Originally posted by Raphael37
Eric Dollard
This is a sticky topic.
words get in the way.
Originally posted by dR-Green View PostPrecisely. Which leads to the point, its signal source is effectively the Tesla receiver. The Tesla receiver's signal source is the grounded AM transmitter. The tuning is done through the Tesla receiver, hence allowing for "untuned demodulation" with the section that you identified as the detector/demodulator much further from the transmitter. Hence my "untuned demodulator" works at 84km.
Yes thanks for the suggestion, I've gotten better results by using different diodes, worse with others.
The tesla receiver represents tuned demodulation because the detector gets it's input from a tuned circuit.
Take away the tuned part ( Tesla receiver) and replace it with a random length of wire, then you have "untuned demodulation" where my example of possibly hearing several close by radio stations at the same time would happen.
Did you try it with a long wire antenna as the only input source????
I'm not sure what you did to get the untuned demodulation. Please be more specific.
Now forget about energising it yourself, it's tuned to the radio station frequency. Now a similar action happens as before, a detectable field is produced around the coil, except now it's powered from the radio transmitter. In this field I place a wire or plate (C0 in diagram) leading to the detector/demodulator, and hear the signal.
Hence the coil is tuned as normal, the detector has no tuning, it merely detects the field that's produced around the tuned coil.
So as the original question, where is the antenna? The tuned coil is "radiating" the signal, the demodulator is "receiving" it in the field around the coil as if it was the antenna. Hence the TC is now effectively the transmitter as far as the demodulator is concerned. If people like to consider the TC as a overground Hertzian wave antenna, would one antenna allow the use of another antenna? If I put up a regular antenna, could I come along with my untuned demodulator near it and hear anything?http://www.teslascientific.com/
getting closer to the same page...
Originally posted by dR-Green View PostThe coil stands alone. It is tuned to resonate with the radio station frequency. Imagine now that you are energising the primary yourself, a detectable field is produced around the coil.
you are either capacity coupling with the plate or inductively coupling with the wire.
You would get the same effect if the long wire antenna in question was cut to a quarter wave length of the radio station's frequency but that would not have as high Q as the LC tank, so may need a bit stronger signal to work but since it is a larger "pickup" it may work fine. I'm not sure, it depends on terrain, signal strength, etc.
If you were close by the station, 10 feet of random wire would be sufficient.
Originally posted by jimm View PostWell, I suppose we can dig up all kinds of moldy artifacts and declare them the "truth"...but what has your truth done for us lately other than rhetoric?
NANO World APPLICATIONS for the SWASTIKA – the true blue AVATAR | Alternative Thinking 37
jimm scroll down to APPLICATION #6 to get a glimpse at what EFFICIENT 21st century science is all about.
Efficient nano motor cleverly harnesses light..
Any simple light source, such as linearly polarized or unpolarized beam can thus be used to drive the new set-up.
The motor could be ideal for powering NEMS and for bio-applications, such as DNA winding and unwinding. It might also be useful for harvesting solar energy, after some modifications in design to optimize its performance for such an application – for example, making it more susceptible to a broader spectrum of light wavelengths. "Several motors can also be easily combined for larger power, like the cylinders in a car motor," team member Ming Liu told physicsworld.com.
Who cares jimm.
Must we all be Eric Dollard groupies?
I guess jimm thinks his kinda of brain is going to fix the problems of this world that his kind of brain created in the first place...?
My posts are targeting folks with an OPEN mind jimm, YOU don't need to read them or comment, just ignore me.
Do you think I read your posts or do I skip over them?
Take a guess.
jimm as the above quote suggests in the future Nano Light Mills that use swastika architecture will be able to UNZIP your DNA and maybe turn you into a moldy artifact to be dug up in the future and dusted off and promoted as something really important.
Originally posted by Raphael37 View PostIt was not necessary to dig up this evidence here, it is recent:
What has my truth done for you lately?
Who cares jimm.
Take a guess.
You have no reason to feel superior to Dollard. You both sell "sizzle" but have no steak!
I am not a groupie or cult joiner, so go hawk your swastika snake oil in your own thread where you belong. what? Is business slow over there?
I may get over there and give it a read as soon as I beam down from the starship that I built.
Originally posted by jimm View Post...but what has your truth done for us lately
Entrepreneur/inventor/patent holder Jay Harman promotes the SWASTIKA in a video that is promoting an Alternative Cure for Global Warming.
TEDxMarin - Jay Harman - An Alternative Cure for Global Warming - YouTube
Starting at around 2:30....what do we see???
Swastika = SHAPE OF MOVEMENT
go ahead IGNORE it jimm ... But Jay Harmon spells it out however in that video
Jay Harman makes it clear that NATURE PREFERS the swastika to help get the job done ...
'Comprehend and Copy Nature'
-Viktor Schauberger
What have I done for jimm lately?
Nothing but I can guarantee you that you are ignorant about how many ways existing technologies derived from the swastika design impact your life in the here and now.
No need to respond jimm, just ignore the swastika and me.
But in the long run only a fool would bet against an ancient good luck symbol that can be dated back to 10,000 BCE.
There is a reason this MEME is being carried forward till this day....it suggests there must a use for it....or why bother 'carry it forward'?
Oh did I say MEME?
Yes I did.
Eric Dollard is more accommodating than you jimm regarding the swastika.
Eric is currently holding a MEME contest.
Eric Dollard Meme Contest Prize
I have entered the contest already and the swastika is my entry.
And a Mike Kirkpatrick said the following:
"...the symbol (swastika) does a good job of conveying the inner structure/movement of electricity and magnetism."Last edited by Raphael37; 07-16-2013, 12:06 PM.
Originally posted by jimm View PostHave you considered that your artifacts may have ended up in the trash can and buried for a reason? They had to do something with garbage back in ancient times as well.
I am not a groupie or cult joiner, so go hawk your swastika snake oil in your own thread where you belong. what? Is business slow over there?the swastika got buried by 'Ignorance R US' who evolved to your generation of garage tinkers .... TOYS R US
The swastika got buried for good reason....and I posted the reason in my last post jimm.
Here it is again:
I never said I was superior to Dollard...we share a common model arrived at independently.
But you dude are really full of yourself jimm.
A legend in your own petty CLOSED mind.
jimm there are SWASTIKA NANO TECHNOLOGIES being utilized right now in the here and now this technology was never buried...only VEILED.
jimm the fact is 21st century swastika nano technologies are making existing technologies MORE EFFICIENT, even while ewe sizzle lamb chop.
selahLast edited by Raphael37; 07-16-2013, 05:26 AM.
Q/
why did Hitler covet the swastika for his MOVEMENT?
Q/
why did the Buddha choose to place the swastika over his heart to represent his MOVEMENT?
And my last question answers the first two.
Q/
why did the pre-christian Pacific civilizations refer to the swastika as the KEY of universal MOVEMENT?
So the answer is clear.
All of the above gravitated (centripetal) toward the swastika because it represents both centripetal and centrifugal MOVEMENT, it is the KEY to understanding the mechanism employed on all levels of scaling of the multi-universe.
... the swastika literally and figuratively makes the world go round.
It is the KEY to understanding MOVEMENT in the here and now as Jay Harman illustrated in his video.
HOWEVER maybe the swastika choose them to be its voice, and depending on how you were raised is how you respond when you hear it calling out to ewe?
The swastika in the QaBaLaH is linked to your higher self - your inner genius and the tetragrammaton a.k.a. YHVH.
selahLast edited by Raphael37; 07-16-2013, 12:00 PM.
Here we go...
Raphael37
The mystics have entered the room.!!! Let us all fall to our knees in awe of their superior knowledge and of drink of the sacred Kool-aid when it is offered.
Such a superior being as yourself resorts to insults and browbeating when others aren't buying what you are selling, huh?
I was actually going to read your thread, only because I was curious about what you had to say. Now it's clear that you are just another con man looking for followers. I'm definitely NOT going to waste my time now.
A truly spiritual person would not write how you have written here.
If what you have "discovered" has made you become the person that you are, I want NOTHING TO DO WITH IT.
Wrong topic
@Raphael37
With all due respect, please take your topic material elsewhere.
This thread is for Eric Dollard to share his information and for those interested to try to work with his technology.
It's already difficult enough to go back and pull out important posts, please don't clutter the thread with anymore irrelevant information.
Marcel
Marcel
Clearly he does not think much of Eric Dollard.
His comment makes Dollard sound like a dullard.
Originally posted by jimm View PostYou have no reason to feel superior to Dollard. You both sell "sizzle" but have no steak!
Marcel are you an impartial moderator?
Marcel I ask that you let stand whatever I posted on this thread till now ... because unless you can tell me exactly what everything means that has been posted till now on this thread ... I suggest you let what I posted stand.
just because what I am is suggesting on this thread does not compute with you...it might with others.
and that is a fact of life you need to understand....
what I posted might be a KEY as others in the past have noted.
The highly respected Itzhak Bentov was another inventor, patent holder, and guru/mystic who endorsed 'meditation'.
He also published this in 1979:
“This desire resulted in the process of creation, symbolized by the swastika within the creative center, representing a four-dimensional rotating universe.
It is interesting to note that if you merge your consciousness with that of the Creator, you discover within Him a rotating swastika.
In other words, swastika stands for both the Creator and the Creation – they are inseparable”
The Svastica is the most philosophically scientific of all symbols, as also the most comprehensible. It is the summary in a few lines of the whole work of creation, or evolution, as one should rather say, from Cosmo-theogony down to Anthro-pogony, from the indivisible unknown Parabrahm to the humble moneron of materialistic science, whose genesis is as unknown to that science as is that of the All-Deity itself. The Svastica is found heading the religious symbols of every old nation.
It is the Alpha and the Omega of universal creative Force, evolving from pure Spirit and ending in gross Matter. It is also the key to the cycle of Science, divine and human; and he who comprehends its full meaning is for ever liberated from the toils of Mahamaya, the great Illusion and Deceiver.
Hey Marcel can I suggest Itzhak Bentov would like it if you let stand ALL I have so far posted on this thread?
ITZHAK BENTOV-The Evolution Of Soul And Nervous System - YouTube
namasteLast edited by Raphael37; 07-16-2013, 03:28 PM.
http://www.energeticforum.com/235298-post17.html
And Dave also claimed on another thread that my ideas are in league with Hitler and Satan....
Originally posted by Dave45 View PostYou try to paint Hitler as a christian but he came from the likes of you and your satanic philosophy.
http://www.energeticforum.com/234757-post1030.html
so you see jimm, Dave really deserved the tongue lashing he got from ME.
ignorant christians have gotten too much mileage out of condemning folks to hell or calling them NAZIs, or even anti-Semites when they feel they have hit the wall
And I can assure you that me trying to promote the swastika in the WEST makes me many friends.
Because now I have produced a target to which they can focus their ignorance...little ole' me.
Originally posted by jimm View PostI was actually going to read your thread, only because I was curious about what you had to say. Now it's clear that you are just another con man looking for followers. I'm definitely NOT going to waste my time now.
can you get past the ugly messenger and reach the TRUTH?
Or do you succumb to the same ole' BS - crucify the messenJAH, if the message makes you feel at all uncomfortable...?
Maybe you should read some Osho or Rumi instead of what I have 'recovered'.
What I write causes MOBS to form...
Originally posted by jimm View PostA truly spiritual person would not write how you have written here.
Whether a priest tells you that, or a shrink who would say you are in denial of who you really are.
I AM not the problem, you are.
You are the change....how about entertaining an inspired THOTH thought that you have never had before?
(at least in this lifetime...)
WHAT IF the SWASTIKA is the KEY to Eric Dollard hitting the motherlode?
Why don't you shleep on it jimm?
namasteLast edited by Raphael37; 07-16-2013, 03:37 PM.
When the Levee Breaks-Led Zeppelin - YouTube
The quadrants of the unit circle and of sin x, using the Cartesian coordinate system.Last edited by dR-Green; 07-16-2013, 04:12 PM.http://www.teslascientific.com/
