Home made AGM's for more control
Hello, I made pure lead plates yesterday from a junk deep cycle battery. I have a question for all: What makes the difference in performance of the 3BGS/5BGS in term of type of battery used ? The SEPARATORS. The AGM use a separator made of fiberglass tissue. It contains boron, silica, potassium permanganate and other compounds. You can either buy fiberglass or mat glass separator for very cheap on the internet. I will do that. You need to add the diluted sulfuric acid too for the normal chemical transformation to take place inside the cells. I will then form the plates with a regular charger and then let it sulfate over time. I will try to test the system will low voltage (a 1,5v dc motor and single 2v cell). You can create high voltage spike with very low voltage but you need more motor speed (higher frequency). I know that silicon and other oxides or sulfates can create semi-conductor properties. A one way energy valve. Some things to think about guys.
