The voltage on the generator coil is not what it can flow constantly and may be misunderstood. I like to think of it as the potential building up. It is also tied back into the negative leg of the circuit which increases it somewhat. I will do some load tests on the generator side of things when I get around to it. It does have the potential to charge on the back end or pop forward to the primary I believe when done correctly.
As far as a wider diameter rotor goes I cant speak from experience. Maybe I will have to build one of those too.
