More Plant Pores
  • More Plant Pores
    More pores could ease global warming | COSMOS magazine
    "They found that the number of pores multiplied relative to the concentration of the solution of the protein, which the researchers named "Stomagen", achieving a maximum of four times the number of pores of an untreated plant.
    An ideal increase would be two to three times, since too many pores impede the functions of other cells in the surface of the plant, Hara-Nishimura said."
    I don't think the co2 has a significant impact on climate change, but still...
    this is a great concept to simply have stronger and healthier plants.
    I talked to my expert last night and there is something almost anyone
    can do at home with their own seeds to get this kind of effect. I'll ask if
    I can post it here... very simple, cheap and effective. And it is completely
    organic too.
    RPX & MWO http://vril.io
    organic too.
    Interesting, do tell - if you can
    Regular service Signature:
      germination pre-soak formula
      Hi Savvypro,
      Here it is....
      0.04g seaweed extract + 2ml bamboo vinegar
      added to 1 liter of water.
      Presoak seeds for 24 hours then plant them
      in whatever you want to germinate them in.
      The seaweed provides protein and nutrients.
      The bamboo vinegar appears to provide as a
      "liquid smoke" alternative.
      Here is what smoke does for germination...
      Check out this powerpoint, it is REALLY an
      incredible find!!! My friend got this from
      this particular researcher. The #'s are off
      a bit but it shows the deal.
      Investigation of the Germination Promoting Compounds in Smoke
      It is known that forest fires are good for the forest and this is
      probably why. Some seeds need heat to crack them and other
      reasons, but this shows the compound that does the magic.
      Liquid Smoke used for giving a smoke flavor to meats, etc...
      can also be used diluted in water. Also at 2ml per liter of water.
      I'm not sure why the bamboo vinegar can do the same thing.
      Should be available in some Asian foods stores. And the seaweed
      extract...that is what can help the pour quantity increase.
      So anyway, use bamboo vinegar or liquid smoke, your choice.
      But definitely use it together with the seaweed extract.
      Each can be used on their own but there is a synergy.
      I've seen the experiments and they're incredible! Anyway,
      at those dilution ratios, it is a very, very inexpensive
      seed soak for seriously increasing germination, etc...
        It is known that forest fires are good for the forest and this is probably why. Some seeds need heat to crack them and other reasons,
        I knew about that ^.
        But that it could be artificially done is new to me.
        The more I look into the whole area of plant growing and the simple crazy things (by main stream standards) that can be done or used to help plants grow the more inspired I get
        Working with nature - not forcing it to do what you want it to do.
          Sonic Bloom
          By the way,
          My friend also developed some sound units that project sound to seeds,
          plants, etc... in conjunction with these formulas for even further enhancement.
          He said this commercial one actually works and has been around for years.
          The sound part that is, I'm not sure about their nutrients.
          Sonic Bloom - Organic Nutrients for your plants, garden or farm
            Aaron,
            I heard about Sonic Bloom some time ago.
            The following page over at Rex Research (Robert A.Nelson: Hemp Husbandry ~ Electro-Culture (Ch 5)) has a collection of a lot of interesting discoveries.
            For example:
            5.6 ~ Magnetism
            Plant breeder Alberto Pirovano published some 50 papers on inherited changes in plants induced by treatment with low frequency or constant magnetic fields.
            Albert R. Davis received U.S. Patent #3,030,590 for his system of gardening with magnetism. Davis said:
            "We found... that treating above ground seeds with the South Pole of a magnet [1,500-2,500 gauss] increases the germination and growth, and the leaves of these vegetables are larger.
            "If you treat seeds [of]... beets, potatoes, carrots or turnips, you will produce a better result by using the North Pole of the magnet."
              I just found out about biochar. This is the method indigenous people of 1,000 years ago used to enhance their soil and produce healthier and more vigorous plant growth. We are just now rediscovering what ancient people knew about biochar or carbonchar. For more info Frequently Asked Questions | Carbon Char Group Good Luck. Stealth
