This is a sticky topic.
  • Kokomoj0
    You mean the boat? There's no way he'd have the boat working at that distance using the configurations he shows. He has missed the fundamental part of the whole thing - the ground. In 7 mins of the 2nd video he explains:
    Meyl - Scalarwave-Technology - The european website of www.k-meyl.de
    "No battery, no earthing line, but only have water as the way back to the earth"
    The 2nd image here is in direct conflict with the Tesla patent shown right above it:
    SmartLINK
    They are right outside the window with the transmitter right next to it. And where is the ground connection as shown in Tesla's patent?
    Do you believe that his transmitter is having such an effect upon the earth that it will transfer through the ground, up through his puddle of water and power that motor? He's just using the puddle as a virtual ground, just like you can do with an Avramenko plug. The coil (metal) would make a nice antenna for an improved effect over more crude AV plugs, and the puddle of water would make a nice virtual ground. You can place whatever you like there, be the "ground" yourself if you want. But I don't believe for one second that his system is receiving the energy via the ground, or via the water.
    And here the same again:
    Transmission of Power Without Wires (Scalar Waves) - YouTube
    My opinion on it is that this is SEC exciter territory, not Tesla's wireless transmission.
    [edit] As far as energy through water is concerned, the sea is obviously a part of the earth and it's all connected. So Meyl seems to have simply cheated by making the water the virtual ground, and receiving the energy through the top terminal instead. According to the correct theory, he should be able to simply plug loads directly into the water and they will power up, things such as an incandescent bulb. But I don't think he will be able to do that.
    well tesla intended to power airplanes as well though
  • dR-Green
    Originally posted by Kokomoj0 View Post
    didnt he say they were 60+ meters apart at glauscau when they tested?
    SmartLINK
  • Kokomoj0
    ?? I haven't seen Meyl demonstrate anything of significance. His description of the boats even sounds wrong. I'd like to see his boat working 10 metres or more away from the transmitter using his proposed method.
  • jake
    @kokomojo
    "yup and I said that many moons ago and was shunned for it LOL"
    What page did that happen?? I think that might be the answer to my current question.
    @garrett
    I need to read your post again at last two times
  • dR-Green
    Now we can take that one step farther and again look at Meyl, regardless how many stones people wish to throw at his work its very hard to argue with success, at least you cant argue too much.
    Meyl is in th e build stage not theory and has shown this to work real time. Now unless he is flat out lying about the measurements has claimed to get more at the receiver than he was transmitting.
  • Kokomoj0
    a tank circuit is exactly like this:
    Making standing waves
    when you reach f0 the the reactances create a null and look to the circuit like a pure resistance you get the highest waves.
    I pointed out in this and other threads that theic can be measured by either a real meter or a simple make shift VSWR meter by tapping into the circuit.
    The old timers have done this since the invention of dirt.
    more
    Standing Waves
    which takes up to wave phase:
    Wave Phase
    interference
    Wave Interference - Wave Pulse
    Electric Fields
    Capacitors
    Electric Currents - Magnetic Fields
    this is what I explained that everyone forgets when talking about the "impulse". the relationship between V I and time
    Transformers - Power Transmission
    finally
    RC Circuits
    LR Circuits Theory Part 1
    LC Circuit - YouTube
    LC Circuits Theory Part 1
    LC Circuits Example 1 Part 1
    LC Circuits Example 1 Part 2
    LC Circuits Example 1 Part 3
    LC Circuits Example 1 Part 4 The End
    AC Circuits Example 1 Part 1 - YouTube
  • Kokomoj0
    Originally posted by garrettm4 View Post
    Jake,
    There are NO inconsistency of terms with what Mr. Dollard has given or even the terms used today or 100 years ago. The problem isn't the terms or definitions its personal comprehension of their significance.
    Per Farad is the reciprocal of the Farad. If Farad implied an imaginary conductance per unit time then a Per Farad would be an imaginary resistance per unit time. Its that simple. It all comes down to understanding what a reciprocal means in the physical world we live in, not in the imaginary world of math. People should focus on CRITICAL THINKING and not DEEP THINKING.
    Per Farad literally means 1/F and the same goes for Per Henry 1/H. Farad literally means F/1 and the same for Henry H/1. We usually don't write things in this context but when doing dimensional analysis it becomes simpler to do it this way. The terms Henry and Farad are usually replaced with L and C for simplicity. Mr. Dollard uses the actual name to give a more meaningful conversation, but at the same time it is a language barrier for those who aren't familiar.
    All of this comes down to understanding the "NORMAL" circuit orientation of the arbitrary element in question. This is seen as SHUNT (or PARALLEL) and SERIES arrangements. Capacitors, enductors and conductances are shunt elements, inductors, elastors and resistors are series elements.
    If we place a capacitor in a series arrangement it no longer acts as an imaginary conductance per unit time (capacitive-susceptance), it now is an imaginary resistance per unit time (capacitive-reactance). The same goes for an inductance, if we place it in shunt we now have an imaginary conductance per unit time (magnetic-susceptance), not the original imaginary resistance per unit time (magnetic-reactance).
    The capacitive and inductive elements are conjugate to one another, their vector forces rotate in opposite directions, if the capacitor acts as a small imaginary resistance and then becomes a large imaginary resistance per unit time, then an inductor acts as a large imaginary resistance then becomes a small imaginary resistance per unit time.
    Stated in another way inductive reactance starts out large and then goes small, capacitive reactance starts out small and then goes large. The same goes for the opposite of reactance, susceptance.
    that is correct and that is not another way but the way for a steady state input. (DC) the rest starts sounding like gobblety gook.
    Keep in mind that second semester electronics they teach you all about phase angle. The imaginary number system handles the addition and subtraction etc of different phase angles.
    Reactance is always a vector sum at some phase angle other than zero. Hence it has a resistive "effect" and properties.
    A pure resistor has zero phase angle
    The reason the above explanations are meaningful and correct is from the fact that IMAGINARY RESISTANCES AND CONDUCTANCES STORE ENERGY (AND CAN RETURN THAT SAME ENERGY). Thus as a capacitor gets "full" it can't allow anything to flow but at first it acted as a dead short, the opposite is true with an inductor at first it impedes the flow of current because it is building a magnetic field, as the field is built and expanded the current is then progressively less restricted in its flow and reaches its maximum when the field is fully expanded.
    One problem I will admit that exists, is the fact that there are MULTIPLE self and mutual inductions of the dielectric and magnetic fields in any given circuit. The root of the problem comes from the fact that the naming of these various direction and situation dependent inductions sometimes overlap and cause a lot of confusion. I will give more details on this later.
    I hope this hip-shot explanation (I'm strapped for time at the moment), can serve as a meaningful (albeit lacking) explanation to your question.
    Garrett M
    well not exactly.
    a magnetic or dielectric field is essentially the same as a dc potential. When that magnetic field is collapased you get the energy, and likewise when the dielectric field is shorted or bridged. until it is in a condition to be kinetic is little different than a charged battery waiting for something to be connected.
    I said many posts ago that all this per stuff is the same as 1/x and I did not see the value in calculating it in the opposite quadrant since it is a mirror image anyway.
    Eric nor anyone else responded to that. So if there is a significance to it its is lost to me because that and several other points made have went unexplained that I asked about. Oh well....
    Worse I started to listen to Erics audios and was forced to turn it off when he started about going backwards in time. So I have been very quiet waiting to see where this is ultimately going to go.
    No other working theory with that regard has been proposed or demonstrated that I can see at this point. Meyls has put out a theory as to why this happens and I have not seen any theory here refute Meyls functionally. So I am left shrugging my shoulders.
    Maybe I expected too much, but I have to admit I expected to be looking the holy grail square in the face and have not had the pleasure of that expectation.
    Lots of great theory but sadly nothing that crashed any of my einstein education yet.
    But I have hope that maybe something is forth coming.
  • boguslaw
    Fish do not think about water, man do not think about field he is moving in. Only those fishes who surf on water surface jumping into air see difference.
    Slap field with transient and it will behave like solid wall. That's how I understand it.
  • garrettm4
    Q & A
    Jake,
    Garrett M
  • jake
    Jake,
    1) L, Leakage Inductance
    Q - "The big magnetic fields that push our motors?"
    A - My answer would be a resounding NO, leakage inductance can only store energy it CAN NOT TRANSFER ENERGY, thus it would only act as an IMPEDANCE and not as an ADMITTANCE required for the electrical to mechanical transfer of energy to create motion in a motor. The leakage inductance is the exact thing we try to get rid of when designing a motor, and is not something we usually want. There are times when a small leakage inductance can be helpful, this is only when there is a short circuit and the impedance of the leakage inductance prevents catastrophic failure by LIMITING the current of the short circuit.
    2) M, Mutual Inductance
    Q - "Energy stored in counterspace/innerspace?"
    A - Magnetic energy as explained by Mr. Dollard is stored in Normal Space, not the "counter space" as explained by him. Mutual induction of the magnetic field is that which transfers energy in-between two separate coils, there is no storage of energy here, only the transfer of energy from one distinct coil to another. This topic can be found to yield many interesting and practical insights, but I will leave this subject for another time.
    3) C, Leakage Capacitance
    Q - "The field created by an electrostatic generator, or in a vacuum capacitor?"
    A - Inside the vacuum capacitor there is NO LEAKAGE CAPACITANCE, this is normal SELF CAPACITANCE, although if at high frequency, when small capacities are physically meaningful, there is a leakage capacitance associated with the vacuum capacitors outer plate to ground (or any and all surroundings) (and on the topic of high frequencies, EVERYTHING has an associated leakage capacitance). Furthermore, only "quantum physicists" think a vacuum capacitor operates differently from any other capacitor type, at the end of the day there is little to NO difference, aside from the SPEED of DISCHARGE (which is due to permittivity affecting the manifest "velocity of light"). The electrostatic generator is a highly complex induction machine which converts mechanical energy (or seemingly this is the source) to electrostatic potential stored in a condenser. There may undoubtedly be a leakage capacitance associated with the electrostatic generators operation, but don't try to fool yourself into thinking that (leakage capacity) is the only thing going on during operation.
    4) K, Mutual Capacitance
    A -ALL DIELECTRIC ENERGY IS CONSIDERED AS A COUNTER SPATIAL ENERGY. Thus, the storage of dielectric energy is greater when there is MORE counter space for the energy to occupy. This can be looked at as the RECIPROCAL of SPACE or a "large space" divided into the "unit" (1) is an equally large "counter space". This is seen in the design of a capacitor, the closer the plates are the more "storage" or "capacity" the capacitor has, it's that simple.
    5) Bonus Question on Capacity of a Wire
    Q - "On a 20 secondary with spaced windings does approaching the coil with your hand increase its mutual capacity K, or its self capacity C??? but before you answer think what would happen if you had a long straight wire and could measure it's C. What would happen to the meter if you approached the wire?"
    A - This is an interesting question and the answer is dependent upon perspective, how do you plan to measure the capacitance? This question answers your question but doesn't really give an answer, so lets work our way through this. First, ALL METALLIC SURFACES HAVE A DEFINITE CAPACITY REGARDLESS OF BEING REFERENCED WITH ANOTHER METALLIC SURFACE. When we measure a capacity we usually place TWO metallic surfaces of interest as close together as possible, we unwittingly try to make lumped elements. When considering a distributed capacity we generally can no longer use the methods and understanding of lumped elements, here lies the problem of measurement, how do we measure only one surface? Well there are techniques to do this but are beyond the scope of your question and my answer. So more to the point, the measurement of capacity is a problem of reference and THERE ARE MULTIPLE CAPACITIES ASSOCIATED WITH THE WIRE IN YOUR QUESTION and consequently multiple answers. An outstretched wire will have a greater "free-space capacity" while the coiled wire will have a greater self capacity to any-one object. Moving your hand closer increases C (leakage capacity) not K (mutual capacity). K is when there are multiple C's that are mutually connected with one another, or MULTIPLE separate metallic surfaces linked via dielectric flux, this in the secondary is seen in-between turns.
    Garrett M
    Thank You very much for your time and answers. I think the biggest road block is consistency of terms.
    For example mutual capacitance K and mutual inductance M. Eric has units of per Henry and per Farad for these terms.
    Do these units agree with your statements?
    i.e. when you talk about mutual inductance M, according to your definition is it in units of per/Henry.
  • Web000x
    I can help seed it for a while if you make a torrent.
    For those wanting to download off youtube, this is a good program. You just copy the youtube link and it will automatically decrypt the url and present you with a list of files to select from, all the different quality versions of the video, flv, mp4, mp3.
    JDownloader.org - Official Homepage
    Otherwise Internet Explorer 6 does the job nicely. Just wait until the video streams and copy the file from Temporary Internet Files It's not quite as easy with the newer versions.
    I will be making a torrent file as soon as I get the PowerPoint presentation onto my computer. It arrived today. I should have this available some time next week.
  • wyndbag
    Standard physics to the extent that I have surveyed it seems to have ended with Dr. Feynman and QED. Feynman undoubtedly capable of formal calculations wound up inventing Feynman diagrams to simplify things. Eric D. has made a similar sort of suggestion somewhere of making up a new sort of math to try to tackle his problems.
    Tesla seemed to work mainly from intuition which was fine as far as his inventing went, but it does not help others who are less intuitive or insightful carry on his work.
    Eric D seems to be attempting to synthesize Tesla, Steinmetz and Heaviside ...
    which is all fine and good...but how many genius kind of people have the background and or the ability to tackle such a load?
    I respect and honor anyone who can take on such heroic lifting and can only stand on the sidelines and hope to see the fireworks unfold. Thanks for your efforts.
  • madhatter
    That is an interesting statement, which is not entirely true at the fundamental level, IMHO.
    Let's first go back to what Eric said some time ago:
    Fundamentally, you need some kind of momentum in order to have oscillation or wave movement trough the medium, yes. However, that momentum does not HAVE to be magnetic in nature. That is, there is no need for the momentum to be of a ROTATIONAL nature, as is the fundamental nature of the magnetic field.
    In other words: the inductance we work with, the magnetic inductance, is NOT a fundamental property of the aether. There is a more fundamental kind of momentum, which somehow gives rise to the magnetic momentum by means of some kind of rotational propagation. And when we are considering the magnetic momentum as a fundamental property of the aether, we are overlooking this more fundamental, non-rotational momentum, which is why we cannot find periodic solutions to longitudinal dielectric motions. There IS another energy we need to consider...
    From what I've been able to work out, there isn't another energy it's the geometry of the 'director' and a function of the period that gives rise to L,C and the rest.
    a single line will have inductance and capacitance and resistance all as a function of the frequency, looping the line upon itself changes the topology and geometry of how the dielectric is transformed into our dimensional plane. The wave phase velocity is part of the key as to why this is. 'insulators' are the conductive or attractive medium of the dielectric and the metallic elements are the 'directive' or guiding medium for the dielectric field. The magnetic field is a result of the wave group moving thru any dimensional plane. the time invariant nature is due to that the dielectric field has no vector quantity, whereas any dimensional plane the conductors and directors are in do. The geometry and topology are key.
    the problem I've seen so far with the math is that it tends to fall back to Newtonian or wave mechanics. quantum physics has this problem as it dragged F=MA into E=MC^2. C is a constant not a fundamental limiting unit.
    I have reservations about the term 'momentum' as it conjures up a mass equivalent or mechanics involved where there is none in the dielectric field. conducting and directing the dielectric in our dimension will effect those mediums, now the tricky part or possible circular term arises because of the wave nature of everything. The structure of matter is a result of the dielectric fields interaction in the 3dimensional manifold.
    gotta run, more later tonight..
  • Geometric_Algebra
    Perrine Liberation
    Anyone with a copy of the text “Physics and Mathematics in Electrical Communication” that would like to help me 'liberate' it's contents should send me a message so we can organize a division of labor.
  • dR-Green
    Originally posted by Web000x View Post
    I'll see if I can put a torrent file together. Or if somebody has some ftp space available to the tune of about 2 GB, P.M. me and we can work something out.
