Originally posted by citfta
sulfated batteries, my own battery began to hold charge and so I changed to
a battery recovery program, hence I cannot add anything much here to help.
Considering the sheer number of weird things that lead acid batteries can do
nothing is ruled out by me.
There is another effect of lead acid batteries which I have seen myself and
had a battery which did it. I have suspicions about how I could recreate this
battery behavior. But I would need a SLA in poor condition to try it.
phantom empty - YouTube
Now bear with me please, Sucahyo attached the meter at the same time as
the load which meant the standing voltage was not shown. The battery I
actually had showed a standing voltage of 12.8v but when loaded the voltage
would drop to nearly what we see in Sucahyo's video, and the same behavior
afterward.. The battery could run a load, but if left for even 1 minute the
effect would begin to return.
Now here is the theory. if a battery like the one shown can be made to
behave like that but from a starting point of very little charge rather than full
like Sucahyo's battery is, it might work in this system.
My theory of how the battery got like that is that it dried out while fully
charged and became saturated with sulfate (i'm no chemist so this is pure
speculation), what I did was I added more sulfate in the form of magnesium
sulfate in a saturated solution. Which actually seemed to make the battery
worse or the effect more pronounced, and it did produce more power, but it
would not rejuvinate and I discarded it.
My bet would be to fully charge a nearly dry SLA then by removing the cover
plate and plugs add more saturated sulfate and maybe let it dry out some
more. If the battery did take on the traits of the one I had then draining it
would make almost impossible to charge and it would have charge
characteristics similar to the discharge characteristics of the battery in the
video. In other words it would do nothing for a while then it would allow some
current to flow and either charge or just raise the voltage or drop the voltage
or something funny.
This could explain why the SLA batteries work, because a dry SLA battery has
the glass mat holding the dry electrolyte to the plates.
P.S. It's the 21-December 2012 here now and has been for over an hour
nothing has blown up and no huge fissure has appeared in the sky or anything
else catastrophic. So the hunt for new free energy must continue.
Best of luck to all.
