3 Battery Generating System
  • Mario
    Hi Aaron,
    I have a question. In his "SG beyond" presentation Peter showed a 3 battery system (24V each) where the 2 series batts run the load into a single battery, and then they get rotated, which is basicallly what John's first 3 battery diagram was showing.
    In Peter's Benitez presentation he showed a 3 battery system (12V each) where 2 series batts run the load into 2 parallel batts (Benitez style) instead of just into one.
    Do you know which one of the 2 setups worked best for him?
    cheers,
    Mario
  • Netica
    Thanks again Turion, I mentioned welding rods because that is what Matt mentioned to use - 6013 welding rods cleaned of their flux.
  • Turion
    Stuff
    There is a supply warehouse that I get 3/16 steel rod in 8' lengths and I cut it to whatever length I want. I sand it while it is still in the long pieces to remove any oil or sticky stuff, and then paint it. I epoxy it into the core, otherwise the magnets will yank it out. That I can promise you!
    I'm sure you could use welding rod, which is what I USED to use until I ran across the slightly smaller rod in these nice long pieces. I want the smallest rod I can find so the air spaces are as small as possible.
    Hope that helps
  • Netica
    coils
    Ok, rather than rely on imperfect memory, which I have done in the past, I went back and actually LOOKED at my notebook. I used 12 strands 253’ long of #23. If I said anything else, I apologize and I need to correct it. My original coil was 3 strands of 800 feet (not 1000 as I have said recently) so 2,400 feet of wire and the coil was pretty full. If you do the math you will see the numbers I have given add up to over 3,000 feet of wire on the coil. Over the course of several builds I worked my way up to that final number OF WHICH I used 18” of wire on each end of the coil to run to my connections and it completely fills the bobbin. I will post a link to where I got the bobbins later today, and get you the dimensions. But I will say this in advance. Anyone who has access to a 3D printer would be better off printing their own bobbin with square ends. For some reason the coils want to rotate, and if not held securely, they WILL, and pull the wires loose. I learned this the hard way. Round bobbins in round holes can rotate. Square bobbins in square holes cannot.
    EDIT:
    Link
    Wire Spools Reels ? Pittsfield Plastics Engineering, Inc.
    3 1/2" diameter
    3 1/4" length
    3/4" hole for core
    I realize those are not the technical terms, but that's what I got.
    Thanks Turion for this clarification.
    Regarding the welding rods do you just take off the flux and epoxy them into the bobbin. Or is heat a problem here and the glue melts. or do you press them in? Do you coat them? Is there a better size to use as they come in different diameters? or anything will do?
    Thanks for all your help.
  • Aaron
    testimonials
    Originally posted by jimboot View Post
    Hey Aaron, you're a smart a guy with great marketing chops. That's a compliment from someone who knows one. Look at it this way, for a product to sell it needs authority and trust. I know you know this. These days though with social media trust has to be earned. Verified Testimonial platforms is a huge business. Trust Pilot, Judge.me, Yotpo, Google the list goes on. Like many of us here I've built a bunch of things which never lived up to claims on the package.
    The Internet has evolved and more than ever extraordinary claims require extraordinary evidence. So for me personally I wouldn't blame a bloke if they third party verification of an effect. I only work on replications from other builders who's work I'm familiar with and trust or others work that is recommended by them.
    Seems to get a lot more heated in here these days.
    Hi Jim,
    There have been times in this forum in the past it got so hot it almost melted. lol - for this particular topic, I've been personally involved with these concepts for a while and have seem various iterations work as claimed too many times and find it nearly impossible how anyone can doubt what seems so obvious.
    I started a new thread here if you can respond to me there regarding the Testimonials - please tell me more.
    http://www.energeticforum.com/renewa...ng-claims.html
  • Turion
    Coils
    EDIT:
    Link
    3 1/2" diameter
    3 1/4" length
    3/4" hole for core
  • NROC
    Hey Mario
    Hey Mario
    Ah okay no worries I get you, yeah we are talking about slightly different things.
    Hope your good
  • jimboot
  • Mario
    Originally posted by NROC View Post
    I disagree that the reactance becomes infinite in a resonance condition for any coil with inductance and capacitance. The reactance is still zero in the parallel resonance condition its just that the impedance goes to maximum because the currents are bouncing back and forth between the capacitive and inductive portions of the circuit. Because the currents bounce back and forth between L and C that portion of the circuit looks like an open circuit to the source and only the resistive part of the impedance exists. That is - that the resistive part of the impedance goes to maximum but the reactance still goes to zero.
    I dont have any experience building these coils into motors I have never tried it so I wont comment anymore on that. I do however have a lot of experience with Tesla's coils and building resonant transformers and that is why i wanted to correct your statement. In fact, if you build a coil that utilises a parallel resonance condition and make the coil in such a way that the magnetic fields can cancel one another as the currents oscillate between L and C you will produce a longitudinal wave with the addition that you must suppress any radiation as EM waves (no sparks). Bifilar coils work well and mobius coils inherently do this. it can also be done with normal solenoids and pancake coils. The tricky part is detecting them which cant be done with normal RF antennas. Anyway this is a topic probably meant for a different thread.
    Hi Nroc,
    I used the term reactance incorrectly you are right, I meant the reactive part of the impedance goes to zero inside the tank at resonance, which to the source looks as maximum impedance though.
    In the case where the source of the parallel tank(like a bifilar coil or a normal coil with parallel cap) is magnetic, such as the passing magnet, at resonance you have the point of maximum CEMF against the magnet, which bring the rotor to an abrupt decrease in rpm.
    When talking about bifilar coils I didn't mean coils that cancel their magnetic field and produce longitudinal waves. I'm talking about two parallel wound wires which are then connected in series, the start of one wire connected to the end of the other wire. You seem to be talking about a bifilar where the 2 ends are connected, which results in a magnetic field canceling coil.
    All this just to say that a bifilar series coil behaves just like a normal coil with an added parallel capacitor, except for the much lower Q.
    cheers,
    Mario
  • Netica
    Hi Turion,
    I am interested to know the dimensions of the coil holder.
    Matt has said his was 3.25inch tall and 3.5inch wide. (using tall and wide I didn't find descriptive enough).
    Can you please let me know what diameter it is and the overall length and the thickness of the sides. And whether it is completely full of winding or if there is space left for more.
    I am sure we could make them a bit wider or longer however it would be good to know what you have done as a starting point.
    Can you please let me know the diameter of the 6013 welding rods used and how you held them in the core. I am expecting that the diameter doesn't really matter but would be good to know what you have done.
    Also you have given different reports of wire length, being at first
    12 strands of #23 253 in length and then
    12 strands of @23 153 in length.
    I was wondering which is correct.
    I would expect that things don't have to be perfectly the same but there is probably an incorrect recollection with one of these and it would be good to know which is correct.
    Thanks for help
  • Aaron
    NROC's comment
    Aaron, was my post not on topic? What part exactly do you want me to comment?
    Mario
    Mario,
    Of course your post is on topic - extremely on point.
    NROC has a bit different perspective on what you posted - that's all I was pointing out if you could comment on what he said.
  • Mario
    @Mario,
    Hopefully, the thread stays on topic.
    Would you mind addressing the above comments?
    Mario
  • Aaron
    @Mario
    Thanks for clearing up the misconceptions with regards to the patent and generator didn't mean to confuse anybody. I agree that the Tesla patent doesn't necessarily contribute anything 'magical' to it.
    All the best
    @Mario,
  • Turion
    Mario,
    Across the board= all the time/everywhere. Amp reduction is all the time.
    I wanted to see if a longer iron core would help with the heat problem and what effect it had on coil output.
    Seaad,
    Where wound I use transformer oil and for what purpose. You lost me.
  • seaad
    Turion Try transformer oil.
    Arne
