troubleshooting my bedini project
  • troubleshooting my bedini project
    recently i made my motor according to bedini motor. but it did not manage to rotate. I speculate my triggered winding is not enough current / voltage to open the transistor gate and make a pulse system....
    1. my power winding i use is 1mm diameter and triggered winding 0.5mm .
    2. the turns of solenoid is around 600-800 turns
    3. magnet that i use is neodymium magnet
    4. this is the circuit that i used
    https://imageshack.com/i/n64kb6p
    this is my motor
    https://imageshack.com/i/n8du4mj
    this is my solenoid
    https://imageshack.com/i/na6vd7j
    5. my core is around 2.5 cm in diameter.
    6. when is hand rotate, my induced voltage obtained at triggered wire is 50mA -300mA....
    7. when is test to switch directly power sourced 12v at power coil, the magnet is manage to repel...
    so, when i assembled the circuit, my motor did not rotate AND I TOTALLY STUCK
    anyone could help me?? please
    i want to add on, i had try to use 1k-5k potientiometer + 470ohm instead of 680.....but it is still didnot work
      need help
      go here for help
      Activity Stream - Energy Science Forum
