3 Battery Generating System
This topic is closed.
  • Ya its the spikes. Your having the same problem Dave had from running the motor.
    Give me a day or 2 and I'll have a solutions. I gotta better switching arrangement.
    Matt
    • Hi Matt
      That MOSFET the one 250v and 50A is too small I am not sure that it's 50a 250v although the specification said it is 50a 250v this is the part number for Digi-key
      IXTP50N25T.
      I have noticed that the cap is charging although I switch off the primaries and the battery power the stamp and the driving board I think the short leading to charge the cap but how the cap discharge the small battery?
      I should make a switch on the positive of the battery that power the stamp and the driving board so when I don't make test I switch off the battery and there will be no short go to the cap because I think that the cap which discharge the battery !!!
      I think it's a good idea for now untill I will find the short .
      Ehsan
      Take the wisdom even from the mouths of the insane
      • I'll tell ya what...
        Check all the lines in your transformer for continuity.
        Set you meter up. Grab one line and check all the other to see if any of them are connected.
        If the serial battery is OFF no power should flow even if you have a short. Unhook the serial battery and see if the caps still charge up. If thats the case your caps are charging naturally, no short.
        Also PM me your email so I have it.
        Also that fet will work for a cap dump. Put a heat sink of some kind on it.
        Matt
          Matt
          Hi Matt
          I put the serial battery OFF there is no power at all but the cap is still charging it was 8v befor I discharge it to 0.00 and now it's 0.65v after 2 minutes so I think it's charging naturally I don't think there is no short but I am still checking .
          Ehsan
          • Ya this happens. Especially with new caps. The scalar or radiant charge conditions them to absorb environmental charges. I have some caps that will climb to 40 volt or better after running on a given machine for period of time.
            There is thread somewhere called "self charging capacitor". You search it and read about the effect.
            Matt
              Matt
              Thanks Matt I will look for that thread
              Ehsan
              • 3 batteries with a SG
                Hey Guys,
                I am sorry if I am stomping on the current theme of this thread, but I refer back to the beginning posts. First, my expertise. Nada. I’m a good builder, but I know little to nothing about electronics and can read schematics and that is it. I am a fanatical tester. Now, here is issue/finding.
                Dave, I used your original block diagram with a different twist. I replaced the motor with my SG. For a load I used a 2k inverter. The “Bad Battery” is a badly sulfated battery that will not hold any charge for more than 3 minutes. I took the – of the invertert to the – of the bad battery as diagrammed for the load.
                History on that battery-I have tried for days to rejuvenate that old battery with my SG. The most I could get it up to was 14.85 volts and then it would drop down to 12.18 and hold there during charge. After taking it off the SG it would lose it’s charge to 10.85 in about 3 minutes and hold there. So I decided to use it for my “Bad” battery.
                I just fried my 2k inverter . I did have a meter on the inverter connection before it toasted, 18.96V in series with that “Bad Battery”. What the heck? I switched on the inverter(no load and watching my meter), it went into alarm(beep), then went silent. Back to Harbor Freight for a new one and new test. How do I safeguard the next inverter so I don’t toast it with this unexpected power? Thanks for any help here.
                Randy
                _
                • Originally posted by tachyoncatcher View Post
                  Hey Guys,
                  Randy
                  If it was good inverter it would shut off at 15 volt or so. Over Voltage protection.
                  Matt
                  • Cheap
                    Yeah, It was supposed to. I think there may have been volatages that my cheap-o-meter did not pickup on. Also the direction say to hook this lead first then then that one last and a spark is normal. Tells me there is electronics in front of the power switch.
                    Not having any electronics experience, I don't know how to restrict the system to 15v for the inverter. I thougt the dead battery would do that since it would max out at less than 15v when trying to charge it. Stupid is as stupid does.
                    I'll throw some 12v bulbs in parallel first to see if that will draw down the voltage, then hook up the inverter. Something different is going on here. This unit has been cold charging just fine for a couple months. Wanted to see if the Tesla Switch configuration would make any difference. It does. After looking over the Tesla Switch patent and a block diagram of the SG, I saw similarities. Just some things missing. Wouldn't it be a hoot if all we needed was a tap into the radiant and the TS configuration to pull it through? In other words, your device, JB's devices, DS device or the many other oscillators out there with the batteries, are the taps and what is needed is the right configuration which has been discoverd over a hundred years ago.
                    Randy
                    _
                    • Randy,
                      Other than blowing up the inverter, it sounds like you are on an interesting track with those components. I know how it feels to blow an inverter. I couldn't tell you the number of inverters, regulators and mosfets I have toasted over the years. But it sure is fun!!. I have my basic 3BGS back on the bench to play with while I am doing some other things. Now that I finally have my shop organized I have room for four different builds at the same time, and that's what I have going on. Never a dull moment. Good luck with the direction you are taking. You never know!!!
                      • Voltage
                        366v hmmm, I thought that bigger coil might help speed up the charging. It did. Now I know what happened to my inverter. I need to tame this puppy before I toast another one. This dead battery does strange things. Does anyone have any theories as to what the dead battery emulates?
                        Randy
                        _
                        • Hi
                          I am new to this thread and have years of experience with auto batteries and a degree in electronics. I have been studying this thread and emailing Trunion and there a couple of things I might be able to add that might help. One thing when recharging a dead or damaged battery the charge cycle will be different for each depending on what is wrong with it. One thing as I understand what you are doing is using battery #3 as a ground for your run motor. A battery that doesn't have much wrong with it except a real low charge will appear to take a charge very quickly and will quickly try to match the in put charge, but this charge is just what they call a surface charge and will dissipate with out a load in a fairly short time. When a battery loses 70% of it's charge it only drops 1 or 2 volts through the rest of the discharge it loses voltage very quickly. When charging things are a little different... if charged with a high voltage it will charge to a few volts under the max charge level, but it takes an hour of medium or low charge to maximize the charge to a real full charge. Using the good batteries for the run is a good idea, but you need a more reliable linear and predictable ground or electron dump. An appropriated sized cap bank would be better. I have a lot of ideas regarding the use as I worked on a similar system 5 or 6 years ago.
                          Will discuss more later got to hit the bed right now
                          Later
                          Larry
                          • Larry,
                            I talked to Luther about this today and both of us are going to resurrect our basic setups again and try out some of this. We are also going to keep working on the setup Matt has come up with as well as keep working with what UFO has been showing us. It all relates, and from all this good information we feel like the answers are slowly emerging. The three battery setup (the original) is so simple I just CAN'T leave it alone...not knowing what I know and having seen what I've seen. So jump in with both feet and let's see if we can figure this sucker out.
                            • I always was interested in original setup. For me it would be better even to divide this thread into two separate but related topics.
                              Just me 2 cents (or 2 grosze in Poland )
                              P.S. Please forgive me , I don't want to harass this thread with my personal offtopic opinions. I'm not this kind of "paid shills" , rather frustrated man who has 1000 ideas in mind while even one is difficult to realize :-( (being "short on everything" if there is such idiom in English ;-) )
                              Larry
                              Please if you would like to answer : what is the reason for battery to become discharged ? John Bedini always stated that battery is a perfect kind of the "dipole", so it should always maintain required voltage level in my opinion....
                              Sorry for my funny poor English language.
                              • I sent Matt an e-mail about that just a few minutes ago. I have had a lot of PM's asking me for the same thing. Seems there is a lot of interest in just the basic setup and seeing where that can take us. So maybe we will do something like that.
