3 Battery Generating System
  • aljhoa
    Search for:
    CZH-LABS Electronics-Salon Low Voltage Disconnect Module LVD, 12V 30A, Protect/Prolong Battery Life
    Cole Hersee 24200 Latching Solenoid
    Al
  • energybat
    Hi To ALL
    My name is Geoffrey Miller I have a lab called Energybat Labs, see link below
    I have followed you Dave & Matt from the being Great work !!!.
    The people the don't understand the tec shown on this website have not built anything.
    Energy Bat
    I have a new product that you guys might like, it is a BATTERY SWITCHING BOARD.
    This circuit board was designed by Energy Batlabs & Magnetic Impulse Tech Group LLC to allow for the switching of battery banks in your DIY energy project. This board provides the logic to be used with relays which will allow you to charge one battery bank while utilizing another during continuous operation.
    Please go to my website for all the info. See pic below
    Have fun
    Geoffrey at EBL
  • Majestic81
    Turion,
    Finally, goodbye!
  • ilandtan
    Matthew, Dave and All,
    Hello from Japan near Nara and Osaka.
    Still checking in from time to time and see how the research goes. Sorry had to stop everything and focus thoughts and life toward our mission for Japan. As we travel here the rooftops of many homes are covered by solar. The government here installs solar free and sends you a decent check monthly for grid connections solar energy production. Imagine they had a super large 3BGS in each community or homes. Wife's sister operates large Day Care center spread over 1 acres plus 3 story residence. All completely solar powered and gets $400 check monthly from government.
    Keep up the good fight my friends and will see you all back home around the first of November.
    Take care,
    wantomake
    We don't need Solar in the US, we can just open more coal mines and dig for oil on our conservation lands! We can drive our huge SUVs and crew cab trucks that get 9 miles to the gallon. That's what being "great" means.
  • wantomake
    Still looking in and hope all is well
    Take care,
    wantomake
  • Turion
    We showed what can be done with the 3 battery circuit and the reason for a PULSE motor. We also showed how a boost module can benefit you. We showed a single battery circuit. Your success depends following the basic rules, like BIG wires and BIG batteries and efficient boost modules and pulse motors. After that its up to you. Our hope was that people would see success and branch off into discovering things on their own and sharing their results. I get emails almost every day from people who are doing JUST THAT, and are NOT participating on this forum because of all the crap they would have to put up with here. I would never disclose someone's name without their permission, but here are two recent (within the last few DAYS) emails I have gotten.
    __________________________________________
    Speaking of charging, in the first setup where I ran the motor just using the left side of the one battery system, I put a pair of parallel 12v 9AH SLA batteries (bat 2) in place of the motor.
    Before the test, the resting voltage of the primary battery (bat 1) was 12.52V and the second (bat 2) was 11.5V.
    Connections:
    Boost in pos to bat 1 pos.
    Boost in neg to bat 1 neg
    Boost out pos to bat 2 pos
    Bat 2 neg to bat 1 pos
    After running an hour or so and letting the bats rest for a while I measured the bats again.
    Bat 1 resting 12.55V (.03V higher than before the test)
    Bat 2 resting 13.47V (1.97V higher than before the test)
    So from a resting voltage perspective, I charged bat 2 for free and even gained .03V on bat 1 in the process.
    I am going to have to pick up a battery capacity analyzer to see what is happening with the batteries.
    What would COP be of that? Infinity?
    __________________________________________________ _____
    Both boost converters are connected across pos and neg of their sources. The first one could be hooked up between the positives of the three battery system.
    I am running just the left part of the diagram. The boost converter is hooked up to the battery, set to 26v with the out of the boost going to motor pos and motor neg going back to pos of battery. The battery was sitting at 12.5v before I started. When I turned on the boost and the motor started running, the battery dropped to 12.2v. After running for a while the battery climbed up to 12.29v and is just sitting there. There is 1.08A flowing from the bat pos to the boost in pos and 1.07A flowing from boost in neg to bat neg. The voltage across the motor is 13.71V and it is drawing 0.7A. What is blowing me away is the battery is just sitting at 12.29V and I just saw the meter bouncing back and forth between 12.29V and 12.3V. I am going to let it run like this for quite a while to see what it does. Oh, now the meter is reading steady 12.3V. The load on the battery by the boost converter is almost exactly the C20 rate of the battery. Wow, all I can say is wow.
    __________________________________________________ __-
    somebody should tell all these people who are sending me emails that this doesn't work. Of course THEY have a setup on the bench, built correctly, and can make their own decisions about what works and what doesn't.
  • Aaron
    i've seen it
    Originally posted by bistander
    I apologise. Objectionable comments have been deleted from my post. I'll delete this post after you've had an opportunity to see it.
    I've seen it - thank you for understanding.
  • Aaron
    leave this thread
    It's just an example. But here you have have a big name FE researcher making a presentation at a major FE conference and can't even get it to work. How pathetic is that? Oh, and then sell video books on how to do it. Like "send me money and I'll tell you how to fail". Sound familiar?
    You're out of line with your mouth and your attitude.
    Peter and RS (who had a battery bank over 1000 pounds) both showed their own variations of the 3 battery concept at the conference for all to see and more work was done than the net loss from the battery bank.
    The Benitez presentation was to show the principle of the circuit with a super low budget and low tech method to operate that switching concept. Peter was using the cheap Walmart starter batteries, which are about as crappy as you can get and they still nearly kept themselves charged up.
    Pointing out that Peter couldn't get it to self run and admitted those batteries won't cut it doesn't show a fault in the circuit or its concept, but in your own ignorance of knowing how to distinguish what is or isn't being said. All that shows is those particular batteries happen to be garbage, but it still showed the point.
    What David and Matt has been showing here for a long time works whether it is their exact variation or not and again, RS and Peter showed this at the conference for all to see.
    Where is all your documented work to show that you have applied exactly what they have taught? If you don't have that, you have no room to talk and need to get out of this thread permanently instead of disrupting it with your ignorance.
    You're welcome to start your own thread and post why you think all this is nonsense. Harassing them here is not going to happen any more. It isn't what you are saying, but how you are saying it and it has to end.
  • Turion
    Fun times
    Werner,
    Don’t worry about me. I’m fine. Not wound up at all. Just seeing how far ol’ bi was willing to go with his claims that I am a liar, and fraud, that I have led people on purposely for some supposed gain of some kind and that this is a scam.
    He thinks he’s anonymous, so maybe he doesn’t realize that when I file a lawsuit for libel and defamation of character I can have the info he has provided to the forum subpoenaed. If no one knew my real identity, I would have no grounds, which is why I’ve taken the trouble to make it very clear that MY identity is known. . I’m pretty sure I know some folks with the tech skills to track him down. Even a frivolous lawsuit will cost him a pile of money to defend against. He can’t afford that. He can’t even afford the right sized batteries to experiment with according to him.
    Of course I might have to wait until my other house sells before I can do that, and I might need advice from someone in the legal profession. Oh wait, I’m married to someone like that.
    Anyway, thanks for your concern I know what I’m doing.
  • wrtner
    Bi,
    It is clear to everyone you aren’t man enough to come out into the open and attack me man to man.
    You shouldn't get so wound up, Turion. We all know your reputation. There is an old saying - Confucius may well have said it: - "Don't feed the trolls".
  • Turion
    Opinion, opinion, opinion
    Bi,
    It is clear to everyone you aren’t man enough to come out into the open and attack me man to man. Instead you’re going to keep hiding in the dark where you have no responsibility for your words or actions. You’ve shown yourself for the coward you are. How was that? Juicy enough for ta?
  • bistander
    Bye
    Turion,
    Yes, I said I'd leave but never promised never to come back. And Matt tricked me to post right after a said I would stop posting, so I admit I told an untruthful thing, but not an intentional lie. I used to think you were just misinformed and actually believed what you were claiming was true. But over the course of the months, or maybe years, I've come to realize you could not possibly be that dense, so you are, in fact, perpetrating a scam of sorts, intentionally misrepresenting things, stating falsehoods and yes, lying about things on purpose.
    You want the last word, take it. Make it a juicy insult towards me because I dare to challenge your BS.
  • Turion
    Don't reply????
    bi,
    One AGAIN you ignored your promise to leave here and not come back. I think besides having broken your word, that also makes you a liar. Don't reply and neither will I??? LOL. So you get the last word on a thread I created and have dedicated years of my life to? Not happening little man.
    All I have is BS and insults? Not! Actually what I HAVE is a working machine. What you have is your arrogance and stupidity. You don't know NEARLY as much as you think you do about what has been built, what works, and where things are headed. Still too much of a coward to give us your real name? I thought so.
    So I'm a liar and a fraud and you are an ignorant coward. Glad we've got that straight!
    Iamnuts,
    There is a working Tesla switch based on the Benitez patents that has been running not for hours or days or even weeks or months, but for years the last time I had good information about it. It is NOT mine to share, but because the work I have been doing is so similar, I was "allowed" to know about it. That was some time back, so it may NOT be working at this time. I don't know. The Benitez stuff works. BUT NOT WITH TOY BATTERIES.
  • Iamnuts
    Readings.
    There's no need for tests, meters and readings. Just let the thing run, if
    it goes for, say a month and shows no sign of deteriorating performamce
    you've most probably got something.
    Actually proving something with measurements is horrendously difficult, especially in these sorts of situations.
  • bistander
    You have called us liars and frauds, insinuated that all this is done to possibly sell something. ...
    The lies and fraud were there in print in your posts. Insinuation... not. Matt certainly offered to take money from me in writing. You? You're selling something, maybe not for money, but selling a line of BS nonetheless.
    Again..... All I ask is proof of your claim.
    All you have is BS, and insults.
