Hi Bhargav,
How long were each of the 24 gauge wires you used? Ohms of each?
Were they the same 100 turns?
The MJL’s should be enough. Have you scoped out the coil as you change resistances?
If not, or for anyone else: Try placing a dual pot on the base / emitter of the 93 and 94 put a base resistor on each of at least 220 (so you don’t hit 0 and burn the transistors) this will allow you to change the value of each simultaneously – so when you scope it out you can see the relationship between changing the bases vs changing the mpsa06/93 resistance vs trigger resistance. All three of these need to be adjusted when tuning. Make sure you have high watt pots and resistors if you want the most amount of juice possible. You can also parallel resistors and pots to increase watt value.
I finally purchased more ceramics for our B-kit, but we’ve been very busy on other projects – only so much free time in a day.
did you catch our double short vid for recovery off a pickup coil on the B Kit.
Thanks for sharing,
Patrick
Thanks for sharing,
Patrick
