fixed ... maybe
all that is required of the PMH is just as shown David .. all it has to do is react as whyme2be portrays with another magnetic field .. probably no bad batteries will be required …. the impedance match to the load battery can be huge . The motors job here is in theory at least just to supply a variable frequency supply. Unless In some way we don’t understand yet the magnetic core of the motor has a part to play. If it does pan out as I describe then its really very close to the end of this game …
It is the bit Orion suggested "I fix" .. I think you'll find if not the fix, its very close, its got to be considered, tried , engineered but the bits seem to fit .. the impedance match to the bad batteries could be made huge or adjustable and perhaps the concept of “bad batteries” removed .. just very high impedance match with a good battery at resonance .. that would be my hope and I think its also possible the motor may be replaced with an H bridge .. we'll see soon David It'll have to be tried I'm sure Orion will grasp the concept pretty quickly if he's not in intensive care. It is going right outside the square .. go through it again and see if it starts to make a little more sense I have perhaps not described this well enough .. Its actually outlining a fully functional system based on this system .. and a few others ..the PMH .. I have simply included because it gives visual proof that the concept works …
and I thought it would give most folks a solid known effect to work from
