Eric Dollard
This is a sticky topic.
  • Sputins
    Extracoils..
    You underestimate their ignorance! They didn't think I had a wire up my sleeve, they thought my woollen sleeve was the conductor! The camera perspective made it look (to them) like I was touching one terminal with the bulb, and my sleeve was touching the other terminal so that was the obvious conductive path. Even though both terminals were in the same bucket of soil and there were no wires leading to the second terminal.
    Yeah when I was using HV and holding the insulation on a big clip the whole thing would light up purple under the insulation, potentially more dangerous than just holding the metal. What you describe as conducting through the insulation I think is capacitive coupling to your body, because the bulb will also light at lower voltages without any of the arcing. If you use a metal plate (experiment with size) then you should be able to vary the brightness depending on the distance of your hand from the plate.
    If you modulate your carrier signal input then it should work just the same as it does now but with some intelligence. Then it's just a matter of tweaking it to make the signal clean which might not necessarily be optimised for lighting bulbs, but it can be fun and distracting to overdrive it to try and get bulbs up to full brightness!
    Is it necessary to measure the wire? If you wind it on the frame then it should end up at the correct length anyway. Either way, I had the same dilemma of wanting to measure some wire so that's what the frame that's currently under my transmitter in the pictures was for. It was designed to have a circumference of 1 metre so 1 turn = 1 metre of wire. With a handle to turn it and a frame to hold it a mechanical counter can then be added to count the number of turns which corresponds directly to the wire length.
    Maybe you had metal fibres woven into your jumper? - Like steel wool, that must be it! We're on to you now, lol.
    After measuring out the wire, (66.2 meters) I constructed the first version Extracoil following the ‘Tentative Extracoil’ calculation formula. I found that for my spiral coil the extra coil inductance was too large, and the frequency of it too low to resonate compared to that of the spiral coil (and adding any capacitance will bring it down even further). Unwinding it some then made the length to height ratio incorrect. - I noticed that this maybe why you recently added the variable air capacitor across the secondary coil on your rig, as to bring down the secondary frequency to match the Extracoil’ s frequency better?
    Yeah, I would agree that measuring out the wire may be unnecessary. I do it because then I can measure out two identical wire lengths, (side by side), then I know for sure they are both the same length and it’s a physical measurement conformation to the calculated length by the number of turns method.
    Having said that, I unwound the Extracoil and started again, this time using a larger diameter wire and larger space (length by calculation this time). Amazingly, this time the self-resonant frequency of the (new) extra coil is almost exactly the same as the spiral coil self resonant frequency. 2.08Mc V 2.085Mc, however the Extracoil is over 57% longer in wire length with a 1:1 H x L ratio. So I’m happy to work with that for now, as I’ll be trying for a capacitive coupling link between them, not directly connected as Eric highlights.
    As for lighting bulbs: I have bought some ‘vintage style bulbs’, not really vintage, but copies of, which are 25W bulbs but they have long fine filaments and a large vacuum space. All of these bulbs light quite nicely. The small 25watt bulb shown in my previous picture, when I push my amp to full power, the light from that bulb is something to behold, it is @#$! blinding! Extremely bright.
    I’ll have to give the plate and hand trick a go too, which sounds like some fun. - I’ll continue to play with adding the extra coil to my rig and see what happens with that.
    Pictures of the ‘vintage’ bulbs, Extracoil, with some statistics and results to come later.
    Sputins.
  • orgonaut314
    If you take the below high frequencies from Rife and multiply them by 2 you get around the 3,2MHz. From what I read the 3,2 also resonates in the virus that resonates on 1,6 killing it.
    Influenza (1918) - 1,674,000
    Bacillus X and Y (Cancer) - 1,604,000
    Would it be a coincidence that my flu is healed in one day I wonder what others are experiencing with their coils? It is really beyond any reason the way I got cured from the flu. Never had that my whole life.
    When you look at these harmonics almost every virus resonates at 3,2MHz.
    Dr. Rife's True Original Frequencies
  • orgonaut314
  • dR-Green
    Originally posted by Sputins View Post
    @dr Green, you’re right, that is what the sting is, arcing to the fingers when the terminal is loosely held. I even received a slight burn through the insulation of the larger clamp, so the current can penetrate the insulation seeking a ground. Penetrate is the wrong term, it was if the current conducts through the (so called) insulation. One is better off to just to grab the metal. No problems. The larger the surface area of the held metal definitely helps. Yeah, less contact or varying the pressure of contact affects the brightness of the bulb. - Love the conventional dismissal comments, wires up the sleave of your woollen jumper hey? Lol.
    Now your amp is able to cleanly transmit music or signals which would be quite practical. Mine cannot as yet, but I might be able to modulate the key in some way to transmit some intelligence. (Morse code or other). Perhaps I can modulate the grid. The next push-pull transmitter will have (music) modulation as a feature.
    Light bulb lit, with the connection from coil to my hand seen.
    Now it’s time to go down to the local oval and look like a lunatic measuring out the wire for the extra coils..
  • David G Dawson
    Fischer Diathermy
    Tesla-Bcn,
    Having read your questions fully and note that this is early 1920s and before Vacuum Tubes (VT) were used, your questions are most difficult to answer.
    Much deeper research is required and this may help:
    The Turn Of The Century Electrotherapy Museum Tesla Library
    Could not find the video unit there and admit that my interest was in the use of VTs.
    You would really need to have a unit to copy as the engineering is superb and is simply not available today.
    The only thing I can suggest is to wade through the blueprints in the URL above and pull out what you require.
    Most impressed with the coils and capacitors as that is where we are at with the Tesla Magnifying Transmitter.
    Have been trying to buy a unit here but competition is fierce and postage/freight always a problem.
    People are after the simple technology that works - try doing solidstate with any of this!
    If I come up with anything new, will pass on,
    Sorry I can't help further.
    Smokey
  • dR-Green
    Originally posted by Goethe
    All things into one are woven, each in each doth act and dwell
    As cosmic forces, rising, falling, charging up this golden bell,
    With heaven-scented undulations, piercing Earth from power Sublime.
    Harmonious all and all resounding, fill they universe and time!
    Amidst life's tides in raging motion, I ebb and flood - waft to and fro!
    Birth and grave, eternal ocean, ever-moving, transient flow.
    A changing, vibrant animation, the very stuff of life is mine,
    Thus at the loom of time I sit and weave this living cloth divine.
  • dR-Green
    From a video titled "Rife Technology - A New Hope" that was once available on google videos but is no more:
    Rife's High Frequencies
    The following frequencies were found by Dr. Rife and used in his high frequency instruments. They were recorded on his lab notes. Some of these frequencies were used in Dr. Milbank Johnson's 1934 Cancer and Tuberculosis clinic. Many of these frequencies were only made public in the last few years.
    The only frequencies shown in this video were Rife's true high frequency M.O.R.s.
    All frequencies are listed in cycles per second.
    Actinomycosis (Streptothrix) - 192,000 - 678,000 - 186,554
    Anthrax - 139,000 - 900,000 - 272,539
    Anthrax Symptomatic - 400,000 - 16,655
    B. Coli (Rod form) - 417,000 - 683,000 - 317,914
    B. Coli (Filterable virus) - 770,000 - 8,581,000 - 11,103,424
    Bacillus X and Y (Cancer) - 1,604,000 - 11,780,000 - 17,033,662
    Bubonic Plague - 160,000 - 512,466
    Catarrh - 1,800,000 - 1,713,100
    Cholera Spirillum - 851,000 - 960,873
    Contagious Conjunctivitis - 1,206,000 - 2,025,625
    Diptheria - 800,000 - 1,090,154
    Glanders - 986,000 - 736,591
    Gonorrhea - 233,000 - 600,000 - 150,649
    Influenza (1918) - 1,674,000 - 1,946,704
    Leprosy - 743,000 - 251,926
    Pneumonia - 1,200,000 - 381,901
    Spinal Meningitis - 427,000 - 927,800 - 1,795,164
    Staphylococcus Pyogenes Aureus - 478,000 - 998,740 - 555,171
    Staphylococcus Pyogenes Albus - 549,070 - 549,070
    Streptococcus Pyogenes - 720,000 - 1,214,000 - 2,111,214
    Syphilis - 789,000 - 900,000 - 2,775,856
    Tentanus - 234,000 - 700,000 0 15,779
    Tuberculosis (Rod form) - 369,000 - 583,000 - 541,142
    Tuberculosis (Virus) - 770,000 - 8,518,000 - 11,103,424
    Typhoid Fever (Rod form) - 760,000 - 900,000 - 868,964
    Typhoid Fever (Filter passing) - 1,445,000 - 9,680,000 - 13,943,835
    Hoyland's Audio Frequencies
    The following audio frequencies were found by Philip Hoyland and used in the instrument he built for Dr. Rife. Rife didn't know the instrument was not using his high frequencies until the 1939 Beam Ray Corporation trial. These frequencies worked in Hoyland's instrument because of the unique way he built it. Hoyland's instrument worked on harmonics and produced Rife's high frequencies through harmonics. Dr. Rife did not like harmonics and did not approve of Hoyland's design.
    Hoyland's frequencies have been mistaken for Rife's frequencies. Though the doctors who used Hoyland's instruments reported very good results, the instruments would drift and not stay on frequency and many were returned. Hoyland's instruments did not work as well as Rife's high frequency instruments.
    Actinomycosis (Streptothrix) - 7,870
    B. Coli (Rod form) - 8,020
    B. Coli (Filterable virus) - 17,220
    Bacillus X (Cancer - carcinoma) - 21,275
    Bacillus Y (Cancer - sarcoma) - 20,080
    Pneumonia - 7,660
    Staphylococcus Pyogenes Aureus - 7,270
    Streptococcus Pyogenes - 8,450
    Syphilis - 6,600
    Tentanus - 1,200
    Tuberculosis (Rod form) - 8,300
    Tuberculosis (Virus) - 16,000
    Typhoid Fever (Rod form) - 6,900
    Typhoid Fever (Filter passing) - 18,620
    Worms - 2,400
    Rife, Crane and Marsh 1950's Audio Frequencies
    The following audio frequencies were derived by dividing Hoyland's audio frequencies by a factor of ten.
    In the 1950's, Rife, Crane and Marsh became business partners. Rife had no schematics for his high frequency instruments. Hoyland built them but never gave a copy of the schematics to Rife. Rife did have an old Hoyland instrument. Rife, Crane and Marsh decided to re-design Hoyland's instrument and see how well it would work. They removed Hoyland's unique design of harmonics and gating. This made it so the instrument didn't produce any beneficial results. Instead of putting back Hoyland's method of producing harmonics they changed the sine wave audio frequencies to square wave to get harmonics. Then they lowered the audio frequencies by about 10 times.
    The doctors who used these 1950's instruments began to get very good results but after several years of testing they proved not to work as well as Hoyland's instrument. The changes to Hoyland's instrument were not good changes. Apparently Rife, Crane and Marsh never really understood how Hoyland's instrument worked. For years people have mistakenly believed these lowered audio frequencies were Dr. Rife's true M.O.R frequencies. Because of this confusion almost everything manufactured today is based on Hoyland's low audio frequencies and not Dr. Rife's high frequencies which achieved the results of Dr. Johnson's 1934 clinic.
    Actinomycosis (Streptothrix) - 784
    B. Coli (Rod form) - 800
    B. Coli (Filterable virus) - 1552
    Bacillus X (Cancer - carcinoma) - 2128
    Bacillus Y (Cancer - sarcoma) - 2008
    Gonorrhea - 712
    Pneumonia - 776
    Staphylococcus Pyogenes Aureus - 727
    Streptococcus Pyogenes - 880
    Syphilis - 660
    Tentanus - 120
    Tuberculosis (Rod form) - 803
    Tuberculosis (Virus) - 1552
    Typhoid Fever (Rod form) - 712
    Typhoid Fever (Filter passing) - 1862
  • orgonaut314
    By the way Rife used 3,2MHz and harmonics for his cancer therapy? I'm still reading this. Rife ended up using tubes with electrostatic fields at certain frequencies. Light did not work. In fact he was using Tesla technology.
  • orgonaut314
    Tesla:
    Thus, everything that exists, organic or inorganic, animated or inert, is susceptible to stimulus from the outside. There is no gap between, no break of continuity, no special and distinguishing vital agent. The same law governs all matter, all the universe is alive. The momentous question of Spencer, "What is it that causes inorganic matter to run into organic forms!" has been answered. It is the sun's heat and light. Wherever they are there is life. Only in the boundless wastes of interstellar space, in the eternal darkness and cold, is animation suspended, and, possibly, at the temperature of absolute zero all matter may die.
  • orgonaut314
    Originally posted by James Barker View Post
    orgonaut, what frequency were you using?
    Close to 3,1 MHz but I'm feeding it square waves now so probable there are harmonics too. I had a good feeling with this coil because Lakhovsky used 30cm rings around plants and my topring is something like 25cm. I guess that if I'm generating frequencies they are close to the frequencies that Lakhovsky found out to originate from the sun. So I guess we should aim at this 30cm end ring and build the rest from there? We are of cause being from the sun. Tesla wrote everything is filled with living aether but the sun wakes the aether into biological live.
  • Sputins
    Congratulations!
    Plus, congratulations to Eric Dollard & his team for hitting the $25,000 goal on the crowdfunding effort!
    Unbelievable! Congratulations to all the campaign donors and organisers! It brings a happy tear to ones eyes..
    Sputins.
  • James Barker
  • orgonaut314
    One small scientific result with my secondary Tesla coil. I had the flue this week it was very serious. Normally it would take me two weeks at least to recover. Well this time in front of the longitudional oscillating Tesla/Dollard coil I needed one day! Part of the day I was asleep, a few hours in front of the coil where enough. The next day I was feeling well again and I didn't needed tissues anymore. I needed a lot of them during the day. Now I'm still recovering but I call this a scientific proof that this coil in the right oscillating mode is killing viruses pretty damn sure
    Side note. We do not use pulses and not even high voltages. The electrostatic mode is also clearly not screened through the water in my body. This coil is making aether waves that penetrate me like solar aether. The viruses can't stand these frequencies that why they parasite on me to get energy. My body gets stronger with these frequencies.
  • dR-Green
    Originally posted by Tesla_Bcn View Post
    Dear Aaron, Dr-Green and specially T-Rex.
    In Spain we are planning to replicate Eric's famous vintage experiment, that was replicated in the Summer 2013 Conference. Our main goal is to achieve a source of truly Longitudinal Electricity.
    Our first step should be to replicate the Fischer Diathermy Machine (we can not afford to buy one), but in the schema that we see in this link, there's something that we would like to confirm, and please apologize if what I gonna say is a non-sense or it's been said before (I did not find it).
    The main question is with the first HV transformer in which there's some question's that come up to my mind when I first saw it;
    ¿ Is that copper strand what is used in the two secondaries of the first transformer? ¿ Bifilar or normal? If it's that the case, then it should be reasonable to think in a considerable self-capacity which would make that transformer to resonate in a low frequency, as well as to increase the longitudinal effects ¿ Do they both aspects sound reasonable?
    ¿ Is that 5 Kv output ? The guy in the video said 2,5Kv. He also said that in the next step, the Tesla Coil, there's 90 turns in the secundary. If it's that the case, and there's 7 turns in the first, then we should expect a higher voltage output of 60 Kv. ¿ Which output voltage (non-specified) does the FD deliver?
    ¿ How much is the top resistance in the variable reactor?
    Waiting for your answers.
    Thanks from Spain.
    Hi Tesla_Bcn, I had nothing to do with that so I can't answer your questions I'm afraid, hopefully Smokey can help you out, or maybe Spokane1 if he's around.
  • David G Dawson
    Hello tgraca,
    "My favorite living rooms until now have had pool tables in them... I am now convinced that coils in my living room is the way to go! Thanks for posting!"
    Thankyou for posting that back up.
    Actually this is the Granny Flat where My Wife's Parents resided before passing on.
    I now have control of the area (I built it) and this is the first annexe (full of Vacuum Tubes) and the verandah is the second.
    The main room, the bedroom, is chokkers full of similar equipment including all the GLOM and a sight to behold and contains the actual workshop.
    Have been absent here on rainmaking duties and will be back soon with pics of the new devices - these are both 'BIG GUNS' after Reich and Foley and are better representative of my challenge with rainmaking in that I am not mobile and my earlier devices needed mobility (possibly) to be active during severe conditions as we are now facing.
    I would never encourage anybody that is married to take over the lounge room for experiments like these, unless, of course!
    Actually, Mum just offered me the Lounge Room in the BIG house which we don't really use but I graciously declined.
    Tesla Bcn,
    Don't think you will get a reply from Eric but will help best I can as I am also into Diathermy, research at least.
    Give me time to catch up with your questions and will respond shortly.
    Recording the video now and have a similar setup in my files - excellent video.
    See the violet blue - that's cold Female.
    Good stuff!
    Smokey
