I've been working on trying to replicate your negative waveform Ainslie circuit, with the primary goal goal of replicating the below ambient temperatures you saw. Unfortunately, despite being able to create nearly identical waveforms to the ones you posted earlier (which was a challenge in and of itself), I'm not seeing any temperature drop in the resistors.
The only part of the system I haven't been able to properly replicate is the load resistor you were using. Do you happen to have a part number for it? It looks like an old Ohmite model but I haven't been able to find an exact match, and most of these modern resistors are using some variant of nichrome (rather obvious due to its magnetic properties) or an unusual material that is most definitely not nickel silver. I assume the resistor you were using had a nickel silver winding? Every otherwise similar resistor I've been able to acquire is in the 10-30uH range, not the 96uH range.
You mentioned before you got this to a 5 degree or more drop in private testing. Any chance you could share any hints as to how that was achieved, and whether you had been able to double check the result with a non-contact thermometer? I watched the Youtube video you posted with the non-contact thermometer but the temperature drop wasn't showing up there (I presume the system wasn't operating in temperature reduction mode at that point).
Thanks!
Thanks!
