Originally posted by Harvey
This topic is closed.
This is a sticky topic.
Originally posted by Peter Lindemann View PostTo Hoppy and Poynt99,
Apparently you guys have finally played your last cards, and shown the readers here the astonishing limits to your knowledge. The simplest DC-to-DC converters are an "inductive fly-back charging system" and almost all of them operate at electrical COP>0.9. This is true of the smallest units made that deliver less than ONE WATT. The idea that you guys openly admit to not being able to build one that works better than COP=0.6 is remarkable.
All I can say is.... can't you two find something more interesting to do than bothering us?
Peter
I would however like to hear your thoughts (if I may) on how the RA circuit is different in order that it can exceed COP>1.
.99Last edited by poynt99; 08-04-2009, 12:09 AM.
Thank You Rosemary And Tektronix!!!
Originally posted by witsend View PostGuys - SOME REALLY GOOD NEWS
Tektronix are lending us the use of a Tektronix 4 channel TDS 3054 500 mHz bandwidth for our tests
This is really good news. As I've said before, if anyone wants to argue results after this then they must argue with God.
SO WATCH THIS SPACE. My guess is that soon and maybe within a week or two we'll be in the happy position of posting some tests on youtube.
AND MANY THANKS TO ALL THOSE AT TEKTRONIX WHO ORGANISED AND ALLOWED THIS
Jibbguy - You'll be pleased I think.
This is VERY GOOD NEWS! Thank you Rosemary for making this happen and thank you to Tektronix for helping this project!Sincerely,
RPX & MWO http://vril.io
@hoppy
Originally posted by Hoppy View PostAaron
Its not a battery capacitor analyser, its a battery capacity analyser. Read up on how they work. John Bedini uses one to measure his batteries before and after discharge
I know that its under 100% efficient, well under. but its not me saying that 16pints can be put back into the fridge. Perhaps you would like to explain to Rosemary how this is possible.
Hoppy
I already know how it it possible. You should go back to the beginning of the thread and not just read it but COMPREHEND it.Sincerely,
realistic
Originally posted by Hoppy View PostSkeptic or realist Aaron; do you understand the difference.
HoppySincerely,
Free Heat
Originally posted by Hoppy View PostAaron, you say in post 1629 that: -
"Most of the free work is constant heat production...".
If its free (energy not input by the user), how are you going to measure this heat to compare its energy value with the electrical energy input to the system to prove the high COP claimed?
Hoppy
OBVIOUSLY is the heat is nonstop while the Ainslie circuit runs much longer than the control, there is your FREE HEAT and FREE CHARGE.Sincerely,
light
Harvey and Rosemary,
Feel free to start a new thread on that topic. It is an interesting topic!
Bouncing sunlight between two opposing polished copper surfaces causes a GAIN in heat production.Sincerely,
Yes, I was thinking how rare it is for us all to be here at once myself.
Actually the food for thought thread was specifically placed to encourage deeper thinking into how COP > 1 can and does occur. Not all magnetic interactions result in internal heating, some result in internal cooling. Gadolinium for instance has a strong magneto-caloric effect and was instrumental in the chilling process used to test for zero point energy. Light is electromagnetic energy in motion and therefore an EM wave can be considered a form of light.
If your device effectively converts 143KHz to Infra Red then we may have a cause. Look at how well a tungsten filament converts 60Hz to a variety of frequencies including Infra Red. Imagine if it only produced one color of light instead, then all that energy would be a single frequency. Fluorescent paint effectively converts UV to visible light, another frequency (and energy*) conversion.
So there are still unexplored classical possibilities as to the increased COP and where that energy actually originates from, but I'm rooting for the resistor being used for fuel theory myself
*the energy of the photon is dependent on its frequency"Amy Pond, there is something you need to understand, and someday your life may depend on it: I am definitely a madman with a box." ~The Doctor
What is the ampere hour capacity rating of your test battery?
HoppyLast edited by Hoppy; 08-04-2009, 06:23 AM.
Hoppy - your comments are now diluting what would otherwise be a really entertaining thread. Could you at least try and improve on the quality of your sad attempts at sacrasm if you must always be sarcastic. Otherwise perhaps you could just keep out of it until you've something interesting to post.
You are patently enjoying your contributions here but I'd like to point out that you're alone in that enjoyment. I'd prefer to spare our readers as well as the contributors. Like I say - improve on the quality of the comments - in whichever way you wish to present them - then we can all have some fun.
wrong questions
Originally posted by Hoppy View PostSo I think you are telling me that the accumulative free energy (from somewhere?) may actually exceed the level of energy input into the circuit by a factor of 16 over the period of the test? That's absolutely amazing Aaron and common sense to everyone - I don't think!!
Hoppy
The common sense is that ANY extra running time indicates BOTH - heat and charge.
Amp hour capacity is irrelevant!
If the SAME battery is used for experiment and control and the times are measured from a specific voltage to voltage, it does NOT matter the ah rating. It is using the SAME power source.Sincerely,
results
Originally posted by Hoppy View PostSo you can see the top of my bench then. You really must have special abilities
http://www.energeticforum.com/psychi...essions-2.html
http://www.energeticforum.com/psychi...-sessions.html
If you have any honest intention whatsoever, post your bench tests. Otherwise, anything you say is just TALK based on nothing but regurgitating "facts" you learned in school or elsewhere.
And put your name on it. Anonymous results are ALWAYS irrelevant.Sincerely,
