Fine Tuning the Gate
Place a 2 Ohm section ( a little less than 30cm?) of Nichrome wire (same as used to build the resistor) in series with the Gate Pot.
Make a flexible jumper of 16 AWG wire with an alligator clip on one end - it should be just a bit longer than the Nichrome wire to allow the Alligator clip to be turned 90° and still reach the end of the wire. Secure the other end to the nichrome wire by a suitable method. You now have an infinitely variable 2 Ohm precision resistor in series with the gate pot.
Use the Gate pot for course adjustment, and then slide the alligator clip along the nichrome to fine tune. It would be best to start with the clip in the center of the nichrome wire so you can either increase or decrease the resistance as required from that point.
This method has not yet been tested on this circuit, so please document your results for other readers to benefit from. I have used this method for calibrating high current shunts in test equipment, only in my case I used copper wire due to the high currents involved. So I know the method is a very accurate means of arriving at the desired resistance.
Cheers!
Harvey
Cheers!
Harvey
