3 Battery Generating System
  • Well No circulation of air can contribute to heat build up as well. Nice little box, but without a fan to concentrate the flow of air, completely useless.
    Come on wake up!!! Its not magic!!
    • @Turion,
      I agree, I was not expecting such high current draw... Curious, the voltage from B3 did not goes down I was expected as such big current draw. Anyway, in 4 hours, the loses in all 3 batts are 0,15 volts, but gaining in B4 are +0,21 volts, and the LED light is, also, a bonus. The REMF charger, still, can be improved...
      @wantomake,
      It was just a simple test, at the end of the day. I still have to order my motor, and in the meantime, I just play with what I have around me. I will try to switch batts manually, and in the future I plan to do that with Arduino, for the beginning, with relays.
      @Matthew Jones,
      As you said, it is a nice box, but the main purpose was to easily use it with jacks and big wires in my setup. I was not really expected to go so warm... lesson learned, though.
      Anyway, what do you think about using a axial flux gen. as generator in 3BGS?
      I think it can be done with not so much cogging, though my first setup, from another project, is quite hard to rotate by hand with a car bulb as load... open voltage is 62 volt, with rotor rotated by hand... I did not tried to test it on high speed, to see, what is happening when loaded...
      Best regards,
      Teo
      • Looks good
        Originally posted by axxelxavier View Post
        @Turion,
        @wantomake,
        @Matthew Jones,
        Best regards,
        Teo
        Teo,
        Sorry I wasn't trying to down play your setup. It is very good that Matthew and Dave both gave you some pointers.
        You keep replicating go forward no matter what. There are many more surprises coming. The idea is to get the 3BGS to balance. Meaning don't drain primaries B1 and B2 while charging B3. The balance between Primaries and Charge, or High and Low sides. If you boost the voltage back to primaries and keep them charged, then adjust the second booster attached to the motor which keeps the potential difference from dropping too low. For myself that is how I balanced the system.
        My first testing used no boosters but only had the my1016 modified Matt motor and I saw good results. But the primaries would lose voltage. I added the boosters and saw the "balancing" Matthew and Dave posted about.
        What is that axle flux generator? Take some more pictures from side and such looks interesting.
        But build and learn is best classroom. I pestered Dave and Matthew but as they stated if someone builds then they would help.
        Time to nuke the coffee,
        wantomake
        • @wantomake,
          Thanks for your reply. Axial flux generator it`s mostly used for eolian energy, and there you have thick steel discs (acting almost like a flywheel - for BIG generators, like mine), and different number of magnets and coils, for minimizing the cogging. Here is some simulations. There are users on eolian forums which have versions of those generators made with tesla coils, with low drag. Of course, this information is missing, but if you put all the pieces together, I think you will have a surprise.
          I believe this axial flux generator made with multistrand coil in series it is the winner in conjunction with 3BGS system + arduino control. You will not have to break magnetic lock to 20+amps, just let it run to speed with no load, and then hook up the load. So far, my coils on this generator are wounded in classic style, so there is some drag, but I have to test is further at higher speed. I will make some tests, also, on a smaller version, so much cheaper for making coils and casting the stator in resin...
          All I need now is the motor, so here is my question: which version should I order, 24 volt/350 watt or 24 volt/500 watt?
          Best regards,
          Teo
          • I have a 350 watt version, but it has more windings.
            I would have to go back and measure the ohms, but the OHM's of resistance you want.
            Does anybody remember that number so I do not have to take a motor apart?
            Anyway You can use any wire size as long as its like 1 ohm or something and any motor size granted the motor can handle more footage of wire so as you stack up the wire you are looking for like .8 to 1 ohm. I can't remember the number.
            If you use a 350 or 500 you have to use a little bigger wire or more strands, something like that.
            Maybe someone will measure the resistance of the windings and remember how many strands of wire.
            https://www.cirris.com/learning-cent...lculator-table
            Here is the resistance of wire calculator.
            • Per your email
              Matthew,
              Your e-mail said 24 awg with 3 strands at 100 feet each. But I can't remember the ohms for each coil. Also you stated 1.3-1.5 amps to turn the motor.
              Sorry I will dig more through my notes(4 or 5 notebooks full) to know for sure.
              wantomake
              Edit:I just opened up my motor and the ohms is 0.4 ohms. I did minus the ohm reading of my fluke meter connectors. But I do have same reading across both coil windings. I did wind each side 40-30-30 turns. But I have the smaller 250 watt my1016 24 volt.
              • Originally posted by altrez View Post
                Warning Warning The fallowing statement is my opinion based on my own tests!!
                I feel there is defiantly OU potential here. I have done tons of tests across all types of batteries and one thing that I can say is that I personally believe to be 100% true is the battery manufacturers are for some reason either misstating the true capacity of the batteries that they sell or just do not believe anyone will believe that they can be reused over and over but also become much more efficient over time.
                I can run a load just off a very basic setup when tuned correctly 35% longer then I can in a normal configuration.
                -Altrez
                I deleted my post because I thought it was unproductive.
                Repeating for most people already familiar things. And nothing practical.
                I guess when someone makes a claim, he probably knows what he's talking about
                You put it back again. Didn't have to. But anyway, okay.
                regards
                • Redesigning
                  Still in process of redesigning the Dave upright generator.
                  As far as the coil core go, trying to decide to mold some magnetite with resin. Or go the acid route then compress somehow.
                  Many things to work out as per instruction from the original.
                  Coffee is getting cold. Time to nukify it.
                  wantomake
                    Teo,
                    wantomake
                    Here are some more pictures. There is much to be done on this generator, and soon I as will completely recover from my surgery, I am planning to change the bearings with high speed versions, and to connect the generator to MY1016 motor, at the beginning in stock mode, and after some tests, in Matt / Dave mod. I still have to weld a platform, to make some room for motor...
                    But I have to take care, the disks are quite heavy, and can`t lift more than 7 kg (15 lbs) - not to mention the huge magnet attraction (very, very dangerous). That`s why I will test first with a smaller version, easier to mount and less expensive for copper wires and resin.
                    Best regards,
                    Teo
                    • Two,
                      If the metal framework you have there is aluminum, you are going to have an issue with rotating magnets/aluminum/eddy currents.
                      Chances are, the magnets on both sides of the coils, as you seem to have, is overkill. The core material will only absorb so much magnetic flux from a passing magnet. One of the reasons why I have built eight different versions of the generator with different rotors and different magnets was to establish what was NEEDED to get max performance. I’ll be interested to hear what your results are.
                      • @Turion,
                        The disks are from 15 mm steel (0,6 inch) and the frame is also made from square pipe steel, so imagine how heavy it is...
                        This is not my invention, I made only some small mods, where it matters Actually, my project was to use this generator for a domestic purpose, but after the surgery, I have to wait a little bit. Actually, a little more.
                        This kind of alternator is usually made for eolian generators, rotor with square or rectangular magnets, and coils wounded in star or triangle connection. I`m quite surprised you don`t know about this.
                        Nevermind, HERE and HERE you can find some good video tutorials about axial flux alternator, and HERE is a translation of a forum I am following for a while. There you have first class info!
                        HERE It`s a video of my generator with a 30 watt car bulb hooked to a trifazic bridge (i think it was 30 watt, I will check later).
                        L.E. - The car light bulb is rated 55/60 Watt, so I think it was hooked up at 55 watt filament. It will be fun to test with both filaments in paralel - 115 watts...
                        There is much more to learn, I don`t know if this is a better solution, but at least this is the path I am going to go, at least for the generator side. I have to test at least 3 different stators, and one of them I think will be just enough for 3BGS system.
                        All in time, as I am running out of founds and time, so I am waiting for the time I will be able to dismantle the generator, to weld the platform for the My 1016 (which I am going to order tomorrow), to see it working at high speed. ALL the materials are expensive, the magnets are 15 mm thick, and for the wire, I think I used here at least 5 kg of copper for coils, and so on. I think you know better, about the „free energy”, which cost real good money...
                        Anyway, I will keep posting updates.
                        If you need more info about this generator, I can give more info, tutorials, books, etc. as I`m not going to take with me in the grave all of this...
                        Take care,
                        Teo
                        • An axial Flux gen is still going to slow down at high speed on a current draw. But the low speed option is there if it puts out enough power. I wouldn't suggest using a mod motor. I would just used a regular motor to turn it.
                          Even if you can get it up 4-5k rpms as soon a load touches the gen you'll lock the mod motor up.
                          I would use a buck converter between the pole of the battery and feed the motor something like 6-8 volt to keep the rpms down. You should be able to find a moderate range that the gen does not drag. But if you try to do AA high speed job with that gen your in for some damage if your not careful.
                          • @Matt,
                            I will test first my gen on slow speed, but until then, it is a long way to go.
                            I ordered today the 350 watt motor, it should arrive in one week max, and after that i have to take my gen apart, with someone to help me - only one disk with magnets have 15 kg, and I can lift only 7 kg now. Not to mention the HUGE force of magnet attraction, so I have to be VERY careful.
                            Making the steel framework for housing MY106 will take also some time - fortunately, I have some good friends wiling to help me out with this.
                            Anyway, in the meantime I still have work to do, testing the small unit.
                            About controlling the speed, I have already a PWM controller, and of course, I have to be very careful...
                            We will see in 2 weeks some news about my big gen, until then, I will play with different coils in my smaller axial flux generator version.
                            Best regards,
                            Teo
                            • Down but not out
                              Teo,
                              You keep posting to let us know or if any questions.
                              Matthew and Dave will be your best help here. I was down with stomach bug or food poisoning for two days. These guys have built this generator and tested it. They know it works. It will save you money and time listening to them.
                              Feel much better today so hopefully will get some shop time today. I'm still re-cutting the upright wooden stators so the coils can be installed from back.
                              Will make more pictures as I get anything worthy accomplished to post. Case in point here Teo. I tried my own design on this upright generator but now I've taken it completely apart to design it a better setup as per Dave's setup.
                              I tried to encourage others to build here. Just keep going. But if you can these guys will help you build a better working machine.
                              Coffee and the morning is cold so time to warm it up in the ole nuking machine
                              wantomake
                              • @wantomake,
                                Thank you for your reply, I hope you fell better.
                                My big generator was already made for another project, and I thought to give it a try also on 3BGS. I don`t have now enough founds to build a different one...
                                I want to make some tests, first, with the MY 1016 motor, but so far I`m out of luck with my supplier. From where did you bought your MY1016?
                                I`m looking for an alternative to buy this motor, with free shipping to Europe (Romania).
                                All I can found is from US - the price is good, but the shipping cost are very high.
                                Best regards,
                                Teo
