Jes Ascanius Radiant collector
  • #16
    Originally posted by Slider2732 View Post
    The panels are painted at the moment and I wonder if that counts as insulation.
    You could try cooking foil, the stuff that turkeys are wrapped in
    for roasting. It is a bit fragile.
    Also the "space blankets", large plastic sheets sprayed with aluminium
    on one side, if a proper electrical connection can be made. (some may
    be a sandwich - plastic, al, plastic)
    • #17
      Very cool, thanks
      I've had another thought that's worth a go...simply use 1N4148's as the diodes. They're dripping off circuit boards of every type.
      The circuit would have to have a large cap as storage, due to the decreased voltage throughput (0.4V'ish difference) but could be held in the cap til....selected.
      The selection idea, relates to battery cycling in Bedini charging circuits that i'm working with too.
      Make a dozen circuits and have the Grounds connected, but not the Positives. Use a CMOS 555 or any low voltage variable rate LED blocking oscillator (Lidmotor's 'Penny' or my '555 A-Like' say) as trigger pulse. Trigger a 74161 counter chip with that and it would sequentially step through the Modules. I'd use a 74161, as that's what I know I have and as used on an 8 count bar measure circuit for an electronic music sequencer once. Each Module would then have time to charge, before being selected and 'dumped' into the main storage cap for running projects.
      'Inventor3' on YouTube made a series of videos of this sort of thing and i'm busily reviewing those at the moment.
      *Edit* - in fact, if you look at this video: Free energy experiment part 3 - YouTube
      It looks like a great method for solar induction too. Diode's, especially some LED's will become photovoltaic...I/R ones being strongest. If they sit within the circuit and you mount all the diodes on a wall outside, you not only collect the energies in the Tesla/Ascanius method, you collect photovoltaic energy too
      • #18
        Here's a 10 minute thing that anyone can do.
        Take a piece of metal (1ftx1ft), string it up to ceiling height but insulated from everything but the string.
        Connect an AV plug of 2x 1N4148 diodes to the lead you have coming off the plate.
        I was quite shocked.
        370mV @ 4uA, with leaps up to 1.6V randomly, every few seconds!
        Am now building a few sets of simple AV plugs, which will lead to a storage cap.
        Then to link up the metal plates in a box like fashion, for the cap plate aerial idea.
        ...a few minutes later
        Sure enough, the counter intuitive thinking is demonstrated.
        With 2x AV plug to the same wire, we may expect to see exactly the same reading, but, nope.
        0.435V, with spikes to 1.9V
        Still not enough uA to drive even a good blocking oscillator, but kinda weird and very interesting.
        Combining the AV plug duo, with the Ascanius Module, a constant 1.070V is being seen. Nothing for uA yet of use.
        • #19
          Sorry for the triple posting (slow thread eh)
          But...
          SUCCESS !!!!!
          I've now got 3 plates strung up from the ceiling, all connected and leading down to the work table using a former mains lead, that was split down the length into 2 pieces of wire.
          That connects to 2x1N4148 arranged as an AV plug.
          They connect to a 1000uF 25V capacitor and the positive leg is isolated from the input by another 1N4148.
          No ground is used.
          It takes a woeful 20 minutes to fill that cap to 0.6V.
          However, when it has done, I can connect an LED blocking oscillator and off it runs
          The cap then depletes at approx 1mV per second, so more capacitance and AV plugs need to go on the system.
          This is completely free power - forever - made from junk and only at ceiling height.
          Leave the system alone overnight and already you can see that some usable energy will come through.
          I'm quite sure that with a better and cleaner setup and using the Ascanius circuits properly, that much better results can be achieved.
          But, the 1N4148's will work.
          Here are my simple messy plates. If I can get results like this, from these, then surely it spurs you fellas on
          • #20
            No one ever does as one tells.
            Hi.
            I am Jes Ascanius
            And no one off you ladies does what i write, instead you try to get something else working that is not at all as i describe and then come here to ask each other in vain most of the time, because you ask a myth as what you ask is not what you have made!!!
            Please do exactly as i do and it works, if you do something yourself that is not like the way i show it, that is why it properly does not work.
            So funny to see some of you write that there nowhere stands that the suspended plate has to be isolated.
            THAT STANDS IN CLEAR WRITING IN PJK BOOK!
            As someone saw and wrote :-) good thing someone still can use their eyes!
            Key notes:
            POLISHED aluminium plate
            Henged on NYLON Robes/strings
            "8" gauge solid cooper leads, "4" gauge is a absolute minimum and you folks use leads that are so tiny it can never work!
            Large ground connections
            Please do see the pictures and videos of the system running from my live space!
            https://profile.live.com/cid-5b0f8c4...94e9&sc=photos
            Everytime i see someones replication, the suspended plate or wire is infantly small or low placed, eventhough i clearly state that either much larger or much higher up?
            Also it depends on ionospheric pressure, meaning that low wet regions are just as awfull as high dry regions are wonderfull for such radient systems, so where one mand has a 60 x 60 aluminium plate on his artic to charge a phone, somewhere else that gets even more power and somewhere it is like it does not even work, so if it is to humid and you cant get it up real high without any aetheric connection to ground, then forget about it, it is not going to work.
            Polish the aluminiumplate often or see the power collection fall, polishing it to high polish and keeping it polished, so use 2-3 mm aluminium plaets, the you can polish them all you want over decades.
            It must be dry polishing, no wax - no nothing but what you polish with.
            I use a centergrinder, one of those round thingies that you can buy cheap in every buildermarked that both vibrates and turns, finer and finer paper, when the finest paper is used i do nothing more but wash and rub them with clean cutton and isopropyl alkhohol, then polish it slightly again afterwards just witj clean cutton.
            So how come someone write here in this lovely forum that there stands nothing about it in PJK Book???
            The number one reson that many cannot find out how things work and cannot even replicate tyhings that are clearly stated?
            I know from long experience the truth, here it is folks:
            Retardment!
            Retardment here talked about is remebering false memories, not being able to remember, not being able to calculate, not being able to visualise and other lovely faculty difficulties!
            Please never listen to people that are the so called "lamers" they are in reallity far more involved in pumping their ego rather than trying to get something to work wich it seems like they are posting about, but it is not, they are there for getting reflection before it is earned truely, whicked people is another word, they grow more and more by time right now untill we all descide to change, so please recognice them, sort them out and go only where real truth is, where something real is made and documented, never listen to those youtubers, but listen to people whom have read books for many years or have REALLY been using houers every day for years to find out about something.
            That has been the way i initially got this working, that is also how i get anything else working, by reading and doing A LOT for YEARS, sorting out, trying out, no manual, just the thinking ultra logically through Hermetic rules / Axioms and one can find out about just about anything i woukd guess, but you have to be senseer, really trying, because you only get as much back as you REALLY try and also you get just as little as you try.
            Sorry for my bad english among other things ;-)
            But Homo Sapiens, Maat, the civil abe listen more when you roughen them up, it must be a side effect for being driven mainly by fear to enlarge the sphere for at least 50.000 years.
            Homo Sapiens, the first Atom bomb driven biological creature, just bombing its way through anyone/anything else untill it is purely alone and have erradicated the last spek of dust in the entire physical universe.
            Allalus face on mars wheaps for the lacking actions of the son of Enlil/Enki, that he could not defeat Marduk, that they most flee to far far away land, and here we are left, with Marduk, god of war, lots of Atom boms.
            Weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!
            How we made it, how we are great, how we will surely prosper, how every day a new kind of tree or plant, animal or insect springs forth from creation........................OR NOT!!
            Insanity, Confusius, the mind of madness, out!
            P.S.
            Something worth trying!
            Limestone, incapsule metal plate behind limestone and use it as a collector, the radient inflow is very large indeed, but nothing sure to talk about just yet.
            • #21
              Hello Jes and Welcome to the forum!
              This topic is very interesting to me and I respect you and thank you for sharing your work.
              I had a look at your pictures and I would like to ask you some questions...
              How much power could you get out of this system (see picture below) and how often would the SCR fire?
              I'm also interested in your "heavy duty" system (see picture below). Do you have a scheme for this one? Did you complete the system? How wide apart have you set the spark gap - did the spark gap fire at all?
              Thank you in advance for your answers!
              • #22
                Exactly Jes ! and the purpose for my very much simplified example of such a device, merely as motivation. Got to start somewhere and very few even do that
                You can see by the way that the topic simply drifted off, that either people are busy actually building, or just haven't taken the time to do anything.
                Your work prompted further reading and building...which now has seen a garden based horizontal radiant collector that's been running for many days. My thoughts were about our high lightning storm rate here in the Midwest of America. The collector is lightning nulled because of its height and powers an LED oscillator 24/7.
                For reference: Radiant Energy Collector - Low Height - YouTube
                Sanding and polishing of different plates is one area to do and then to put them in the attic, with spark gap protection and large gauge wiring. The simple AV plug and cap idea does work, but isn't very suited to multiple circuit integration. So, with a hoped for acquisition of germanium diodes, that situation can be *cough* rectified, for multiples of your circuit. As you say, only when actually replicated, will such a system work as described.
                We need to do some roof repairs and that's when they'll be fitted.
                I wish more people would simply have a go and see.
                Regarding Mars anomalies, this one is a fave:
                • #23
                  Parts for project
                  For those that are interested, the hard to locate 200nF(0.2uF) 200v caps
                  can be found at Mouser.com under the Mouser P/N 80-R46KN3220JBM1K.
                  These are exactly like the ones used in the project. The other components
                  can be found on e-bay.
                  Hope this is helpful.
                  goharry1
                  • #24
                    Replication
                    Hello All,
                    Glad to see a forum on this stuff.Thanks to Patrick Kelly, compiler of, IMHO,the Greatest Free Energy pdf ever assembled in the history of the planet.
                    Thanks too to Ascanius who did what others refuse to do, SHARE
                    I have replicated the device.I am now fine tuning it to get more voltage and to light an LED.Actually did it with some kids from my science club.Wanted the next generation to warm up to what their Physics texts refuses to inform them about.
                    Actually got 0.3 volts to start with but I need to get the polished stuff, another module and I already installed two grounds.
                    This weeks project is to light an LED.
                    Incidentally, what ascanius has created is a device called a Rectenna.It is also a sort of voltage multiplier.
                    He is moving from low voltage to high, but simmilar devices have been patented.That employs HV instead.Example the HEED device by Deyo that uses HV HF pulses to get it resonating at between 4 and 7Mhz for greater power.They have added a tank circuit.But that might be a totally different device...
                    Anyway.I am pleased with my success so far an will keep in touch as I experiment.
                    Ged
                    • #25
                      Radiant power come from RADIO Station
                      I Replicated this circuit and only two bank is enough for lit one LED. But that happen when my nearest 10KW MW Radio Station is on air mode. During night (after 11:59) time the AM Station is off==My LED OFF
                      I failed to tune Radiant Energy.....
                      RATUL KHAN.
                      • #26
                        @Ratul - Perhaps the way to view your experience, is that the 2 banks are showing that your system is connected correctly. The overpowering radio station is throwing out enough RF to show the illumination - but - your system hasn't the amount of banks to continue after it shuts down at midnight.
                        A good experiment and continuation, would be to add several more banks and see what happens after midnight...the output would drop, but you should be able to build on the collected radiant (and indeed of other RF noise, like ionosphere bounced signals). Using a multi-meter ought to show what you have coming in after midnight
                        • #27
                          Some advice for a newbie please.
                          Hi guys. I´m Chris from Argentina, and new to the radiant energy world and to the forum.
                          I got very excited since I casually landed in the NICOLATESLASECRET.COM webpage and discovered this "strange" and almost unknown source of free energy.
                          But I need some advice from you, the experienced people.
                          Happens that I am interested in buying the e-book the site offers, but there are a couple statements (within many others) on the salespage that seriously make me doubt about if they are a scam or not:
                          First, they say that anyone following the "step by step" instructions contained in the ebook can easily go "off the grid", with a few bucks, becoming totally independant from the electricity company. (mmm...), even without NO electrical knowledge at all.
                          And second, they say that the "device" is so small and portable, that you can take it with you for camping and feed a refrigerator or tv with it, even in the top of a remote mountain (mmmmm 2...)
                          These ideas obviously fascinated me, but based on what I am reading here and there, I´m now becoming a bit exceptic.
                          Other page somehow similar to the one I told above is TESLASECRET.COM
                          Is one better than the other?
                          Some advice and oppinions?
                          Thanks buddies!!
                          • #28
                            Scam
                            This has been discussed several times on this forum. To my knowledge no one has ever gotten more than a tiny amount of power from this circuit. If you have a powerful TV or radio station nearby you might get enough power to light a LED. Use the search function on this forum and you will find a lot of threads where people have tried this.
                            And to the forum.
                            Carroll
                            • #29
                              Many thanks Carroll.
                              It is a pleasure to join you!
                              And to the forum.
                              Carroll
                              • #30
                                3 plate
                                Slider congratulations regarding your experiment. Can you please post the exact schematic you've done?
