Info
bi,
I’m on the road to AZ. Will look at my Amazon purchase history when I get there this evening. That’s the only way I have of giving you a link or part number, and even THEN it will just be a guess. I have purchased probably close to a hundred different boost modules trying them out to see results. If you want to wait until I get back home next Sunday, I can look at the setup that is on my bench right now, but I am pretty sure it is Drock, and they are also current limited. Zahn are probably the best and you would only need one because they are NOT current limited. Expensive though. There are at LEAST three people out there who have built this and have it running with POSITIVE results. If they want to pop in and link to which module they are using, that would cut down on your wait time.
It won’t work for you with a stock motor. It MAY work if you pulse it with a 555 timer. Matt’s motor pulses at the right frequency, the dual boost modules give you a higher amp output and the higher voltage necessary to act as a “battery charger.” All the system does is recirculate SOME of the energy, running it through the motor to give you mechanical work while charging the battery.
The ONLY purpose of the generator attached to the motor and a load attached to the generator was so that solid measurements could be made. Run the motor/ generator combo straight off the battery until the motor stops because the battery runs down and see how many watt hours went to the load with a simple watt meter.
Then run the motor/generator combo on the circuit and see how many watt hours went to the load before it stopped working.
It was always about testing the circuit with the motor as a load, as ALL our past experiments have been. That’s why your data about how long the light bulb would run just made me shake my head.
bi,
