Didn’t work.
The link didn’t work,anyone interested it does on this thread.post 21.
* * The Universe from Nothing: T=0K. / by*Israel Socratus /
Thanks to Socratus.
John.
3 Battery Generating System
Pinched.
I borrowed this from another thread.
The boundary must be clearly defined, so one can clearly say whether a given part of the world is in the system or in the surroundings. If matter is not able to pass across the boundary, then the system is said to be closed; otherwise, it is open. A closed system may still exchange energy with the surroundings unless the system is an isolated one, in which case neither matter nor energy can pass across the boundary.
https://courses.lumenlearning.com/in...hermodynamics/
John.
Balance
You can always put a load on battery 3 to draw it down and maintain the potential difference.
If all 3 batteries are staying up, you should still have a potential difference. Not sure I understand the problem.
Originally posted by Iamnuts View PostProblem thought : how to keep a potential difference and thus running the load when all batteries are topping up at 14.4 volts?
Jeepers now yous have got me wondering if there is enough energy stored in a generator coil, while on it's approach to tdc, that if released in a timely fashion, could neutralize the magnetic attraction that caused it. If so that looks like an imbalance of force that could play out favorably.
Silly Season.
Originally posted by bistander View PostI don't know what you're talking about.
biLast edited by Majestic81; 11-18-2018, 08:59 AM.
In a word...
Nah. Not gonna show you anything.
I take that back.
I will show anyone ANYTHING they want to know about how to build the generator the best way I know how based on having built like 13 different versions so far.Last edited by Turion; 11-18-2018, 04:15 PM.
The system does in fact give extended run times. However I am not sure if you can truly take any battery's stated storage as fact.
-Altrez
You're making the claims
Originally posted by Turion View PostWhen you prove to me that you can turn a rotor with 12 one inch neon magnets on it with a small electric motor past 12 generating coils with over a thousand feet of wire on them as YOU claim you are able to do...(since you have said speed up under load and magnetic neutralization make NO difference) I will drop everything I am doing and prove inputs and outputs. But I already know that youCANNOT, because such a setup would stop your motor DEAD. The difference here is I have already built this stuff, and you are just talking through your hat.
I am just calling you out. Anybody who is skilled in the field and knows what they're doing can easily see you don't know what you're talking about. I am not making claims of incredible performance. Just stating accepted scientific facts. I have nearly 200 years of proof behind me.
Again, why would I build something I know won't work? You make the claims, you need to prove what you claim. You can't, so you just double talk about irrelevant things.
Show us the 1800 watt output/300 watt input generator.
Originally posted by Turion View PostMajestic81,
If all batteries are holding voltage you just need to put an additional load on battery 3 to keep it pulled down and maintain your potential difference. Figuring out HIWMUCH of a load will be the problem. Too much or two little and it goes to pot. You have to balance everything.
I am awaiting my 12AWG wire order before upgrading to larger loads.
Here is a showcase of the battery sequencer board cycling when the source battery goes below 11 Volts.
[VIDEO]https://www.youtube.com/watch?v=XakAbwHZnqk[/VIDEO]
Problem
Majestic81,
Deal
When you prove to me that you can turn a rotor with 12 one inch neon magnets on it with a small electric motor past 12 generating coils with over a thousand feet of wire on them as YOU claim you are able to do...(since you have said speed up under load and magnetic neutralization make NO difference) I will drop everything I am doing and prove inputs and outputs. But I already know that you CANNOT, because such a setup would stop your motor DEAD. The difference here is I have already built this stuff, and you are just talking through your hat.
Hi All,
I've setup the sequencer board in a 3BGS configuration using 12.8V -10A LIFEPO4 on 6 x 12v - 40A relay's.
As load I am using a 220V inverter with a boost converter before the load at around 24Volts.
I am able to run a 5W to 60W load on it.
I am awaiting AWG12 cabling before I will upgrade the load further.
