Dollard Forum Adrian Part 2:
To answer now with respect a TMT system.
I had not thought of using the plasma phenomena in a TMT system but simply - why not?
Refinement of the Impulse Discharge (ID) device was a paramount direction before entering into any other use.
Yes, the initial tuning is a delicate procedure and my probable answer was to not power the TMT in this manner but to use the conventional approach but where the two plasma balls were sited was the focus for refinement and where we needed to tune accordingly for a desired output.
i.e., use the Dollard Pulser as the input where the input modulation frequency can be adjusted to the 95khz required out of the secondary and final output from the Extra Coil at 149khz and this being impressed across the plasma balls where the rope is used for fine tuning.
Probably a lamp grounded locally somewhere conveniently away from the apparatus where an analogue meter is used to determine current across the balls and this to aid the tuning distance.
OK, now having written the above, why don't we use the ID to power the TMT?
This would give a true Tesla style input into the system and is most worthy of a try and will do so.
My TMT as it now stands has a pair of high impedance headphones attached and I am listening to the local radio station from a distance of some 20" from the Extra Coil using a crystal set detector (1N34s) attached to a 3" silver capacitor plate from a transmitter.
All passive and works well and the signal IS coming from the Extra Coil.
My Extra Coil is different to Eric's where we have had a disagreement on winding procedure and length etc - mine simply worked.
Probable next step for me here is to use his Regenerative Magnifying Receiver (RMR)(2C22) and see if I can't pick up the signal on that.
OK, good question which has led to further possible developments that might refine the overall system.
Thanks for that and biting at the bit to get back into the Lab.
To retune my system back to Earth Resonance I have calculated that I require a 1.5uF capacitor (plus variable) with a fixed L of 0.005mH at the primary.
I presented something earlier but that was wrong as it was for the secondary and not primary.
There is also some contention here with the frequencies used by Tesla and I feel he was doing a pi/2 at each of the first three steps and this fact has always bothered me.
He was tuning for the LMD component at each stage and not TEM.
Primary at about 58khz, secondary at 95 khz and Extra at Earth Resonace at 149khz and this is up for testing when I can get back to the TMT.
Hope this helps.
All the Best.
Smokey
Eric Dollard
This is a sticky topic.
Dollard Forum Adrian Part1:
Hello Adrian,
Good with the power supply!
Good question but I haven't answered yours yet and see Part 2.
When we discovered the plasma phenomena in the Impulse Discharge, I then set about attempting a down conversion from the storage capacitors (4kv) into a 240 volt power supply.
First efforts were with Gas Discharge Tubes but all this did was burn them out - this is what Don Smith had used but was hopeless.
A spark gap showed me that I could keep a 240v 100watt lamp glowing reasonably nicely but was most unreliable and that is when it looked capable of OU - about 2.5 watts in (12v @ 200mA) and 100 watts out - all analogue metering.
Carbon tips being used here from D batteries and in there is another OU prospect in why it was that they stopped using carbon for anodes in large Tubes 805/813 etc and I still do not have an answer - Eric - anybody?
The DVM is measuring voltage at the caps via a 1000:1 homebuilt probe and shows 1,182 volts:
This device was then put on the backburner in an attempt to discover a reliable means for the down conversion.
Along came Eric Dollard and gave me some beaut Thyratron schematics like in the TMT Pulser (2050) and the Cosmic Ray Detector (OA4G) and pretty much there was my answer but still not finalised at the bench.
Direction here is to disable the current pulser power supply HT and use the 600 volts from the storage capacitors to drive the system at 50 hertz into an output transformer for the 240 volts ac.
There is a circuit in the RCA Manuals that shows a power supply using thyratrons (2050) and this kind of sealed the problem.
This is from RCA Ham Tips Nov-Dec 1946:
Also have plans to use the Tripler with the Flyback for 27kv and have actually done this but my records are incomplete and I have no idea why and requires a review.
Lots of work still to be done here to simplify the circuit to make it reliable but the thyratron is an answer.
There may be other alternatives and I am open to suggestions.
The high voltage driver Mosfet that goes with any flyback is also a possibility and I already have that set up as an option.
I have been collecting HT transformers here for quite some time and I feel it is just a matter of selecting one that can be reversed to give the 240 volts output.
Some of these transformers are huge, one I can barely lift but all worthy of testing.
Have also been collecting Thyratrons where the anode power requirements are in the Kvs as an option to Eric's 2050s which are limited to 450 volts ac.
Working with something generating another plasma also seemed like a good idea.
The ether loves a vacuum!
I had to stop what I was doing in the Lab as I ran out of safety space and am still in a reorganising mode.
I am really tempted to buy two shipping containers where I can put a roof up between them and continue testing in that environment.
Trusting that answers your question - it doesn't as I have just reread yours and will now answer that in a second post.
All the Best.
Smokey
Hi Smokey,
Originally posted by David G Dawson View PostExcellent work with the Linear Amplifier from the 2nd Video and have one question for you.
The EHT supply pcb is being driven from what source - 110vAC 60 hz?
The reason I question this is because what is being used in ceramics will not give you the voltage you expect..
The linear amplifier takes its power source from the standard UK line supply which is AC 240V 50Hz. The HV transformer inside the amplifier steps this up to 1200V, and further with a doubler to about 2400V anode potential. With judicious tuning of the PI-network in the amplifier and the T-network antenna tuner, (not to the system impedance of 50ohms), quite a bit of this potential can be exposed to the experimental apparatus.
A question for you, from my investigations amd experiments so far, (still ongoing), it appears that the self-generating discharge utilises the abnormal glow region of the spark gap I-V characteristics, which represents a negative resistance in the spark gap region, and as demonstrated and measured here:
http://www.am-innovations.com/negati...scharge-part-1
Given that this specialised bias region appears to occur only at low currents e.g. around 100mA, and requires very delicate and precise bias adjustment, how would you practically propose to make use of this fascinating principle and phenomenon in a high-power disruptive discharge powered TMT system ?
Best wishes,
Adrian
I see many comments and effects. Is there a person capable of giving an over all statement that explains goals? In other words, what is it for, what is it suppose to do? Or should it be doing? What is it?
Yes it throws sparks, radiation and radio waves and has a transmitter and one receiver which is around a 50% conversion efficiency. So what does this show? or is it a learning tool possibly? what is the purpose? beautifully done hardware construct.
Underwater radio?Last edited by BroMikey; 12-21-2020, 06:47 AM.
Eric's new RCA Twin Receivers:
https://youtu.be/NyiOnxaCrk0
Radio Antenna Engineering Edmund A Laport:
http://www.athm.net/andreas/RadioAnt...ring-ebook.pdf
https://www.snulbug.mtview.ca.us/boo...naEngineering/
What really bugs me here is the fact that the USA during WWI set up an underground antenna for Continental USA to Europe communications that was dismantled entirely after the war and never used again.
The antenna was the Rogers underground and undersea and the only frequency reference I could find was that for 1150 meters which is about 250 khz with C = 0.035 uF and L = 1 mH.
A possible forerunner for submarine V & ELF communications which began at about the 200 khz area but today is much lower and down to <20 khz.
http://www.rexresearch.com/rogers/1rogers.htm
What I see here is something that could be used at HF but I don't see anybody doing such leg work to see if this is at all possible.
Eric talking of a 10 acre aerial farm and a probable impossibility but why don't we begin to use the underground aerial theory and at HF would be just that much simpler, don't you think?
I made a Post earlier on this and was developing a system similar to Roger's Fig 7/8 but have not as yet done so.
This was no more than a hole in the ground big enough to contain the large pvc pipe/s that contained the antenna with granite surrounding the pipe - an added coherer if you like.
I was looking at a 150mm 6" pvc with end caps but I'm sure you can get bigger with the length being the main criteria.
More than one for effect - build two and you have your stereo requirement.
I am into aerials at this time as I am building a directional rectangular parabola for the Juan Biagorri Velar rainmaker and have the final design and parts for 60 mhz 5 meter but still waiting my attention.
This is another Vacuum Tube initiative and looking at 6SN7GTAs or even 807s.
What I do have here is a Yaesu FT-901D (6146Bs) and may simply use that as the transmitter matched into the antenna with a variety of modulation means available.
There is a research band at about 54 mhz which I will try to encompass in all of this by not breaking any laws regarding illegal transmissions.
Fun stuff!
The Spectrum Analyser has arrived and looks good but untested - GQ EMF-360V2 - 10 Ghz - Seattle address.
We need to understand what we are seeing on the meter and attempt to recognise it as a dbm or watts reference or a something else.
Food for thought.
Smokey
Originally posted by aminnovations View PostHi,
In this post we take a preliminary experimental look at the transference of electric power using a cylindrical coil TC and TMT, energised using a linear amplifier generator, and also the high power transfer efficiency that can be achieved in a properly matched system. The setup, tuning, and matching of the linear amplifier is covered in detail in the video experiment where a 500W incandescent lamp can be fully illuminated at power transfer efficiencies over 99% in the close mid-field region. The power is shown to be transferred to the receiver through a single wire between the transmitter and receiver coil through the longitudinal magneto-dielectric mode, and not through transverse electromagnetic radiation or through direct transformer induction. This high-efficiency, very low-loss transference of electric power is possible as the dielectric and magnetic fields of induction are contained around the single wire. It is also demonstrated that more than 500W of power can be transferred through a single wire no thicker than a human hair, a 40AWG (0.08mm or 80 microns).
The video experiment demonstrates and includes the following:
1. Linear amplifier generator setup, matching, tuning, and operation to drive a cylindrical TC and TMT system.
2. Measurement and confirmation of the series and parallel modes of resonance for a balanced TC, against the Z11 impedance results, using the generator exciter and an oscilloscope.
3. Transference of electric power from the generator exciter unit, to a single wire transmission medium incandescent lamp load up to 120W.
4. Transference of electric power from the linear amplifier generator to a 500W incandescent lamp load at the TMT receiver output, and subsequently to two parallel 500W lamp loads.
5. Longitudinal magneto-dielectric (LMD) mode measurement through central null with a fluorescent lamp, and mode interference patterns with an ultraviolet lamp.
6. Transference of electric power efficiency measurements up to 99% using an AWG12 single wire between the TX and RX coils.
7. Efficiency measurements up to 100% using an AWG40, 80 micron (0.08mm), 60cm long, single wire between the TX and RX coils.
Best wishes,
Adrian
You are doing fascinating work as always.
Considerable discussion has taken place on the need for an extremely low inductance and low-resistance ground system in the design of TMT power transmission systems, but here you demonstrate power transmission over a high inductance, high-resistance medium.
Do you have any explanation for the apparent ease in which you delivered power via an 0.08mm wire, while Tesla and others needed tonnes of copper to achieve a suitably low impedance connection to the earth?
Originally posted by David G Dawson View PostHello - anybody home?
Eric Dollard Forum:
I go to this Forum today and see that I have some 20 odd private questions from individuals about various segments of my research dating back to 2013 that I have posted here but how come I am only seeing those now and not when they were first posted?
My humble apologies to those people as I was not aware of those messages until today.
I am open to objective criticism but if somebody asks me an intelligent question, I do my best to give a truthful answer supported by the research and to do otherwise is not me.
Those questions would have been better to be presented at the main Forum and not privately and would appreciate those who are still interested to repeat their question - Thanks.
Some of the questions were to do with rainmaking but you must all remember that this is exactly what Tesla first endeavored to design but his early results led to a much greater discovery in the 'radiant energy' and its enhanced properties.
I am also active at Groups io and MeWe and may be more suitable and comfortable there for you and you are most welcome to come and join this specialized arena:
smokey9s@groups.io
notifications@mewe.com
We used to receive notifications when somebody posted here but that is no longer happening and why nobody responds.
Smokey
I've never read Ernst's books, so can't give you an answer on his technical details that were used. I know from reading and watching Eric Dollard's work, the "Earth" resonance is around 18 kilohertz, or 18 kilocycles per second, though maybe you know that already.
From what I've read of many of Tesla's lectures, patents, articles, etc... I've never heard directly he wanted to use his transformers to control the weather. There was one reference to it directly in a to-be patent, but was never filed. His transformers were designed for the primary function, transmission of electrical power through the Earth. A lot of the "burning nitrogen" and weather related stuff that's Carried by Ernst and Bill Lyne, seems to be overexaggerated and misinterpreted in my opinion. Thinking there's some "secret" encoded in Tesla's writings seems really silly to me. I don't think Tesla was making significant efforts for weather control, they were probably just ideas being proposed like what happened after he exiled himself in the New Yorker Hotel, and gave teases to news reporters about what he claimed to have invented and found.
Originally posted by David G Dawson View PostWe used to receive notifications when somebody posted here but that is no longer happening and why nobody responds.
I personally wish there was a way to get notifications of all replies to the thread, regardless of whether I had checked it. Aaron, maybe there is something you can do?
Eric Dollard Forum:
smokey9s@groups.io
SmokeyAttached Files
Hello Aaron, Eric, Adrian, Ernst
My Resonant Negative Ion Generator (RNIG) was built using ceramics from AC 240v 50 hz and only gave about 950 volts when it should have been 5 Kv.
Those in the music game are using this same type of arrangement to power their EHT panel speakers but they do not realise that they are not receiving the voltage they expect due to a too low cycle hz,
The only solution to this problem is to go to an electrolytic which is really only a much higher value but adds the capacity component required and gives the result you are building for - I used 4.7uF 400v.
Individuals enter the high voltage scene but fail to prove their endeavours with a suitable EHT probe meter.
I mentioned this problem here some years ago.
Glad you were able to use the work of Ernst Willem van den Bergh in his excellent presentation in his 'Tesla's Magnifying Transmitter' Book.
One thing here for Ernst is what I suggested to Adrian in the use of the Plasma gap which Ernst presents as stage 4 of the TMT where it is a PLASMA Gap and not a spark gap and how is he adjusting his plasma balls to tune for the correct gap?
An analogue meter is best used here to show current as in any transmitter, tuning for minumum current and maximum output.
Also what frequency is Ernst using and is it the resonant Earth frequency?
See my entry Page 186 entry #2779 onwards.
We have a picture of the overall interior of his Tesla Coil but don't get to see the magic side.
What is most evident from the initial observations of Tesla was that he was most interested in building a rainmaker of sorts but his ongoing experiments showed that he had a much greater and wider use potential in the TMT than just to be a rainmaker.
The Crystal Set Initiative (CSI - TMT) is now being rebuilt and utilising the 4th and 5th stages and my guess is that this is exactly what Eric is now building at Lone Pine - am I correct?
How could I possibly be wrong as I still see him in a very old picture at RCA Bollinas over the top of a TMT like experiment.
Eric may remember me eliminating his ground line in one of his drawings as not being required but no comment was received as to question why.
This was revealing what Ernst had also discovered in what Wardenclyffe was all about as a direct advancement on the Colorado Springs experiments.
Eric's thyratron TMT Pulser will be used for this rebuild as it is a pulse that is required to provide the trigger action to make rain and that is what I am building for and anything else that may accompany this initiative will be most welcome.
His 2C22 Regenerative Magnifying Receiver (RMR) will also be used as the monitor.
I now have a Spectrum Analyser on the way which is said to be made in the USA but the English used is more Asian than American:
https://www.ebay.com.au/itm/EMF-Mete...F/254651509614
In all of this the only persons of the past that I can see had some sort of a handle on what Tesla was really all about apart from Eric was Edwin Gray and his 'Spark' Tube and William Lyne's 'Free Energy Surprise' - the use of a Plasma.
This was all demonstarted to me by my accidental discovery of what I called 'Impulse Discharge' and what Chernetsky called 'Self Generating Discharge'.
Smokey
Hi,
I have added a new post to my website on:
High-Efficiency Transference of Electric Power
http://www.am-innovations.com/high-e...electric-power
Best wishes,
Adrian
I have a few questions about the Cosmic Induction Generator and the Colorado Springs Transmission System, more so the CIG.
What form of Coax would I have to use for the conductor (which would be the outer coating) on the secondary of the system?
I intend to make a CIG of my own in the near future, when I don't know, but I plan to.
The diagrams I bought designed to operate at 432 kilocycles, the reason for that was I figured maybe I'd try a pythagorean number and see what happens.
The next couple questions are about the Transmission System.
1. Could it be possible to actually adapt modern digital age technology, computers and possibly internet to this?
2. I'm trying to explain this to some friends to increase your audience and I wanted to know, if you were in a shuttle and wanted to communicate with a station on Earth or a space station, would it be possible with this tech?
I wanted to be sure about these 2 questions before I shot off my mouth like an idiot.Last edited by WesTheSavage; 11-08-2020, 01:31 AM.
NEW TELEPORTATION VIDEO - ONLY FOR THOSE WITH A SENSE OF HUMOR
With all the insanity that has spread across this nation, a good laugh is in order. https://emediapress.com/2020/09/22/t...demonstration/
- 1 like
NEW FREE VIDEO WALK THROUGH OF THE COSMIC INDUCTION GENERATOR - PART 2 AVAILABLE NOW
We already sent you a link to the video about the Cosmic Induction Generator that we're working on, which is more like a Universal Tesla experimentation system because it is very versatile and can do a lot of different things. That was explained in the first walk through video.
In this new video, we show you how far we've come in a relatively short period of time - on this website, there is both Part 1 and Part 2 videos and if you didn't watch the first one yet, I'd recommend watching both in order or you will miss out on a lot of information. You'll see in both videos that Eric is truly a genius engineer who cooked this all out of his head based on what I told him I wanted and it all came together perfectly. We're 90% done with the first rack but take a look: https://emediapress.com/2020/09/09/c...enerator-2020/
Hi Marcus,
Originally posted by Marcus Neuhof View PostHow is this done in coils? I am generally familiar with the use of graduation in e.g microwave antenna theory to provide smooth impedance transition from the 50-ohm line to 377-ohm free space impedance, but the coil-wire-ground-wire-coil system does not seem to admit of much opportunity to provide gradual impedance transitions between the components.
I am looking forward to your further publications on this topic. In particular since our earlier discussions concerned the necessity of disruptive excitation in producing this class of phenomena, but you appear to have observed it with what I assume is continuous wave excitation.
Temporal and spatial coherence being a property associated with sine waves, you are saying this phenomena disappears when the coil is excited with a disruptive discharge? Or is it that the coil's transformation of the disruptive discharge into a sine-shaped waveform which is a precondition to the observed phenomena?
Additionally, I am somewhat confused by your characterisation of the dielectric and magnetic fields "acting ... in displacement" since it was my understanding that displacement is a dielectric phenomena.
Displacement as an underlying process can do this because of the undifferentiated (unseparated), nature of the fields of induction which inherently are spatially and temporally coherent. In contrast the disruptive discharge is in itself a state of transference with many phase relationships between many frequency components, but is also a non-linear one that applies considerable tension to the system. Displacement is a process that underpins transference, and is inclusive, coherent, and involves the undifferentiated dielectric and magnetic fields of induction, whereas transference deals with the differentiated induction fields. When displacement is called forth into a non-linear system certain phenomena are generated including radiant energy, which I treat as an emission from a displacement event. The displacement I am referring to here is not simply a dielectric phenomenon, (which on its own belongs to transference), but rather a totally coherent relationship between the undifferentiated fields of induction, both spatially and temporally.
Best wishes,
Adrian
