MUST SEE ! John Bedini with showing the crystals on the plates
  • MUST SEE ! John Bedini with showing the crystals on the plates
    This is what I have been looking for.....
    BatteryForming_2008_04_25_16_16_47.wmv
    A clear understanding of what is happening in the batteries..
    See my experiments here...
    good movie ,you bring it once again big guy ,thank you for the link .
    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
    Nikola Tesla
    http://www.imhotepslab.com
      Great vid.
      So was the charger he was using for the bottle lead alkaline cell a normal charger or one of JB's radiant ones? Because he mentioned that the battery was outputting more each time it was charged.
      You can view my vids here
      http://www.youtube.com/SJohnM81
        RE watching
        Originally posted by dambit View Post
        Great vid.
        Ehh you missed it... what he did was swap out the electrolyte to alum ( the stuff you use to can pickles ) which as I have found out there are several formulations of.... Anyhow he swapped out the sulfuric acid to alum and was demonstrating that it could hold a charge and give energy.
        Some observations about this...
        There is a chemical change in the battery with the type of charge used, note the DC charge verses the radiant charge.
        I am trying to understand when he says he charges for 1 minute then can get 3 minutes out what is he trying to demonstrate..... I am going to watch again to see how much energy he is putting in verses the draw of the light bulb to try to understand....
        There is alot to chew on in the video well worth taking notes on.
        Mart
          Is alum the same thing they use in sand filters for pools?
            alum
            A nice trick with alum is to get your friend to put some in their mouth. I tried that as a kid...makes your mouth pucker.
            RPX & MWO http://vril.io
              RE: Alum
              I have found ALUM it is ground up partly Aluminum from what I have read. I would not be putting this in my mouth as there have been studies of this causing Alzheimer's... ( metal toxicity )
              The recipies that I have read of this used in pickles have you wash this off after you process the pickles...
              Alum - Wikipedia, the free encyclopedia
              I had a VERY hard time finding it in the store, until I found out it is considered a "Spice" I found it at Walmart and Krogers very expensive. I did order some from a photo place and tried it, my mistake was not to clean out the battery enough with baking soda before I used the Alum. It does work, it is just with my experience I got greater voltage with the surfuric acid. I may not of done it quite right.... But we have a forum here of the adventures with Alum "Making batteries safer"
                alum use
                Alum is starting to be used for pickling and other stuff less and less in the US.
                I was going to say something else about it but I forgot what it was!
                  New info on Alum..
                  I am part of a group that converts batteries. The link below is the best price I have seen and.... Below is results the guy had with this source...
                  Canning & Pickling - AmericanSpice.com
                  "i am very happy to report that my 6 volt deep cycle that is about 12
                  years old and has been sitting on my celler floor for 2 years is
                  working like new with the mix of alum 1oz to 10 oz of water after many
                  flushes of baking soda and water for a week till it was clean charged
                  for 24 hours and took 20 hours to drain with a 24 volt motor let it sit
                  for an hour and tested it and it still had powert so it went back on
                  the charger for 24 hours amazing it works better than new now i need 7
                  more 6 volt batts to do them up and put them in my electric car"
                    I guess to go along the battery conversion and alum a mandatory link is: Sepp Hasslberger: How to convert a Lead Acid Battery into an Alkaline Battery
                    I'm sure it has been posted elsewhere but might as well have it here, since it relates to the subject matter.
                      I found the information that you need real lead plates and no paste to get the maximum efficiency out of the battery very helpful.
                        RE: light test..
                        Battery dead then charged with power supply....
                        3.1 V 2.7 Amps 8.37 W 1 min.
                        3 V light load..
                        Well I watched it again... if I am reading right I am not very impressed with the " 1 minute in, 1 minute out " as he was putting in over 8.37W of power into the cell for 1 min. The light bulb was a 3V flashlight bulb thus was only pulling much less than 8.37 W of power so was not an exact match of load verses what he was pulling out if I am looking at this right.....
                        Still, I really liked to see what my target is, that conditioned battery is what i am aiming for.... in the conditioning of my batteries.
                          Anybody ever rebuild batteries? Anybody ever heard of that?
                          A few years ago there was this guy and he worked for the local FS or something. He would rebuild batteries. I know of people who bought them and said they worked fine. He would sell them to farmers, landscapers, snow plow guys and pretty much anybody who was seasonal. He would always take the core.
                          • #14
                            I found it very interesting the difference in the crystals between the normal and radiant charge. I guess the smaller crystals allow a greater number of them to form on the plate therefore providing an even greater surface area. Maybe that is the reason radiant charged batteries have greater output once they are conditioned.
                            P.S for those that are loking for lead sheet, just nick it from building sites. They always have leftovers from the flashing on the roof and windows.
                            • #15
                              Alum battery
                              Mart
                              Hey great I have been wtanting to make up some alum batteries and chrage them up with a SSG to see what happen.s have you done that already?
                              I was thinking it might be better to condition the battery first to get rid of all sulfate buildup and then to the alum replacement. Are you willing to slhare your formulas. the only one I know is 4 Ozs of alum to a gallon or somethnig like that.
