A solution to "making" a really dead appearing battery?
I recalled coming across this tidbit and hope it is of use. From here:http://www.theorionproject.org/en/documents/Gary_V.pdf
On page 44:
Here comes the explanation:
On page 44:
There's one other little thing. At that same International Tesla Conference in Colorado Springs, the folks who were in charge (for the energy barons) of suppressing all successful over-unity devices in the Western world were also there when Watson demonstrated his 8-kilowatt device. There is a certain effect which happens in a battery sometimes for a large over-unity battery popper unit like that, if the device is "for real". Time-reversal operations and wave transductions can occur, resulting in time-excitation charging inside the battery materials, in a negative time charge sense (remember, the over-unity operation is a negentropic operation). After a machine of that type and with that particular internal effects has been used to furnish energy for quite a while, you can make a definitive test on it. Simply hook it to a normal battery charger for that size battery, and start to charge it. You then may find to your surprise that the power will just seem to "disappear" in that battery, without charging the needle one iota, for 16 to 48 hours or longer, and in a rare case for two weeks.
The reason is that wave transduction occurs of your charging spatial energy into time-energy, and so you have to furnish rather enormous energy to get a little bit of that negative-time charge reversed. After you fill that seemingly "bottomless pit", then suddenly the negative time-charge will have been eliminated, and at that point the battery will start to charge up in quite normal fashion.
