the zone
Hi Dave and All,
Just to let you know am still testing
I have replaced the motor with transformers and am running a 300 watt inverter ,off of a bank of super capacitors (dead battery replacement)
The inverter in turn runs a battery charger, which replenishes 1 good battery
Battery #2 which is parallel, never changes in its' charge, regardless of drain I put on the setup
I can kill it with too big of a load
I've noticed in test runs there seems to be a certian point of balance,..
Go to far one way it dies, or go to far the other way it dies.
I found by disconnecting at just the right time , during charging, the circut seems to sustain itself
It seems the zone only lets you have so much,when you reach its' limit ,it shuts you down, then when you drop below its' lower limit ,It opens back up.
Once shut down you have to restart by distorting the input to get it going again.
more tests yet...shylo
Hi Dave and All,
