The properly running SG
Why do you think John designed it a certain way? do us all a favor and build a bike wheel, with a 2n3055 or a mjl 21194 and a 1n4001 and 1n4007 diode, with 100 ohms plus a 1k pot for the trigger. and the neon, its on every one of Johns SG circuits, no its not enough just to get your wheel spinning, we are not using current to charge the battery, its something else.
it is the magnets all north out thats why its a monopole if you go north south you only get half the switching, its NOT a generator.
it IS the strength of the magnets they are what switch the core which turns off and on the transistor.
the SG built properly produces 200 to 300 volt pulses the neon triggers at 90 volts, if your not blowing transistors without a neon in the circuit you have a lousy circuit, your coil is not switching rapidly producing the transient. you should easily be over 200 volts with a standard Bedini SG. that is why its a lousy charger, but a good proof of concept.
you want to use imhotep build it exactly as he has...... otherwise build it like the inventor says you will be much happier, as opposed to doing this
![Wall Smiley](http://www.energeticforum.com/core/images/smilies/wall.gif)
![Thinking Smiley](http://www.energeticforum.com/core/images/smilies/thinking.gif)
![Mad](http://www.energeticforum.com/core/images/smilies/mad.png)
![Cheers Smiley](http://www.energeticforum.com/core/images/smilies/cheers.gif)
