Multi coil SG
  • Multi coil SG
    Hello everybody, I have built a new Badini SG. It is crafted from solid 3/8" aluminum. With one 8 filer coil and seven transistors, it runs between 300-450 rmp. It is 24"x24". It has 20 3x8" x 2" x 1"
    Magnets. It runs great with one circuit and one coil. It is setup to add 18 coils for a total of 20. I have been having trouble integrating the 2nd circuit to the existing, functional circuit. What is the best way to hook it all up? I have tried a couple times, resulting in a few fried transistors. I have 2 coils mounted, and they both have a trigger wire. If i only need one trigger for the entire machine, i can use the 2nd trigger to build an additional transistor set. Anyway, i am stuck on what i am doing wrong, it should run.
