Water for farm from air
Originally posted by velacreations View PostThis is interesting, I wonder if there is an open source or DIY version. this would be great at the base of new tree plantingsLast edited by tachyon; 11-13-2012, 12:30 PM.The pure in heart will see the light.
Yeah, I started doing some calculations based on relative humidity and temperature, and this thing does not look good in dry climates. When you are talking about 30% humidity or less, you are going to need a 30 degree F temp difference to condense that water. My ground temps are about 70F. So, that means it will only condense water when temps exceed 100F or the humidity increases beyond 30%.
So, this is not for deserts, this is for hot, humid places. Those places also tend to have a lot of water.
This device can be a great way to conserve water. As we all know, water is becoming a scarce resource all over the world. This has been a topic of many researches and yes it is a fact. This device can help in the reduction of clean water consumption. Instead of getting water from our faucet to water the plants, we can use the output of the device instead or maybe used for some other purposes. Thumbs up for this great invention.- l_schultz
A friend of mine has something similar to this on his yacht,
it just pull water out of the air to provide an endless supply of fresh water while out on the water, in perfect conditions it can make 7 litres a day.
its about the size of a microwave oven half of which is a stortage tank it is a bit power hungry which can be an issue on a yacht.
