This is a sticky topic.
  • Raui
    Thanks for your transmission Eric!
    Originally posted by Pinwheel View Post
    I'm pretty sure Raui's forum signature is of use.
    It's the artistic realization of a particular canon of Bach's. See Bach: Endlessly Rising Modulation Canon (with score!) - YouTube for the particular canon. The idea is discussed in greater detail (and is where I got the idea from) in Doug Hofstader's Godel, Escher, Bach and the Eternal Golden Braid. Basically the canon changes key by the time it gets to the end of the sequence and it seemlessly blends meaning it doesn't make the song tune sound off and can continue to be played over and over with every time corresponding to a heightening of the key. Same thing with Drawing Hands by Escher with this infinite loop type situation occuring. I don't fully understand how this ties in with what Eric is saying but I do know that it does.
    DanDman,
    I have assembled a list of freely downloadable books, alot of which Eric has referenced, here; http://www.energeticforum.com/renewa...html#post97489 It contains every single book Eric has referenced on the forum with the exception of Ernst Guillemin's Communication Networks plus some references he has referenced in his books. I stress that anyone who is reading Eric's posts should check them out especially Heaviside's Electromagnetic Induction and its Propagation.
    Raui
  • t-rex
    Experimental Cubic Volumes
    It has been heretofore established an existence of a volumetric, or cubical, unit of space, the metrical dimension. This unit of the dimension of space is defined as one cubic centimetre, the size of a common sugar cube. It is given this metrical cubic volume of space is void of any substansive dimension, no sugar, no 10-C oil, and even no aether, since aether is considered a substansive dimensional relation. Hence, indivisible, void, and a pure metrical unit, this is our cubic volume of EMPTY SPACE.
    Consider the axiom that a field of electric induction cannot exist in the absence of the aether. Then just how does this cubic void space interact with an electric field? Since the laws of lines of force as established by Michael Faraday, and developed by J.J. Thompson, and as further established by C.P. Steinmetz, maintain that no line of force can just end in space. The lines of magnetic induction exist as closed loops, no beginning, no end, continuous expansive or contractive loops. Magnetism is a circumferal force. In a conjugate manner the lines of dielectric induction terminate upon physical surfaces, where they bond into the intra-molecular dimensions. Dielectricity is a radial force.
    The Maxwell concept of electro-magnetic induction and its propagation gives an altered concept of the nature of dielectric induction. In this situation the lines of dielectric induction may also terminate upon themselves, forming closed curves in a manner analogous to the loops of magnetic induction. This condition is a necessity for the propagation of electro-magnetic waves in a dielectric medium, (sugar, oil, aether, etc.) without guiding metallic structures (wires, waveguides, etc.) This eliminates the “charge carrier”, that is, the dielectric induction is now completely independent of any terminal surfaces. The dielectric induction is now completely dielectric. This is the fundamental concept underlying the Maxwell theory of electro-magnetism. It is here that J.C. Maxwell found his fame. But the pedant tells us just the exact opposite! So intent is this mind-state in forcing a “materialism” upon electrical theory that Maxwell’s work is re-worked to suit this view, it is then taken up by the one wing parrots, their screeches drowning out the original concepts of Maxwell.
    It may be logically inferred hereby that, for the condition of a cubic volume of space, the line of magnetic, and the lines of electric, induction must bend around this cubic void of space. These lines cannot be interrupted or broken by this void. Hence by the insertion of a cubic void into a space supporting electric induction the lines of force are pushed aside. The overall induction in the supportive space is then hereby reduced, since now there is a unit volume less of this space. This is to say that the inductivity of the supportive space is reduced by the insertion of an aetherless cubic volume of space, the cube of empty space.
    Consider certain experimental configurations. One configuration consists of a widely spaced pair of laser produced beam of light, side by side traveling through the aetheric medium. The second configuration is a pair of one square centimetre copper plates. These two plates face each other squarely and are separated by a span of one centimetre. This defines a partial boundary for our one cubic centimetre, or unit, cube. Hence any unit cube volume can be inserted between the pair of one square cm copper plates. It is also given that all space within and surrounding these copper squares is void, no sugar, no oil, no aether, just empty space.
    In our first experimental configuration we have a set of three unit cubes, one is filled with 10-C oil, the second is filled with aether, and the third is void. Taking the side by side spaced laser beams, we measure the speed, or time delay of propagation of both beams through supporting aether through which they propagate. Here, both arrive at the end point at the same time, thus propagating at identical velocities of propagation. First, take the unit cube of oil and insert it into beam number one, leaving beam number two unchanged. It is hereby found that beam one arrives delayed in time relative to the arrival time of beam two. Here it can be inferred that light travels slower in the oil. By measurement it is found to be about 70 percent of the light velocity in the aether.
    Next, take a unit cube of aether and insert this cube into beam one, again leaving beam two unaltered. Obviously both beams arrive at the same time since both propagate through only aether.
    Finally, take a unit cube of void space and insert it into beam one, beam two again unaltered. The poodle begins to bark. We now have two distinctly opposing possible outcomes.
    (A) Beam one is stopped at the facing boundary of the cubic void. No beam one is detected at the receiving end. Now it may be asked, what became of beam one? Was it sent back, or was it consumed, thus in violation of the Law of Energy Perpetuity? This we are unable to answer.
    (B) Beam one arrives advanced in time relative to the arrival time of beam two, this to say, that the propagation through the void space is now instantaneous, in other words with an infinite (un-defined) velocity. It takes no time to span the distance of the unit void space. How is this possible?
    Now we take our next experimental configuration, the pair of parallel one square cm. copper plates, these in void space. Thus far we have no concept defining capacitance, but we do possess a capacitance meter. How fortunate! Upon connecting this instrument to the unit copper plates in a void it is found that this metallic-dielectric configuration has zero capacity. This is understandable since we now have no dielectric, and hence, no dielectric induction.
    Next, we insert a unit cube of aether between the unit square copper plates. Now the instrument indicates one electro-static unit of capacitance, this as expected.
    Finally, we insert a unit cube of 10-C oil between the unit square copper plates. Now the instrument indicates an increase in capacitance over that of the aether. This increase in capacitance is in EXACT proportion to the square (second power) of the decrease in the velocity of light through the same identical cube of oil. It is then given, the change in the velocity of light through a dielectric medium is the square root of the inverse of the change in capacitance effected by this dielectric medium. Hence capacitance exists in a direct relationship with the velocity of light in a given medium. Zero capacitance, infinite velocity.
    Hereby this dimensional relation is given as,
    Seconds Squared
    Per
    Centimetres Squared
    This is to say, one over the speed of light squared, that is, one over c squared. Here it is useful to take the speed of light as a unit value, or one. See for example, C.P. Steinmetz’s “Impulses, Waves, and Discharges”, chapter on “Velocity Measure.” It is in this relationship between luminal velocity and electro-static capacity that we find the luminal velocity concepts of the relativists, the c squared in the E equals M-c squared. Call it a “dimensional fluke” if you wish. However, capacitance is forever married to the velocity of light, to one over c squared.
    Investigating dielectric capacitance a bit further, consider an experiment of Ben Franklin, the father of the electro-static condenser. Here we will dispel the “electronics nerd” concept that a capacitor stores “electrons” in its plates. Taking the pair of copper plates as in the previous experiment, but now we have two pairs of plates, one pair of plates distant from the other pair of plates. Upon one pair of plates is imposed an electro-static potential between them. The cube of 10-C oil is inserted between this “charged” set of plates. This hereby establishes a dielectric field of induction within the unit cube of 10-C oil. Now we then remove this cube of oil, withdrawing it from the space bounded by the charged pair of copper plates, and taking this unit cube of oil, it is then inserted into the space bounded by the other un-charged pair of plates. Upon insertion it is found that the un-charged pair of plates have now in fact become charged also. It here can be seen that a cube of dielectric induction can be carried through space, from one set of plates to another set of plates. This induction is contained by the boundaries of the 10-C oil. Well golly-gee Mr. Wizard, what happened to all those electrons, Isn’t oil an insulator?
    Here given has been various examples of dimensional relations involving space. First order space has been the long distance power line, second order space has been the package of spaghetti, third order space has been the cube of 10-C transformer oil, and, over the incessant barking of the poodle, fourth order space has been invoked as a product of conjugate flux densities.
    With the understanding hereby developed it is now possible to enter development of the concept of inductance and of capacitance, along with their use in the application of the metrical dimension of space to the substantial dimensions of electric induction. From this can be derived a substansive concept of the aether.
    73 DE N6KPH
  • Pinwheel
  • lamare
    Originally posted by wizofid View Post
    Might I suggest that cutting a pasting Eric's work alone - together in one place and reading it - in its entirety -may be the way to see this in a cohesive manner. It is one way to remove the disjointed thoughts.
    You may want to take a look here:
    Tuks DrippingPedia : Energetic Form Posts
  • wizofid
    That - and Eric has posted the textbooks that he started with. I some 35 years ago, found the very same thing, when I was reading Mech and EE Eng books, back in high school - The NEW texts, were 300 pages and left out all of the steps from question to solution. Going back 5 or 10 editions - and maybe 20 to 40 years of publishing, allowed me to find the very same questions, asked and answered - for 40 years. The simple truth was that during the 70's and 80's, Texts got cut 2 and 300 pages - but what was left on the floor was the math and word explanations - of how you sorted things out in "First Principles". I found - the older the book - the better the explanation.
  • DanDMan
    I get it
    Originally posted by Dollard, E. P. (N6KPH) View Post
    ...for those who’s minds have been polluted by the prevalent quantum goddess reality:
    Example:
    The air in the room; the room is filled with air and has atmospheric pressure of 2998 mB, your stereo is blasting away, the speakers are creating longitudinal waves having length and frequency and exert a oscillating force centered on 2998 mB (+ or – 10 mB)
    RG is the air pressure, a scalar
    XB is the sound of the stereo, a longitudinal wave
    XG = RB, thus no transverse waves exist (XG – RB) = ZERO
    Hence (RG + XB) is what is going on in the room, the disinformers have convinced you that this whole quantity (RB + XB) is scalar, RG is the only scalar component. It is DC and has NO FREQUENCY, no WAVELENGTH and thus NO WAVE! SCALER = NO WAVE - GET IT???
    If people don’t get this fundamental concept – my time is better spent talking to my pet Coyote… I have nothing further to say…
    I totally get it Eric. This has been my thought about the electrostatic for while, but knowing who to bring this to practical application has been hard for me. I have been working on a capacitor with one metal plate and one plasma plate. The idea to very capacitance over time at extreme frequencies. Am I headed in the right direction at all?
    I have only now found your work. I gave up on understanding Tesla years ago, because I made the mistake of seeking education from Babylon. I have only now picked it up again. Tesla has been my primary hero since I was 10 years old. Your last post just broke my heart. I am so sorry. I have nothing to offer you, but if you ever need a place to stay the door is open.
    There are years of time span in your work and I would guess that you have refined your ideas, but being at the beginning, I need a way to get to the relevant info and not wast time with outdated ideas. I assume from your frustration you have, like Tesla, already explained everything but have not been perceived. I beg this one request from you Eric in the name of Tesla and all that is Good. Can you please provide a list of your works and/or others which gives us the secrets of Tesla?
    Having all the relevant material specifically listed in one place would greatly speed the learning/relearning curve! With this info I promise to learn it, build it, and teach it worldwide!
    Right now, I don't even know where to look for all your data, math, ect..
  • Raui
    Eric,
    Very informative post indeed! I'm going to read more of Transients in Space tonight (For anyone interested in doing the same it's located in Steinmetz - Theory and Calculation of Transient Electric Phenomena and Oscillations) I eagerly await your next transmission
    Does it go on from there?
    The ratio of the dielectric flux density over the dielectric induction is the ... (I have no idea).
    Or,
    The ratio of the magnetic flux density over the magnetic induction is the ... (I have no idea).
    Similar to how impedance and admittance were treated earlier?
    Or perhaps,
    Planck^4 / (either) phi or psi = something
    Like, there's another set of dimensional relations and ratios that one would want to consider now that we are looking at the substantial properties of the electric field density in cm^4.
    /edit -and now I realize I was reading it wrong - it's Planck/cm^4.
    Good to see your trying to thinking ahead but the ratio of dielectric field density to magnetic field density or visa versa is Impeadence (webers per coulomb) and Admittance (coulombs per weber) since the space to the 2nd power cancels when dividing. See an example here; WolframAlpha
  • Pinwheel
    [...]it may be asked, what of the product of the dielectric flux density, and the magnetic flux density?
    Or,
    Weber per Coulomb
    Equals Ohms.
    Coulomb per Weber
    Equals Siemens.
    Or perhaps,
  • t-rex
    Basic Electrical Relations in Space
    Let a one centimetre cube of the metrical dimension of space be given as unit space. The given metrical boundaries define a unit cube, a sugar cube with no sugar, no 10-C oil, not even any aether. This cube of space is empty, void. This unit of space, a metrical unit, is NOT in connection with any substantial dimension. This is a unit cube of void space.
    It is postulated that electric induction, as a property of the aether, cannot be established without the presence of this aether, or another dielectric medium. This is to say, void space is not capable of supporting electric induction. Hereby it is reasoned that the aether is a substansive dimension, or it can be expressed as a substansive dimensional relation. The dimensional expression of the aether it is best given as a primary dimension, expressed only in a dimensional relation derived from a primary substansive dimension and its relationship to a primary metrical dimension, time or space. This is served by the concept of the Planck, Q, this in conjunction with a space versor system expressing the Planck in real (electro-magnetic) components. See E.P. Dollard “Theory of Wireless Power.”
    In general we have been speaking in terms of line of force, that is lines of magnetic and lines of dielectric induction. It is as of yet known “how big” these lines of force may be. These lines of induction can be expressed analogously, such as a bag of uncooked spaghetti. Its individual strands serve as analogs to the individual lines of induction.. Hence long, thin, strands with axes in a broadside bundle. If then the bag of spaghetti is snapped in two, when it is viewed endwise, a circular cluster of small end-sections of each strand are seen. These are elements of the strands of spaghetti.
    This package of spaghetti is an analog to the total dielectric induction. Now there are 100 strands of spaghetti in this package, or boundary condition. Here Psi is then given as 100 strands, the total quantity of spaghetti. Viewing this package endwise, 100 end sections of the individual strands are seen in a circular bundle. The cross sectional area of this bundle, bounded by the package is a one square inch AREA. This is analogous to a dielectric flux DENSITY, the density of dielectric induction, in PER SQUARE INCH. Hence the density of spaghetti is given as 100 strands per square inch. The total undivided quantity of spaghetti is 100 strands. The substansive dimension of spaghetti is in containment by the “throw away” package, this as the metrical dimension of space. Counter-spatial representation is given as 100 strands per square inch. The grocery store regards this as one indivisible unit quantity in space of spaghettic induction.
    Here the substantial dimension of spaghetti, Psi, is operated upon mathematically by the metrical dimension of space, per square inch. Here arrived at is the dimensional representation of spaghetti in space, strands per square inch. This is a second order space relation, in a counter-spatial form.
    A pair of dimensional relations follow from the spaghetti analog. One is the dielectric flux density, Psi over A,
    (1) Coulombs per square cm.
    And the magnetic flux density, Phi over A,
    (2) Webers per square cm.
    Here A is the area in square cm, a second order expression of space. A primary dimensional expression for second order space is the ACRE, the space for which she extracts her toll.
    Since the total electric induction, Q, is the product of the dielectricity, Psi, and of the magnetism, Phi, it may be asked, what of the product of the dielectric flux density, and the magnetic flux density? This is given as,
    (3) Coulomb per square cm
    Times
    Weber per square cm
    Substituting the dimensional relation,
    (4) Coulomb-Weber, or Planck
    Hereby gives the dimensional relation of the product of the flux densities as,
    (5) Planck per quatric cm.
    Hereby the product of the pair of flux densities, (1) and (2) Gives rise to a fourth order space relation (5), this in counter-spatial form. Now what in hell set off the poodle this time?
    73 DE N6KPH
  • t-rex
    Application of Space to the Electric Dimensional Relations
    In order to gain an understanding of the electric field of induction a concept of the distribution of this induction in the dimension of space must be developed. An example is a 200 mile long power line. It has a span of 600 feet between towers. This is a 230 kilovolt, 60 cycle/sec, 3 phase line. It can be shown that for each span of line between supporting structures there exist an electro-motive force, E, in Volts, this in series along this span, and a displacement current, I, in Amperes, this in shunt along this span. The series E.M.F., and the shunt displacement of each span compound with each successive span. The total E.M.F. and total displacement for the entire length, 200 miles, of the line is found by integrating over the total number of spans. However, this integrated value is not given by the simple addition of the individual E.M.F.s and displacements developed by each of the individual spans. Here we find an exponential function of space determines the relation between the individual values, and the total values of E.M.F. and displacement. These considerations are developed by Carl P. Steinmetz in his “Theory and Calculation of Transient Electric Phenomena” book, in particular the chapter on “Transients in Space.”
    The general problem of the representation in space is given by the introductory part of “Transients in Space” and also by Ernst Guillimen in the introductory chapters in his “Communications Networks” vol. 2. Read these, they are a most important study. These writings form the basis for the theories of electrical engineering utilized today.
    The metrical dimension of space is most often considered as a VOLUME, this representing an enclosed quantity of space. This space is filled with something substansive, often which must be paid for, such as a gallon of milk. The milk is the substantial dimension, the “throw away” gallon container is the metrical dimension. In general, this volume of space is considered a cubic quantity, or boundary, this such as a cubic foot, cubic yard, cubic centimetre, and etc. It is habitual to express a volume in cubic terms, this in three mutually perpendicular co-ordinates, wrongly called “dimensions.” It is also habitual to express electric relations in the same manner, a corner of a cube, such as Psi, Phi, and Q. This now is three dimensional, a 3D relation, since Psi, Phi, and Q are dimensions. The cubic relation itself has no substansive dimensions, it is only the metrical dimension of space expressed by a group of three mutually perpendicular co-ordinates. This is important.
    It is given here that a one centimetre cube is the elemental unit of the dimension of space, a volume of one cubic cm. This is about the size of a common sugar cube, but instead of sugar, this cube is filled with electric induction. It is a cube of electricity. What exists outside the boundaries of this cube is for now unknown, it is excluded by the boundaries. For most of the examples that follow, all space is filled with 10-C transformer oil, the dielectric. All boundaries enclosing, or dividing, this space are sheet copper, the metallic. Here given is the metallic-dielectric geometry, such as a power transformer, or a static condenser, two fundamental apparatus in electrical work.
    In the case of the 200 mile long A.C. power line the basic element of space is the span. This is first order space. Here it is given as per 600 feet, this now a unit value. It now equals one, one span. This unit value is known as a differential element, it is indivisible, the smallest “line on the ruler.” It relates to the Newton-Leibnitz concept of the infinitesimal.
    It is considered that cubic, or third order space, is the most general expression of space, a metrical dimension. Since the ordinary transformers and condensers utilized in power engineering are of considerable volume, it is then allowable to consider one cubic cm. as a differential element, that is, an infinitesimal quantity if space. Taking the, one cubic cm. of space, as a unit value, gives the differential element of the metrical dimension of space. It is hereby about the size of a sugar cube, but filled with 10-C oil. Hence the VOLUME is given as ONE cubic cm., the AREA as ONE square cm., the DISTANCE as ONE cm., the SPAN as ONE per cm., the DENSITY as ONE per square cm., and the CONCENTRATION as ONE per cubic cm., all faces, corners, spacings, and etc. of this unit cube are ONE. Hence our differential, indivisible, element of the metrical dimension of space. All orders, or powers, of this space equals one, one squared is one, one cubed is one, and etc. All are one.
    This may just as well have been a cubic yard, or a cubic nanometre. The consideration of “unit value” is to reduce the size to the point to which there is no distinguishable variation of the substansive dimension with respect to the unit of the metrical dimension of space. It is then a space scalar condition, no variation in space. For example, consider the 200 mile long A.C. power line. It has a propagation velocity very near that of light. For a frequency of 60 cycles per second, this gives the wavelength as 2880 miles in length. The total distance of this line is 200 miles, this a significant fraction of a quarter wave or an impedance to admittance transformation. However the per 600 feet of a span is an infinitesimal fraction of the quarter wave distance. Hence the distance between towers, the spans, serve as the differential element. It is then 600 feet is of unit value, indivisible. There are no intervening towers.
    No perceptible variation of the series E.M.F., E in Volts, or the shunt displacement, I in Amperes, exist along this 600 foot span of A.C. power line. Hereby it is said the E.M.F. per span, or the displacement per span. In the general case it is given as Volts per span and Amperes per span. These dimensional relations represent the voltage gradient and current gradient along the length of line. Dimensionally it is;
    1) Volts per cm.
    2) Ampere per cm.
    It should be noted that this pair of gradients exist in space quadrature to the previous given gradients, the dielectric gradient, d, and the magnetic gradient, m. This is a fundamental relation in electro-magnetic induction and its propagation.
    It can be seen that each span has a back E.M.F. in series with the power flow, and a displacement, or charging, current in shunt with the power flow. These are a consequence of the electric field of induction in a time rate of variation, the 60 cycle, or 377 radians per second. These are transmission impairments and give rise to a delay in propagation which progressively compounds down the line, from span to span. These differential elements, or spans, must be summed up, or INTEGRATED, in order to determine the total E.M.F., total displacement, and the total delay in propagation. This is not so easy of a task. Now for higher orders of space the situation is that order more difficult.
    In the application of the metrical dimension of space to the substantial dimensions of electricity, the concept of magnetic inductance, and electro-static capacity, are utilized. Steinmetz, in his “Impulses, Waves, and Discharges”, established the inductance and the capacitance as the “Energy Storage” coefficients of the electric field of induction. It must be noted that here the term ELECTRIC FIELD is NOT the “electro-static” field, it is the union of the dielectric and magnetic fields of induction. Erase the “electric field” wording of the one wing parrot. These two distinct dimensional relations, the INDUCTANCE and the CAPACITANCE serve to define the ability of bounded to contain the electric field of induction, this field representing STORED ENERGY.
    What follows here is the development of the properties related to the dielectric and magnetic fields and the interaction of these with the bounding metallic-dielectric geometry. Considerations involving energy will be arrived at later on. In this view inductance and capacitance now represent GEOMETRIC CO-EFFICIENTS, expressing the relation of the BOUNDING GEOMETRY with the fields of induction which it bounds. In essence inductance and capacitance are of a scalar form. Here enters the concepts of what is known as “radionics.” The inductance and capacitance each exist in distinction to the electricity itself. The inductance and capacitance ultimately serve as geometric expressions. This is important. Hereby they can be expressed as completely metrical dimensional relations, that is, having no substansive dimension.
    We have of yet actually given the dimensional relations which make up inductance and capacitance. Further considerations involving the electric field have yet to be understood. Break, more to follow…
    DE N6KPH
  • madhatter
    Please understand that I'm no way making a preemptive strike against Eric or his work. My only reason for saying I hoped he was above mud slinging was directed at and only at the slur as I see it against quaternions. I can only assume as others that this may be a subtle reference to Beardon, however I don't know for sure as Eric is not clear about it.
    I've watched the videos from the 80's and have worked thru his journals and publications and fully understand what he's talking about, I don't think I'm rare in that. I do have some additional background knowledge due to my line of work that I can not disclose that does indeed validate Eric, do not construe that to mean that I'm trying to mislead anyone. I implore all to listen and pay attention as best as they can to what he's posting.
    I'm probably from a smaller group though in that I've studied quantum physics for 10yrs and have long strayed along the accepted edge. The eyeopener was taking a step back and really listing to what some physicists are saying and a theme will emerge. There is a fundamental break between physics and our conscience, you may be wondering what any of this has to do with electricity.
    I'll tell you, neuroscience deals with the synaptic function of our brain, this occurs on a quantum scale. It's the world of the unknown and full of interesting theories. Now here is Eric who's trying to tell the anyone who'll listen that there is more to the dielectric fields than is taught and we know. I came across Eric's work a number of yrs ago when I was doing research in quantum electro dynamics, preciously because he's done lab work that proves the existence of another dimensional phase, or faster than light travel.
    I honestly have no idea how much in depth knowledge Eric has about this or it's implications beyond the macro scale. research and testing requires substantial funding, I'm aware that he's been thru the wringer on that front and I don't begrudge him in his distrust of people due to this.
    Eric is free to tell me to go jump in a lake as is anyone. I wanted to make the point that one particular type of algebra or calculus isn't the reason why Eric's or anyone's work is obscure. The reason would be due to the interpretation of the equations that gets pushed forth, and the peer review process itself. classic case of this is found in string theory, it's not the type of mathematics but the input for some very odd theories.
    Eric makes a point and it needs to be stressed, understand the relations between the functions and constants. A lack of understanding these basics will get one lost and confused. This is going to be tougher for those who don't have a background knowledge in how the constants were derived and the relations they have to each other. For the terms used, i,j,k, and many many more, there is reason for each and what each mean. The majority of equations use these 'place holders' to reduce the shear complexity of them, however one needs to keep them straight in their mind and know where you can and can't place them. The order and use of them is also related to the type of algebra or calculus used.
    Eric is not going to give everyone a math lesson or go thru the fundamentals, that is the responsibility of the reader. He provides numerous sources of reference for this. Take advantage of that.
    I apologize for any offense I have made, that was not the intent.
  • jarvamundo
    Poopin ended up with hellovalot more than $25,000... try more than 400k by the end of the AT&T episode. And here is the rub, if Heaviside had been backed, he could've demolished the patent fight between AT&T & Pupin. (this being reason why AT&T did not pursue the case with poopin... as OH would've been revealed as the holder of prior knowledge..... so it was in AT&T's interest to endorse the pupin patents). But Heaviside considered it a crime not to publish. An unsung hero.
    Also of interest.... Ivor Catt published a biography by Heaviside's friend G.F.C. Searle "The Man". It's a sad read, but also serves as an inspiration to "stick it"... anyways it's as first hand as you're going to get (it's free get it, read it): http://www.forrestbishop.4t.com/OHM/...de_the_Man.htm
    Ivor Catt's work on logic buses is interesting in it'self (The Catt Anomaly)... as these transmission line effects are now popping up as we reduce the dimension of time and space by studying these effects on a pcb. Turns out 'charge' appears on a parallel conductor (reflector) "instantaneously out of no where".... the conflicting letters between the IEEE officers are hilarious... apparently one of em has a Nobel.
    imo historical context is very important when approaching these ideas...
    Also when you study Electrical Papers.... be sure to check out "Ido Yavetz - From Obscurity To Enigma"... it's technical & written for engineers, applied mathematicians... however the focus of the author on the method of Heaviside's physical reasoning is as good as i've found. A real gem.
    Absolutely no mention should be made of anything Maxwellian without directly quoting Maxwell himself thru his writings! To study his work in its entirety will take a lifetime. So mute thyself.
    back to EPD and Coyotes munchin parrots... mute-on
  • Pinwheel
    @madhatter
    I'm not quite sure what your basic point of contention is. Is it that EPD is not endorsing QM?
    It also appears that you are saying that there is many different mathematical methods to achieve (something). Obviously, there probably is many different maths one can use to do this or that. Is this what you are saying? Also, what is that (something) that many different types of maths can explain? The nature of space?
    ___
    After taking a 10 min break in composing this post, what looks to be happening is that you are preemptively critiquing EPD's method of describing something... that he hasn't described yet... with his method that he hasn't fully revealed or explained yet. He hasn't fully revealed it here anyway. This is unless one had a very thorough understanding of his papers he wrote from back in the late 80's - in which case you would be the first person to have that level of understanding that I've personally witnessed. I'm also assuming that EPD's has fully published his idea and methodology in those late 80's publications.
    I would think that someone with this level of understanding would be able to re-create those late 80's experiments, that we've all seen, and then, of course, feel free to dissect whatever it is that EPD talking about with something like "the wave propagates through a higher dimension" - and subtle ad hominem shots like your "I just hoped Eric would be above mud slinging though".
    I could be wrong but I'm pretty sure that nobody (and for sure nobody here) has EVER... re-created any of EPD's experiments even 1 time ever.
    Should we let the author explain his idea and his proposed method for understanding the idea, THEN call him out on it's legitimacy? You know what I mean? How can we call a guy out when we can't even duplicate what we've all seen him do? He's trying to tell us and we're like "naw.. you mud slingin' bro".
    Am I wrong here? It looks preemptive to me.
    For those interested, there is an interesting book by a guy named Mortimer J Adler called "How to Read a Book" that talks about things like this - critiquing an author only once you understand him (as well as how to have a better chance at understanding said author, ie: 'How to Read a Book'). Worth at least an investigation, if not purchase. I know the title kinda makes one go "pffft, I know how to read dude" but it's not like that - very very cool book.
  • madhatter
    I don't think Oliver liked quanternions, from Vol 1 preface:
    "The numerous letter prefixes of the quaternionic system, which greatly contribute to the difficulty of reading quaternionic investigations, are abolished, retaining only the symbol V before a vector product. Another difficulty is in the scalar product of Quaternions being always the negative of the quantity practically concerned. Yet another is the unreal nature of quaternionic formulae. The terms do not stand for physical quantities. Again, in most physical mathematics, the quaternion does not even present itself for consideration, or, at any rate, may be readily dispensed with. Lastly, the establishment of vector-algebra on a quaternionic basis is very hard to understand, as chapter II. of Professor Tait's treatise shows. These troubles are obviated by the method I follow, basing the whole upon the definition of a vector, and of the scalar and the vector product of a pair of vectors."
    agreed, Heaviside had an intuitive nature to physics and math can be brutally tedious, if one is not careful you'll loose all sense of what you're doing. The biggest thing is keeping your terms and functions in their proper place and understanding the relations. quaternions are difficult because you can be left with unknown terms and start with them too. Heaviside 'reduced' the equations to what was relevant and needed, not a bad thing in reality it worked well, undefined fields have no physical place here and become difficult to work with. look into the myriad of tunable constants in string theory, it'll cause brain lock!
    It is noted that their are waves that travel faster than light, at face value for some it comes out that there is something moving at a velocity faster than light. problem is it isn't that simple, it's propagating thru a higher order dimension. any dimension beyond the ones we inhabit can not be fully understood, the flash of 'string' theory and multiple dimensions bandied about by the media are misinterpreted and this only leads to further confusion. they are mathematical constructs, that's it.
    the physical world is translated into mathematics in order to gain a sense of order and predictability. The problem can be when one tries to take the math further than the physical model and then when the physical model does not invalidate the math it's taken as theory. There are physical, tangible phenomenon here now in this dimension that do not have a complete mathematical construct for them or even one that can be agreed upon.
    Heaviside was pragmatic and approached the issue in a clear and intuitive manner. This of course angered the community as it wasn't holding to the std in place. No different than today. Honestly I don't care what math anyone uses, show proof and predictability in it and all is well. postulates and theories with no substance are a waste of everyone's time. tossing obscene amount of money into mathematical constructs that have failed time and again is setting the clock back as well.
    This is sadly a simple thing, however for most scientist they can't see the forest for the trees. We need the math in order to exploit the world around us, otherwise we will be walking around in the dark. the mathematical equations have to fit the physical model first and foremost, if it does not then it is wrong. What 'flavor' of mathematics one uses is entirely their choice, the fallacy occurs when the driving theory behind the equation is wrong and then the math is blamed.
    For the astute reader, yes I've left out the interpretation of the equations. It is one of those 'kinks' that can obfuscate the truth. An equation can have a result that is dismissed due to a lack of understanding of what is being derived. And that is where the line is between the great teachers and the perpetual students. It's a case of you have it or you don't.
    The majority here would prefer to have finished results shown to them and explained simply. the problem I see is that for those who have gone thru the educational system it's going to be difficult to get around what's already in place, however you have the advantage of seeing the big picture and where the pieces may fall. If you've managed to extend your studies into QED and the quantum world, it takes a really open mind to start with and you'll really be able to see what's going on. I'd like to point out that quantum physics is more akin to what Eric is talking about, if one gets through the lower classes and enters into QED for example it requires a re-work of what you already know. particle physics is strange, however if you re-work it as a wave function then it becomes so much clearer and the here's the beauty, it validates what Eric knows!
    Ok, I'll step off my soap box now.
  • john_g
