Started reading Dollards book in the train home.
WOW!
Really groundbreaking stuff! What he does is basically re-invent complex mathematics, but he takes it a giant leap further than that. I still can't get my head around it completely, but from what I understand now, I'm sure this is going to be the electrical engineering model of the 21sth century. Yes, it is THAT groundbreaking.
Anyway, I wanted to talk about this:
Tuks DrippingPedia : Sbarc Lecture
Remember Dollard talking about the dielectric and the magnetic fields being opposites? One contracting, one expanding....
The magnetic component is a rotation in the ether. In order to make a beam, you need a ..... contracting force, a vortex.
So, what you need to do is to create a rotating surface wave across your sphere/coil. This way, you create a vortex going trough the centre of your sphere/coil, perpendicular to the rotational movement of the wave. This vortex expands into space, which is one and the same phenomenon we know as lightning. A very compact magnetic tube, a very compact vortex basically transporting DC magnetic energy. A steady-state rotating flow in the ether, which I think is also what binds atoms together. The "electrons" are stretched between the atoms such that they become vortex tubes, along which energy is transported between the atom nuclei in a crystal or molecule, which result in an attracting force between the atom nuclei.
The question is: how to create such a beam?
We don't know any more than that Tesla developed a beam tube. Did this consist of a sphere? If yes, then I would say he would have had his feed 90 degrees turned when compared to what he normally did. In other words, he would have fed his sphere along the surface of the sphere and not perpendicular to it. The wavelength he would have fed into the sphere would have to be 2 * pi * r in order to create a surface wave.
Another possibility would be to use a short-cutted coil, and feed that with one wire to put it into resonance, also creating a rotating surface wave around the coil, which would create a magnetic vortex stretching out into space.
If I had to make a bet right now, I would bet for the coil option, given what I wrote here:
http://www.energeticforum.com/renewa...is-motors.html
So, if you can make an extremely strong magnetic field using an extreme inpulse traveling around your coil, I figure you can als make a magnetic field using an alternating wave traveling around your coil. And when you manage to get the coil into resonance, while the wave travels in one direction, you should be in business....
The bottomline is that you need a contracting force to get a beam, which would be a magnetic force and NOT a dielectric one...
WOW!
As wireless progressed, Tesla established the system where he could transmit [electrical power] longitudinally through the earth at a velocity of 291,000 mi./s. Also he developed a beam tube […] In the beam, Tesla found that he could transmit direct current energy over incredible distances, and this energy not diverging out of the beam, much tighter, more compact than any laser ever built.
With that in mind, we can find Gray's actual secret, the production of extreme pulses of magnetic foce using a negatice resistance device, in Eric Dollard's "Condensed Intro to Tesla Coils":
http://www.tuks.nl/pdf/Eric_Dollard_...Coils(OCR).pdf
What makes a negative resistance device so interesting for steering coils into resonance for applications in magnetic motors is that the current trough a practical negative resistance device, like a spark gap or lambda diode, is always positive!
The formation of the energy impulse involves the discharge of a capacitor with the highest practical stored energy into an impedance (inductive) of the lowest practical value, and the discharge path is coupled to an energy supply through a negative resistance device. This negative resistance is classically a spark discharge, but a superior plasma device needs to be developed to enhance efficiency. Under optimal conditions the exponent of oscillation amplitude will be positive over a sustained period of time.
The net result of this system is the production of an extreme impulse of M.M.F. (magnetic force).
