JJUK,
The basic setup from the first post remains the same. We have gone down other paths since, including using caps instead of battery three, diodes in different directions in parallel with battery three, circuits that pulse the motor, etc. I built a UFO designed motor from a razor scooter motor and got AMAZING results for a couple days...unlimited power output and charging on my primaries at the same time, but then that effect went away. So you really need to follow the directions in post #1 to get a basic setup running so you can see for yourself that this works, and then go from there. But replacing battery 3 with other things hasn't seemed to work more effectively...at least so far.
You can get all kinds of incredible things to happen with the original setup, but the minute batt #3 gets charged beyond a certain point, all those amazing effects go away. I can ALWAYS run large loads off of batt 3 for short periods of time....no longer than about 20 minutes, and then my primaries will recover from whatever point they have dropped down to...eventually reaching a full charge again and usually a bit higher than where they started. But a system that only works for 20 minutes at a time and then needs 24 hours rest is no good to anybody. They key remains a bad AGM battery in the third position and somehow keeping it from charging while it still remains in the circuit.
Look at post 1384 where I show VIDEO results from running the UFO motor or ANY pulsed motor (it turns out).
Look at post 1416 where Matt shows the circuit for pulsing a motor
Look at post 1435 where Matt is talking about the results he's getting USING that circuit and why it works and then quits working.
That will give you the most up to date info that has been posted here. BUT
all kinds of different things that people have done here have produced positive results. I would pay special attention to Matt's posts and the videos he has shared. He has had some successes. So there is a lot of really good info to be found by weeding through what has been posted here, and some combination of different things that have already been tried MAY produce a solution.
