Junkyard electricity
  • #16
    I changed the 1N4007 diodes from the low drag generator to 1N4744 15 volt zener diodes.
    It now reads over 12 volts from the coil output unloaded.
    Now folks, you know this machine doesn’t have a self sustaining output for itself to run, but each step I take, makes it run that much more efficient and eventually getting the project to work.
    All I need is 3,4,5, or 6 volts...3 works great.
    Okay you guys, start gummin’ them chops over the usefulness of such a setup when put on a solid circuit board and housing.
    Go,...
    • #17
      I have this dc to dc stepup transformer.
      • #18
        Go,...
        Are you talking to me? I am not questioning the possibilities here.
        Can you show a circuit or a direction to go in? Is this a Don Smith?
        What does the spark gap do to help this? If any. No spark gap?
        HV can be fun.
        • #19
          I took the two stator outputs and disconnected them from the bridge rectifier and attached two smaller Zener to the outputs making four diodes total so the drop voltage will be smaller and a larger dc voltage.
          • #20
            Ionic wind, Tesla coil transmission, wireless dc to dc transmission over long distances.
            Some possibilities for an HV to be used to teach others on a smaller scale what Eric Dollard is doing in larger detail and scale.
            It may help some people.
            • #21
              Who is Don Smith?
              I will try to reason out a schematic among all the wire Jungle vines.
              • #22
                Who is Don Smith?
                Okay great, a diagram is nice, no hurry. Don Smith uses this HV box
                and he does wireless transmission on a small board. He had one generator
                and three collectors or receivers.
                I will look on with interest
                • #23
                  hi BroMikey
                  please check your pm box, I have a question
                  • #24
                    I have a question, why are you using this thread for your text message?
                    • #25
                      Here is a drawing of the stator arrangement.
                      The first, fourth, seventh and tenth legs are used and the other legs are dumped into a microwave capacitor then rectified using small zener diodes and then fed into the primary side.
                      • #26
                        The circuit is using nsnsns magnets instead of nnnnnn.
                        I plan on making a 24 magnet rotor that is both inside and outside of the rotor shell by drilling holes and using the same 24 for both low drag coil and the Bedini circuit opposite each other in application.
                        Since the inner ring magnet is an 8 configuration, I reasoned that 8x3 24, it should work.
                        Guys and dolls? Your thoughts?
                        • #27
                          Is this the correct diagram we spoke about?
                          • #28
                            One of them. The circuit feeds the one transistor Bedini layout like the TeslaGenX circuit board. The input and output have capacitor reinforcement to keep the circuit balance, it keeps the transistor from blowing just like the neon, but it allows extra time in case the charge battery accidentally gets unhooked.
                            The primary has five parallel caps to store the input voltages from various places.
                            I will draw more when I physically feel better. My age is about yours BroMikey,
                            Just be patient, thanks.
                            • #29
                              Okay, yes Sir, got to show respect to the elders and that other guy?
                              Using your thread, I don't know who he is (sending me a private message)
                              Who the hell is Dogg2shoes?
                              Either way I got to see your git up when you run it.
                              • #30
                                A photo of one of the coils, each phase has two wires of equal size.
                                Then like in the photo, the pair are used in ssg format.
                                The other two phases are left alone and ac is rectified across some tiny zener diodes.
                                Before the ac to dc transformation the ac is passed through a microwave capacitor for stronger emf.
                                Now the question of 24 magnets, 12 n and 12 s; the opposite side of the configuration on the outside would go across the low drag generator coil.
                                I will drill holes for this.
