Quiet? Hardly!
QUOTE=T-rex;198338]Too Quiet Here
With all the material I have provided, this for one year now, why has it not created any activity here. Little comes back out of this effort to promote any advancement in understanding. What is there to maintain my interest?
It did get my car back in shape and a replacement PRC 47.
It would seem "Sparks" has figured it all out. Great! Perhaps he can begin in a series of writings here to explain in an engineer's terms his understanding.
73 DE N6KPH[/QUOTE]
Eric,
Time makes us all equal, you are up the curve where we are not and we are learning from you and for most this is all new as they are just beginning.
Appreciate very much all of the Integratron detail and a new learning curve there as well.
MIT Pulse Generators V5 is an excellent document and have uploaded this one to 'n6kph' for those interested.
It shows me how to downconvert charged oil filled caps into pulse transformers where I believe I have 'Energy Synthesis' displayed using Thyratrons.
'Fence Antenna' Experiment:
This is the simple Crystal Set probe head that I displayed earlier, two 1N34s and a 500pF capacitor into hi impedance Headphones, NO COILS.
I am finding that anything of a metallic nature in my area is charged with this AM EM Hertzian signal at the frequency of 1.557 Mhz.
This includes not only the fenceline at various intensity levels but also anything metallic, house tin roof, motor vehicles, crossbracing on carport, metal objects in yard in general.
What I am now finding is that the Ground Plane under the 'Crystal Set Iniative' is now very loud compared to day one just as if something has allowed this energy to build in size from the Telluric side.
I have noticed that the ORP (Oxidation Reduction Potential) of my hot water system in the Lab which is turned OFF is very high at -800mV where all other water levels are at +250 mV which is normal.
The Lab water is isolated from 'artificial electricity' where the other is used as a grounding path.
CHASING THE HIGH ORP
Will be doing the test exercises today on the 3 Extra Coils and the Secondary as I still have a problem with your Extra Math and disagree with its result as it does not match Tesla's at CSprings.
You are very interested in your disclosures but not interested in the results that are being achieved that may question your own findings.
My setup is using your p1/2 relationship but gives the Secondary and Extra as being of equal length and have the coil resonant at that frequency and why it is radiating and can be received through wet air some 20" away.
From what I can see is that I have a working, passive TMT.
Has anyone else checked with a Crystal Set probe head and Headphones to hear what their Extra is doing?
You will hear very little unless you have a 50kW blanket AM transmitter in close proximity.
I have completed some Math on Tesla's 3 coils with respect to 'Copper Mass' and 'Copper Surface Area' and will present those findings shortly and it will show the errors that people are making in their Tesla replications.
On September 22/23 Tesla was noting that the Primary and Secondary needed to be equal but this is clearly NOT the case on October 4th as he clearly states that his Secondary was 'not vibrating freely' and as a consequence began some major changes.
This is the same time he was beginning to hang his balls, so to speak.
October 5th - 'Res. of secondary 17 turns 2.804 ohms'.
Turn 20 on my system is 'dead', where turn 17 is 'alive'.
'Notes On The Crystal Set', your words:
It is all there, look at it, not the diversions, and remember everything you thought was Tesla is the exact opposite. It is there; one or two turn primary; a 20% height/width secondary; and a 100% height/width extra coil, all there, wire size, turns, all there, can you find it?
Yes, we can and have done so but you are not responding and that is all I ask of you.
Quiet? Hardly!
'If you look for only what you want to see then you will be missing out on the unseen'.
Thanks.
Smokey
73 DE N6KPH[/QUOTE]
Eric,
Quiet? Hardly!
Thanks.
Smokey
