Latest Circuit
Post #3931
This is the circuit we have been talking about for a couple weeks now at least. But it only requires ONE battery. If you HAVE more batteries than that, just put them all in parallel. If you don’t remember what we said about the wires when using parallel batteries, you have some reading to do.
3 Battery Generating System
Hi Altrez
Here is the basic one.Attached Files
I was wondering is someone could please post the most current schematic of the 3bs with boost converters?
Thanks!!
-Altrez
Boost Converter basics
https://www.elprocus.com/12v-to-24v-...r-using-lm324/
I'm pretty sure Matt knows of much better tutorials.
Originally posted by liber63 View PostYes, it's really very exciting. I knew the truth of that by reason, having done similar experiments but not with the right stuff. Now I see it with my own eyes. Nobody can take that from me.
One more thing, I was wondering if all this experiment would do better if the voltages for all was higher, say 24volt for the batteries and 40 for the boost or even 36 for batts and 52 for the boost. I think it's been said here before. Of course, there is no need for that really. Maybe it becomes more complicated.
With my previous setup, I had the batts before start around 12.80 and the boost at 29,2volts, if anybody is wondering.
Thats one thing I want look at building specifically for this experiment, so we can get plenty of current without worrying about exceeding the parameters of the converter.
MattLast edited by Matthew Jones; 08-01-2018, 08:22 PM.
Higher voltage
One of the biggest losses in the system you have to make up for is the boost modules, and they are MORE efficient at higher voltages. But high voltage DC is deadly, so there is always that risk when you get TOO carried away. And we were trying to show an inexpensive system that WORKS and proves what we have been saying. I’m not going to talk about something I have not run myself. Matt has done way more work running on potentials than I have, so maybe he will comment. All my time has been devoted to the generator side.
Originally posted by liber63 View PostThat's the second time I try the 2 batteries setup, this time under load, after Dave's advise. My batts are fairly new one year old, 74Ah each and so I have 2 parellel on each side.
I used the small boost converter but in less than a minute I burned it. Then I used a 400watt one which was volt and current adjustable. I confess that being afraid of burning this convert as well, I didn't open completely the current. Also trying to be on safe I put small load also on the generator attached to motor, counted it and was 10watts. So I didn't follow the advice of David to the fullest.
The motor had to use around 35 watts to keep the 10 watts on the gen. Run it for two hours. 20 min on, 40 mins off, few rounds totally 2 hours. Then left them to rest. After 30 hours the two group of batteries where all higher. 41 hours later both are still higher than started. One is 0,02 volt and the other is 0,05 volt. Totally, I used like 70wh and still all 4 batts show gains. I wonder how much better could it be if I had not limited the current, if i have used deep cycle batts instead of car batteries and the modified motor would not get that hot.
I think also the effect is improving by the long intervals in between runs.
Relatively small loads but still clearly shows the potential. Doesn't it?
https://www.youtube.com/watch?v=iyoJ...ature=youtu.be
Your equipment is quality too, big batteries, big wires everything thats needed to make it work.
The only advice is no matter the explanation thrown at you keep your eye on the ball and keep your mind open, keep looking. Don't discount anything.
If you find an effect and you can modify to make it better then your on your way.
I am really happy for you. I know how good it feels to watch stuff like this happen. Contrary to what the "Facts" say.
MattLast edited by Matthew Jones; 08-01-2018, 08:24 PM.
Reality
liber63,
Once you have built it and seen it working on your own bench, it becomes more difficult for people to convince you that this doesn’t work. The proof is not in how much voltage or current moved from here to there. The proof is in the batteries. As you run this you will see increased capacitance in the batteries, and that they do not lose their charge. How is that possible when you were running loads the whole time if there is “Nothing to this”
Now you know it works. Don’t let anyone tell you it doesn’t just because they believe they are experts. Go slow and keep good records. I found that a battery analyzer is a pretty important tool to give me good data as I experiment with different circuits. At times I found my voltage might go down .01 volts during a run but the analyzer showed the capacity of the battery had gone UP, meaning, when you do the math, that it would actually hold MORE power. Resting helps these changes take place.Last edited by Turion; 08-01-2018, 02:28 PM.
To All, Norm and Bi
https://www.youtube.com/watch?v=iyoJ...ature=youtu.beLast edited by liber63; 08-01-2018, 10:44 AM.
Never said that
Originally posted by Matthew Jones View PostPost# 4047 clearly said MATT is lying, but has since been changed.
Originally posted by bistander View PostHello Altrez,
PWM motor controllers are buck converters and operate efficiently employing current multiplication through a freewheeling diode. Matt is incorrect. They do not waste 50% of the power at half voltage. Please don't believe me and look up buck converter or PWM DC motor controller.
I burned my power supply up running them, LOL.
The important thing to learn from seeing this, is the effect. If the effect can be modified then its real. And sure doesn't hurt anything in my ballpark that when the voltage went up in the power supply the motor went faster, even though Tinman and Gotoluc didn't include that in there video's and the Bisexual wants to come up with some excuse. Regardless of what anyone wants to call it its a good thing. If it can be modified to work better its starts to get into what we want, a little bit more for a little bit less. I never said everything was perfect but it leaves room to get better.
I am really grateful for those are trying, I apologize I am continuously targeted by these people who pretend to know it all and want you to ignore what we find. I am going to do my best to get all out this time. 3 years we have been trying when we have time and 3 years we've been asked not to. Not this time. Stay Tuned!!
MattLast edited by Matthew Jones; 08-01-2018, 09:18 PM.
I cant speak on using a power supply to run theses tests however I can say that I am going to run theses tests to a battery and will post the results.
I do not like videos that use a power supply because battery's behave differently. My tests are coming soon using the Matt motor and a battery. Lets see what happens in that setup!
-Altrez
Yep all talk, no proof....No physical proof, no text book reference no credentials, no film, no nothing. Just made up lies to clutter the thread. Your dime a dozen, and everyone see's it.
Post# 4047 clearly said MATT is lying, but has since been changed. This is typical and I just got telling David, "Next he'll play the victim". My insulting language...LOL All of you must have one game plan. I know its shameful but your gonna have to go back to BRO MIKEY and get some advice, he's the best disruptor there ever was.
Soon you'll realize how bad you failed.Last edited by Matthew Jones; 08-01-2018, 02:34 AM.
