Hi gang! Better late then never! I have a lot of catching up to do. Today I built my first SG. I built it with the help of Johns Book #1. I did it exactly like he said. Cause he says "build it just like this". So I did. or at least as close as I could. I have a close up of the circuit so you can see what I did.
got it all hooked up, and spun the wheel the wrong way. Of course it dident run. then it dawned on me, so I spun it the other way. YeeHaw! she took right off! so to "test" the circuit, I pulled the pos off the charge battery. thats where it went wrong
the 2nd light from the right blinked a couple of times and went out. None of the others came on. I hooked it fight back up and it still ran, but slower. so I did a finger temp test on the transistors. 2 on the left were HOT! the others were cold. everything is per spec as far as I can see. So i did some testing, I have no idea how to test BJT's but the values seem consistent except the 2nd one from the left. I put in new diode, no change, new resistor, no change. removed the neon bulb, no change.
eplanation of the picture:
"top of the coil" comes in on the right with the trigger wire coming in through the hole, connected to the resistors. Bottom of the coil connected to the transistors, with the trigger wire coming in thru the hole on the left, connected to the?collector? the pin on the left when upside down
The rest is visible as far as how its assembled.
So what went wrong?
I have got a few days to reflect, as I have to wait on Mouser to ship me new transistors
Any help would be appreciated
So what went wrong?
