battery about the same size. This battery slowly climbed to 10 volts with trickle charge. Highly sulphated. Two other identical batteries only got to 2 to 4 volts. So, I used this one for bat number two.
Bat 3 is a really old small battery out of a UPS system for computer. Will not hold any charge to light anything but a flash on a led. This bat is about 4 inches square in size. Has a standing voltage of about 5.
To get anything to run I had to put a small two watt dash light bulb across bat 3. I have everything hooked up to split the negatives like in skeptic video 9.
I had to spin it to get it started, but there was 20 volts across the bulb. I was afraid it would blow the bulb, so I put a 130 ohm 2 watt resistor to drop the voltage to about 14.
After about an hour, I noticed the resistor was really hot to touch, so I paralleled it with another 130 ohm two watt resistor. This gave me 65 ohms and reduced the brightness of the bulb with about 10 volts.
After about 3 hours running, I was able to get rid of the resistors and the bulb and run just on a 12volt led array to replace clearance bulbs on cars.
I am running a small motor I salvaged out of an old HP printer. Everything running smooth and quiet. Battery voltages about the same, bat one 12.2v, bat two 10.1v and bat 3 10 v.
Gee, all this writing just to get to the point of my post. I fired up my old bench meter and checked the battery 3 for frequency. My hand meter was showing AC voltage about double the voltage DC. It is polarity sensitive. Therefore I assume It is pulsating DC from the brushes? This is the reason I decided to check the freq. I am getting about 2.4 kHz across bat 3. For some reason I decided to check the freq of bat 2 thinking it would be the same.
But, battery 2 checked out at about 1.1kHz! If I had used a good battery on 2 position, it would have absorbed all the pulsing DC just like bat 1 shows nothing on the freq or AC settings. I was surprised the freq was different.
My feeling is the different size batteries with their high impedance are setting up different resonances with the coils in the motor? Freq much too high for it to be just brushes. I would guess brush freq would be in the neighborhood of 200 to 400 Hz?
Maybe this is old news for some of you. But, I can't recall much discussion on this thread re the freq of the pulses going to bat 3, and why bat 2 has diff freq?
Is it the capacitance of the batteries setting up resonance with the coils as in a parallel circuit?
Just putting this out there for what it is worth?
Chris
can It be known
Hey shylo,
I really get excited to see and hear of these strange anomalies in batteries. But what causes this to happen. How do we repeat these pulses of energy. Can It be manufactured and placed in a box so we can be free.
Can It be known? So good feeling to experience this but frustrating to not be able to give a setup to a family with no job, money or power to heat their home.
So can It be known, one day one of us will find IT,
wantomake
draining the battery
Hi WTM, I can't say , but I have seen a load to drain my dead battery go dead , after 10mins, come back to life, then repeat. I just get tired of waiting for it to finish.
Strange though you would think with the constant load of the motor , the battery shouldn't be able to recover, in order to run it?
artv
test with aluminum sheet
Hello to All,
Found interesting results with aluminum sheet in water.
1) connected wire to pos of #3 battery from aluminum sheet
2) placed car window motor across two neg not pos post
3) no lights on #3 to balance system
While I waited to see #3 drop in voltage and motor start, the primaries voltage started jumping 22 volts to 19 or 20 then back up to 22 again. I tested #2 primary and found it was the one.
So I connected 12vdc light (50 watt) to #3 and the motor started with a surge sound each time the voltage jumped in the primaries 1 and 2.
This happened for five minutes or so and charged the primaries up. But then would start to lose voltage. The #3 would hold around 2.8 volts.
Each time I turn off the motor, let the primary alum batteries sit, they return to 11 volts or so each. I don't recharge them. Then just connect motor and watch the same thing happen. Without light on #3.
Just curious to what you all thought. I did make a video and will post to YouTube later.
wantomake
Timing
Originally posted by cornfused View PostHi Dave
Funny you mention the motors run faster wired up a certain way..
When I was a kid, my dad and I (well mostly me) raced r/c cars. The modified motors all had replaceable brushes and a person could adjust the timing. You timed it in relation to the brushes and magnets. If I remember right advanced timing gave you more rpm, but more current draw, I..e heat. Wouldn't last as long. Retard the timing and the motor had more torqe but still draws more current. We had to find the sweet spot between runtime and speed. Of course the drawbacks were heat . Maybe a person could adjust timing of the motor to compensate for load on the 3bgs.
Jason
My nickels worth.
Good Luck,
Randy
Originally posted by Cornboy 555 View PostHey Duncan, i have done a few experiments with granite dust, ( or metal dust, as we call it ), straight from a quarry.
The parramagnetic strength vary's from quarry to quarry, i have tested samples from 4 quarries in my area, the difference in gauss, etc, is profound.
This dust is an incredible long life soil fertiliser.
My other interest in this dust is for a core material for motor coils and i will be trying some highly parramagnetic dust mixed with high temp epoxy, in my next build, just to see.
Regards Cornboy.
Dear Duncan.
It always amazes me how a simple statement made by one can inspire another !! My little accident occurred a couple maybe 3 years ago, dementia or just getting older who knows ?? I had learned to cut out the area in question from my sight !!However we both looked yesterday and the distinct lines are now so faded as to not be there anymore, just the very poor attempt at my repolishing remains !! Grin
I have Granite, not because I can afford it but because a very old friend owns Granite business !! Wink So your test could well be quite simply tried !! Big but !! My work surface is much more strongly magnetic than the other bit's and bob's that I have!!
Do you think this might have a bearing ??
Hi Dave
Jason
Originally posted by Duncan View PostI'm running on a bit of a tangent as you all know .. still we are trying to boot the ball into the same net, so If I see something or its reported and I think it pertains .. I'll post . Such is the case in this regard . I did not know granite is radioactive .. neither did I Know it is magnetic . All that aside this was posted..
I know full well there are strange thing happening when an LA battery is being charged !! I got a serious ear bashing from my wife, when after a couple of days charging a battery on one of our Granite work surfaces, upon moving the battery the Granite had taken on the shape of the cell structure within !! And despite a whole day of re polishing there is still the faint outline !!
The pleasures of OU research !!
It may not mean much to you .. but it speaks volumes to me . I questioned the man, That occurred with a standard battery charger.
Regards Cornboy.
When you look at the direction of current flow in a potentialized system such as this and consider the motor to be just coils of wire located between a higher potential and a lower potential, you want the flow to be in a specific direction through those coils. Why??
1. These motors were designed to run in a specific direction and
2. These motors put out power as a generator in a specific direction.
So, does the generated output of the motor come out the + wire on the motor or the - wire on the motor?? And is that wire connected to the two batteries in series or to the single reversed battery. That will affect your results I should imagine.
Is the current that is traveling through the motor turning it in the direction it was designed to turn in for alignment of the brushes? And please don't tell me it doesn't make a difference, because it does. I have run this motor on high voltages, and know you get more rpm's out of it when it is hooked up correctly.
These things, which I really hadn't considered until viewing the discussion on Erfinders thread, could be the difference between success and failure in the setup of the 3BGS. You can run the motor between the positives or between the negatives. You can reverse the motor in either of these locations. I know on my original setup I split the positives, but I do NOT know which way I had the motor running. It seems that we have four different possible configurations even in the BASIC setup, and I don't know that we have narrowed it down to which one is the best.
Dave.Last edited by Turion; 01-15-2014, 05:59 PM.
I have heard it all now. Granite is born out of moisture. Its moist in the mountain, it cut out with moisture, its slabbed up with moisture and it polished with moisture. And moisture is trapped in it.
Its also NOT a solid color. Every part of it is translucent. The stain could be below the surface and give it all kinds of appearance. If you actually etched out the polished surface its because you got battery acid on it. Lemon juice left alone on a granite top will etch it out.
But more than likely if polishing didn't remove it it was moisture. And it went away eventually.
Like I said more housewives than I can count have complained about the same thing. Make a mountain out of a molehill. More of it because they think they are paying way to much for a maintenance free stone that will last forever and never blemish. LOL
Goto any granite shop and get a piece of waste and try it, you'll see Its just moisture.
Shape = deformity = alteration of structure of some very hard stuff polishing is a sweet word for grinding , the man isn’t talking about a temporary stain , and I doubt moisture, still as I say make what you will, I think it could be important, flick it off the cuff if you wish.
