This is a sticky topic.
  • Kokomoj0
    Originally posted by QuarterPole View Post
    Yes to primary and secondary. **Actually, maybe not, I'm currently reading Colorado Springs Notes, and I'm at October 8, 1899: "Now the length of wire in the secondary was 803 meters, namely 17 turns each of a diameter of 15 meters."
    So the fence could even be a secondary. I haven't read anything yet about an extra coil that big, though, mostly the extra coil is wound around a barrel... Reading on: "The total length of wire in the extra coil circuit was: the extra coil itself 889 meters, namely 149 turns each of diameter 1.9 meters plus special coil inserted in series: 307 meters, namely 160 turns each of diam. of 0.61 meter. This special coil was used when the ball on top was not employed as capacity and the coil was so adjusted that the vibration was the same without the ball as with the ball and without the special coil ... The total length of wire was therefore: secondary + special coil + extra coil = 803 + 307 + 889 = 1999 meters"
    So, in that picture, he could very well be sitting inside the secondary and under the extra.
    The magnifying effect adds up to high "pressure" at the top of the coil. He did increase spacing to avoid sparks within the coil. This is explained in Colorado Springs Notes. He studied the effects of capacitance, and offers math to estimate same in a coil. He does a lot of math to estimate frequency, and to make sure each element was in tune with the next. He also had a small adjustable coil before the primary, which he used along with the jar capacitors to tune it to the secondary.
    Tesla tried every combination he could think of. Different coils and capacitors in series and parallel. The extra coil was often added to the end of the secondary, but not always. He rewound the extra many many times.
    The book, Colorado Springs Notes, is full of equations and diagrams, I cannot recommend it highly enough. That sphere is out of place, though... It's not big enough to hold all the sparks in
    yeh me too, I am reading it as well. Its always interesting to see how much ya got right and how much ya got wrong LOL I am not keeping score though HAHA! Good info thanks....
  • Kokomoj0
    There is NO TEM. Everything in this system is longitudinal. Why do you think the transmitter is monopolar, only connecting to the ground?
    sounds like Lamare then would not need to be too concerned about the feed line to the sphere. I raised that question in his moonshot thread.
  • QuarterPole
    It seems that "the long coils of popular design" have combined the secondary and the extra into one unit, while Tesla seems to say that the extra and the secondary should not be inductively coupled.
    June 18, 1899
    Experiments were continued with the oscillator showing that proper vibration does not take place, evidently owing to some cause which is still to be explained. To see whether the trouble is due to poor induction from the primary, a coil-wound on a drum of about 30" diam, 10" long, 500 turns approx. of No. 26 wire, used in some experiments in New York -- was connected to the free end of the secondary and with this coil a great rise was obtained, streamers about 12" long being obtained on the last free turn even with a small excitation of secondary. The trouble seems to be due to internal capacity. The total length of a quarter wave with coil was about 2400 feet, which agrees fairly with the calculation from the vibration of the primary circuit. The experiments with the coil show strikingly the advantage of an extra coil, as I call it, already noticed in experiments in New York; that is, a coil practically not inductively connected but merely used to raise the impressed electromotive force.
  • t-rex
    Oscillating Current Transformer
    The oscillating current transformer
  • QuarterPole
    I think the issue is the joule/watt confusion. Here's how I have it:
    Watt = Joule per Second
    Joule = Planck per Second
    Planck = Psi * Phi
    Psi, ψ = dielectric induction, lines of force
    Phi, ϕ = magnetic induction, lines of force
    (E and I and e and i)
    Displacement current, Ampere, I, Coulomb per second.
    Electromotive force, Volt, E, Weber per second.
    Magnetomotive force, Ampere, i, Weber per Henry
    Electrostatic potential, Volt, e, Coulomb per Farad
    You, Logical_American, are very much correct in understanding that there are complex numbers involved. When I said my experience in math was limited to "one imaginary layer", I wasn't just throwing words around. In Symbolic Representation of the Generalized Electric Wave, you will find the symbol k, which makes i/j look like kid stuff.
    k^1=k
    k^2=-1
    k^3=k^-1
    k^0=+1
    "The symbol k^n is a versor operator where k is the axis and n is the amount of turning arounk the axis k. Since the rotational unit in this case is π/2 or quarter cycle the symbol is more correctly given as k sub 4 to the nth"
    "Thus the quadrantal versor operator k sub 4 to the n serves as a fundamental symbolic representation of the alternating electric wave"
    I think it's important to note that everything is symbolic. You can take a guass meter and measure a magnetic field. Now you now that if you move a given conductor through that field at a given speed, you will have such-and-such an emf. All of our existing definitions are symbolic and circular, because we do not properly understand what a magnetic field IS. We define it by its effect, and because we can't SEE what the field is made of, we just kind of ignore it. The ether got "disproved" and we are right back to "spooky action at a distance."
  • madhatter
    From what I see Eric is stating that Phi & Psi are algebraic Versors not Vectors or Scalars. And most certainly not Quaternion Versors of spacial relation. This is probably the biggest hurdle for those with a physics background.
    It's difficult to not automatically assume they are vectors and treat them as such. Also it's difficult to avoid the 4th dimensional association that Eric if I understand him correctly warns against.
  • Logical American
    Reply to Pault's Question
    Pault:
    Here's the exact quotes and timestamps: (note one post is by Sputins)
    2011-August-22 03:40 pm
    Continuing then it has been given that the total electrification Q is the union, or product, of the total dielectric induction Psi and the total magnetic induction Phi, Psi times Phi equals Q.
    2011-August-31 02:41pm
    Electricity is embodied in the aetheric state of matter, or “proto-matter”. Electricity is aether in a state of dynamic polarization; magnetism is aether in motion, dielectricity is aether under stress or strain. The motions and strains of the aether give rise to electrification. Phi times Psi gives Q.
    2011-August-31 03:12pm
    Question by Sputins
    If total eletrification Q = Psi . Phi
    Or the total eletrification Q = Total Dielectric induction, times the Total Magnetic induction.
    (showing what he understood, which is my present understanding also)
    2011-September-16 05:59 pm
    Given thus far is the product of the magnetic induction, Phi, and of the dielectric induction, Psi, giving forth the total electric induction, Q.
    Sorry, if by "restated" you took it to mean that is exactly what Eric said, that is not true as you have suspected. I was trying to encapsulate in math equations what Eric was stating along the way as he presented his ideas.
    When I said 1 Planck = 1 Psi * 1 Phi, it assumes that they have magnitude, because at this moment of time I have no better idea to go on. I am trying to address questions as I started from the very beginning of Eric's posts, so that people could see the struggles that a person will have when picking up this new material.
    Thanks for your question, I hope that I have answered it.
  • QuarterPole
    Originally posted by Kokomoj0 View Post
    So I presume that fence is a huge primary magnetizing coil, the one he is siitting under is the secondary, and the center which is that same height as the secondary I presume is the extra "tesla" coil with the sphere on top?
    @Eric
    is the secondary wire spacing that gets wider toward the top because of poor insulation and high voltage or is that some kind of tuning?
    both? From what you are saying it sounds like we would want that secondary to be close wound and also the extra tesla coil with the sphere on top to be close wound? The primary I remember you mentioned using strap bronze for good impulse response.
    Maybe I should be asking what we are all looking at in that pic That sphere almost looks out of place? and the center does not look like coil but a pipe. Like the center of a transmission line?
  • t-rex
    Originally posted by mikrovolt
    T-rex, I understand your situation with the computer frustration,
    this does help explain why the communication lag.
    Will the Viktor Schauberger repulsion system add significantly to the
    non-pollutant energy ?
    If so were does a person begin to assimilate the Schauberger repulsion device ?
    what is the notation for torque as it relates to this ?
    I know nothing about Schauberger, sorry
  • t-rex
    It would be great fun to be able to measure more power coming out than put in. I believe to do that one must ideally completely null the TEM side.
    That said what I am really looking for in the final analysis is tips on how to remove all tem transmission completely from the system and only transmit LMD. Maybe you have given me enough information that I should have picked up on it already and fail to see it at this point, if so please simply ignore this.
  • Kokomoj0
    Originally posted by OrionLightShip View Post
    Actually I was speaking about the secondary.
    Orion
    I had to read that a couple times myself.
    I think he is talking about each?
    Generally you do not want to create inter-winding capacitance, that lowers the impedance and lowers the voltage and in some cases lowers the magnification factor. (end)
    Secondary
    In the primary you want the lowest capacity possible. (end)
    Primary
    That's why Tesla used coils of equal width and height. (end)
    Both
    If anything litz wire decrease capacitance.
    It creates less flat plate area.
    Can we think of that as similar to the flat wound amature transmitter coils?
    does any of that sound right?
    So do I read it correctly that we want Hi Z, Low inter-winding C, because that will result in higher magnification?
    I am still plugging away on a couple things in his response to me too.
    @Eric
    is the secondary wire spacing that gets wider toward the top because of poor insulation and high voltage or is that some kind of tuning? both? From what you are saying it sounds like we would want that secondary to be close wound and also the extra tesla coil with the sphere on top to be close wound? The primary I remember you mentioned using strap bronze for good impulse response.
  • madhatter
    Originally posted by pault View Post
    Please point me to the exact point in Eric's posts where this is "restated".
    Thank you
    pt
    back in 8/22/11
    Originally posted by Trex
    Continuing then it has been given that the total electrification Q is the union, or product, of the total dielectric induction Psi and the total magnetic induction Phi, Psi times Phi equals Q. In other words, the dimensional relationship Q, the total electrification, is the product of the dimension of total dielectric induction Psi, and the dimension of total magnetic induction Phi....
  • pault
    Originally posted by Logical American View Post
    NOTE: In attempting to understand the new material presented, I backed up (as one person suggested) and read all the posts from the beginning of the thread and have carefully collated some equations as they are serially presented.
    It is restated:
    1 Psi * 1 Phi = 1 Q Plank watt-sec^2
    Thank you
    pt
  • OrionLightShip
    Orion
    Generally you do not want to create inter-winding capacitance, that lowers the impedance and lowers the voltage and in some cases lowers the magnification factor. In the primary you want the lowest capacity possible. That's why Tesla used coils of equal width and height. If anything litz wire decrease capacitance. It creates less flat plate area.
  • t-rex
    NOTE: In attempting to understand the new material presented, I backed up (as one person suggested) and read all the posts from the beginning of the thread and have carefully collated some equations as they are serially presented. There are important questions to be addressed, in attempting to satisfy Fourier's principle of dimensional homogenity for the equations and qualities presented.
    Furthermore, I just now found out that new posts have arrived, before this post could be presented, I don't know what to do about that, as it is frustrating to establish a serial thread here.
    Heaviside Equation:
    (1) (R*G + X*B) + i*(X*G - R*B) = propagation constant^2
    Note: This is a complex product of (R+iX)*(G-iB) or (X-iR)*(B+iG)
    Physical Quality Dimensional Units
    R = Resistance in Ohms ?
    G = Conductance in Siemans 1/?
    X = Reactances Henrys/second ?/sec
    B = Susceptance Farads/second ?/sec
    R*G is scalar or DC component (dimensional units in R and G are reciprocal)
    X*B is longitudinal or AC component
    X*G is transverse or OC component (forward moving)
    R*B is transverse or OC component (backward moving)
    A post says that male is dielectric field in counterspace (/cm) and female is magnetic field (cm^2)
    (we have mismatch of units, one is /cm the other cm^2, so which is in error?)
    (2) Dielectricity * Magnetism = Total Electricity Q
    What is the product * mean here? dot product? cross product? complex product? as it is not yet well defined in the dimensions.
    A post defines Q as Planck as watt*sec^2 not as NIST (conventional) joule-sec.
    Energy is the usage of Q/second = watt*sec which is our standard understanding
    (3) E = dQ/dt in conventional terms where Q is total electricity (not charge!)
    1 Planck/sec = 1 watt-sec (answering the question of how many Plancks/sec are in a watt-sec)
    The dielectric field density must equalize the magnetic field density to equalize forces.
    But forces is a term introduced but not defined, nor is its relationship to either field density shown, just implied.
    Is this a physical force? field force? measured by weight units? Ambiguous and undefined at the moment.
    Important idea: Counterspace or Reciprocal Space (fractal space) 1/n
    i.e. 1/cm is less counterspace than 1/nanometer per unit length
    A post supplies a familiar analogy, stopping a car with F = m*a and it specifically says that a is dV/dt (which it is)
    (4) F = m*a = m * dV/dt (where F is force, m is mass, and a is acceleration)
    Then the analogy is presented that dQ/dt = W (energy)
    (5) W = dQ/dt (but what happened to mass or space?, by analogy to (4) )
    We appear to have something missing in (5) in regard to space being acted upon by the change in total electricity during a time interval. What is it?
    A post criticizes the time integral of W dt = Q.
    The neglecting of C (the constant of Integration) is problematic here, perhaps detrimentally so, because C might well be some amount of total electricity. Furthermore integration is totally unable to say anything about the original quantities to start with, so it appears valid to differentiate, not integrate, in order to not lose anything valuable under consideration.
    A post states that it only takes 2 quantities to specify the volume of a cylinder: height and circumference.
    Was diameter or radius meant here, not circumference?
    Mathematicians note that the formula is
    (6) Volume of a cylinder = height * area = height * Pi * radius^2
    This has dimensions of length^3, since height is length and radius^2 = length^2, so we cannot escape 3 dimensions.
    A post then states that:
    (6) Psi (dielectric induction) * Phi (magnetic induction) = Q (Planck) watt-sec^2
    (we still need to define * operator here, and formalize the units for Psi and Phi)
    A post argues 4 basic units for Electrical Engineering:
    1. Time t dimensions:1
    2. Space s dimenions:3
    3. Dielectricity Psi dimensions:? 1/length
    4. Magnetism Phi dimensions:? length^2
    We need to resolve ambiguity on 3. and 4. for length so they mutually cancel on their product (whatever that is)
    (7a) d(Psi)/dt = I (amperes) displacement current flow (not conduction current)
    (7b) d(Phi)/dt = V (volts) electromotive conduction volts (not electrostatic)
    It is stated:
    (8) Phi/Psi = Z (impedance) in Ohms (E/I = Z)
    and Inversely
    (9) Psi/Phi = Y (admittance) in Siemans (I/E = Y)
    Two distinct I currents and two distinct V voltages are mentioned.
    Important Question:
    Define I displacement current and I conduction current?
    Define V electrostatic field and V electromotive difference?
    I believe that it is very important to properly define these two types of physical qualities. Can this be done at this time?
    It is restated:
    What are the dimensional units for Psi and Phi ?? Do they have dimensionality of watt^(1/2)*second ?
    And again, in regard to watts, that it is
    W = dQ/dt (joule or energy)
    We need relationship of watt to joule defined. Later on we find watts cannot be = joules as the dimensions do not match. NIST defines watt as joules/sec so watt-sec^2 = joules*seconds
    Does Planck have dimensions of joules*seconds? There appears to be ambiguity in using the term joules and watt-sec^2. Can this be resolved for everyones' understanding?
    A post defines:
    Coulomb (charge) Psi = Q/Phi
    Weber (induction) Phi = Q/Psi
    What are our units here?
    Can we mathematically say that
    dQ/d(Phi) = Psi (instantaneously)
    dQ/d(Psi) = Phi (instantaneously)
    so that
    E = d(Phi)/dt (as above) unit: volt
    I = d(Psi)/dt (as above) unit: ampere
    However the two types of voltage and current are still ideas, not formally defined.
    A post resummarizes:
    Group 1 (primary)
    Q Planck (watt-sec^2)
    Psi Coulombs ( ?/sec )
    Phi Webers ( ?/sec )
    W joules (joules ?? watts? ) (This has to be watts, not joules)
    Group 2 (derived)
    E Volts ( ??/sec ) or d(Phi)/dt
    I Amperes ( ??/sec ) or d(Psi/)dt
    What about the two types of E and the two types of I ?? Can we
    define them properly?
    (This seems to be hinting that we need complex numbers to adequately
    describe what is going on)
    joules/sec = watts (so there is a mistake equating joules = watts above)
    It is pointed out that humans overlay space with dimensions. (usually 3)
    Positive Space
    length = cm^1
    area = cm^2
    volume = cm^3
    hypervolume = cm^4
    N-volume = cm^N
    Reciprocal (Counter) Space
    span = cm^(-1)
    density = cm^(-2) (density is usually thought as volumetric)
    concentration = cm^(-3)
    diffusivity ? = cm^(-4)
    N-diffusivity ? = cm^(-N)
    A post gives:
    l^3 * Q = Planck cm^3
    l^2 * Psi = Coulomb / cm^2 (so l^2 cannot be right, it has to be l^(-2) )
    I stopped at September 30, 2011 12:19 pm posting, as there are questions that I have above that need to be addressed, because of the confusion in dimensional homogenity. Can they be addressed?
    Later on I suppose a discussion of mass (kg or grams) might be brought in, but it is okay to ignore mass for now, since none of the material above, except for implied force right after equation (3) above is mentioned.
    NIST carries the base units (qualities):
    1. length (m/cm)
    2. mass (kg,gm)
    3. time (sec)
    4. electric current (Ampere)
    5. temperature (K deg)
    6. amount of substance (moles)
    7. light intensity (candelas)
    For now, I will leave discussion of mass aside, and we notice already that item 4. electric current is in trouble, because it avoids the discussion of what type of flow it is, displacement current, or conduction current, which are totally dissimilar.
    We probably don't need to talk about temperature, nor Avogadro's constant, and light intensity is probably energy projected onto an area, so it probably is not as base unit and should be removed. After all, we do have materials absorbing energy in other frequency bands than light.
    - Randall
    You have just taken all the work I have done in deriving new dimensions and tried to convert them back to physics dimensions. You want to go back to physics. I just got done going through 40 papers to get physics out of this! Heaviside and Steinmetz didn't go through all this trouble to turn it all back around again. Are you sure you know what dielectricity and magnetism are? Physicists have no business in dealing with this sh**. I derived a system of units that stand by themselves. Use the units I have derived NOT physics units. Physicists have no idea what electricity is- they don't even believe in the Ether!
