3 Battery Generating System
This topic is closed.
  • Originally posted by altrez View Post
    Hello bistander,
    Do you have some links you could share on this?
    Thanks!!
    -Altrez
    I would think that would depend on the PWM you are using. If it actually bucking thats not a problem. If its just cutting up your current with a timed on and off that is a problem. You can look up Volt-Second principles. Its 101 engineering for sure. Lots of things fall under Volt-Seconds principle its really useful concept to know.
    Matt
    • Hello Everyone,
      Here are the final results of my tests.
      Here is the basic battery test using only the motor, a 12v 7.2ah battery and a PWM:
      And here is the final tests for the one battery circuit's 12v 7.2 ah battery:
      I hope this test was helpful to some of you. It ran for 3 hours and I let it rest for almost 20 hours before taking measurements.
      -Altrez
      • Cutting up current
        Doesn't the Matt modification to the motor cut up the current with a timed on and off?
        • 93% duty cycle. No matter the speed.
          • 45 people watching. Watch now, you know good info is coming, Its always near when the man sends his minions in to disturb the thing. You see bisexual is hard at trying to implant the doubt. He's about to loose his bonus, but the fact is compared to the disturbance of Bromikey this bisexual clown is a flat out rookie.
            Bisexual go over to BroMikeys desk and get some pointers you need the help of a senior disturber.
            In the end all you are going to be out of a job....
            Tomorrow I'll show you the GEN frame, then I gotta wind and tune the coils. That is as long as the power don't go out. Lightning everywhere tonight.
            Stay Tuned!!!!
            Matt
            • duty cycle
              Looks more like ~50% on Gotuluc's scope.
              • Lol
                Matt,
                Once you show them they won't have any more excuses for not building this except $$. What will they have to whine about?
                But don't worry. At least one of them will claim that it's a "fluff charge" on the battery and it has REALLY lost voltage but we don't know how to measure it. Or you are using faulty meters or something.
                They won't be able to get it through their heads that it is for real. I know all the whiner tricks. I have been observing them for ten years.
                • Hello everyone,
                  I am going to start ordering supplies for the motor modification and was wondering of those of you who have built it could you please post a parts list. My goal is to make absolutely sure I am buying all of the recommend stuff.
                  It would also be nice to get as much as I can off Amazon so it is a one stop shop to get the parts to build this motor.
                  The plan is to build and test the motor and post all the results. When I have it done I will build another one and send it to one of the people in this group to test as well.
                  Getting excited!!
                  -Altrez
                  • Youtube link
                    Hello everyone,
                    Getting excited!!
                    -Altrez
                    Hey Altrez,
                    Try this YouTube link:
                    https://m.youtube.com/channel/UCGVcH_sVjarbs-vvfSeUQ8w
                    I'm sure Matthew will give more info as he sees you want to build this modification of his motor. But these videos got me started.
                    wantomake
                    • Originally posted by wantomake View Post
                      Hey Altrez,
                      wantomake
                      Thank you wanttomake. I will be ordering parts next week and posting everything I do to help everyone move forward.
                      -Altrez
                      • https://www.youtube.com/playlist?lis...7WsknDG4439vV3
                        Thats the instructions in case you didn't have them. You just need wire. I wanna say 600ft of 24 awg will do the motor. 3 strands per winding. Can't remember exactly how much it takes. Some of the motors will take a skate board bearing.
                        https://www.amazon.com/Ceramic-Beari...563J3TZH9KE6Y2
                        If you have set of calipers you can measure the inside spots for bearings see if the ceramic will fit, Or you can just buy a set of regular bearings. The stock bearing aren't great.
                        You might want to be able to tune past the screws so some thing to clamps the motor together from end to end. I didn't do this except to test and then I built a new brush plate that mounted on the back with the adjustment prebuilt into it, but I gotta CNC to make those things, not so easy without it.
                        I can't think of anything else.
                        **Added this.. You may get extra wire in case your first attempt fails. Its not an uncommon thing. Better to have wire and not need it .....
                        Matt
                          Matt
                          Will this wire work?
                          https://smile.amazon.com/Remington-I...wg+magnet+wire
                          -Altrez
                          • https://www.amazon.com/Remington-Ind...ZB9AB1NMN0EG5V
                            This is 200 Deg C wire. This will hold up better under a work load.
                            Matt
                            • DC motor control links
                              Hello bistander,
                              Thanks!!
                              -Altrez
                              Hi,
                              It's been years since I've looked. Back then there were numerous tutorials, white papers, etc which were very good. Not so today. This one isn't too bad.
                              https://www.google.com/url?sa=t&sour...xVLfcnptIj07JJ
                              This one is a bit more advanced but looks good. Haven't read it yet. Maybe tonight. https://www.google.com/url?sa=t&sour...E6sCoXWgPm-i63
                              • Just a little update, ya'll can see where I am going with this.
                                https://youtu.be/ghMriKx8tQY
                                I'll post incrementally as I get little things on it together.
                                Lots going on this week but I am going to get it up running by next weekend.
                                Matt
