Originally posted by gadh
Sorry for the delay.
1. A wire connects Pin 7 to the junction of R4 and R6. Move that wire so it connects Pin 7 to the junction of R6 and D2. Note that the connection between Pin 7 and R7 remains unchanged.
2. Replace R5 with a straight wire (remove R5 and put a jumper in its place).
The component values in my suggested modification are those values that allow the circuit to work within the original Quantum parameters. Please note, that when Glen tried those values, he was unable to get the circuit to behave as claimed by the original article. His arduous experimentation resulted in the schematic shown in the very first post in this thread. Therefore, apart from 1 & 2 above, the schematic in the first post of this thread is the one that should be used if you wish to replicate Glen's work.
If your goal is to replicate the original SA claims, you will need to contact that group for assistance as their schematic and procedure is flawed and cannot work as claimed. Only they can provide the true values and procedures used. My suggested value modifications were provided to show that their stated parameters (2.4kHz Original Parameters) could be achieved with the simple correction of the capacitor and resistor values as shown. The SA group later admitted that the Quantum schematic was in error but never offered a correct schematic. Therefore we were forced to reverse engineer the device with a "best guess" approach and a lot of time and energy on Glen and Aaron's part to get it to work at all. My experience is that the SA group is purposely close lipped regarding their schematics, parts, apparatus and data. They are not sharing these things with the Open Source community for some reason.
![Frown](http://www.energeticforum.com/core/images/smilies/frown.png)
Removing R5 increases R4 Range, not R1 sensitivity.
With R5 in place, it is impossible to bring R4 all the way to supply rail thus limiting the frequency range.
Moving the wire as stated above, will reduce the current through the discharge circuit and remove the need for R5 at all.
What is needed in R1 is greater resolution, not greater sensitivity. We want less sensitivity and greater travel on the adjustment. For example, you can have two pots in series, both with 20 turn resolution. The one pot can be your R1 100 Ohm, and the new one (R1b?) could be 1 Ohm. Now you have better control using the 100 Ohm for course adjustment and the 1 Ohm for fine adjustment. My earlier suggestion of a length of Nichrome could have a 1 Ohm value to become R1b with a slide action rather than 20 turns. It is a low cost alternative to finding a 1 Ohm 20 turn pot.
![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
