Bedini SG
  • sudhirpaul
    my first ssg in 3 day and tuned!
    That sounds about right to me.
    one thing you can do, once you find the sweet spot (and salmon is right it will change depending on the batteries) as long as you are using the same batteries though, once you find the sweet spot, stop the wheel measure the pot find the resistor/s that match/es (as I'm sure you already did). have this resistance "on hand" so once you get the rotor up to speed, you can flip a switch or move a wire to go from the pot to the resistor/s. "viola" you don't have to waste your time tunning every single startup.
    I'm sure you thought of this or are already doing it prior to my typing, so this is just for anyone else who comes along as well
    Patrick
    hi to all
    great forum here. spent 5 days reading before starting, so i was aware of the problems people were facing. one thing i learnt was follow instructions, get the first one working. then experiment. built my first ssg 3 days ago, carefully, spun it, and it did not work. i know electronics and so i knew the transistor was soldered correctly diode was correct coil resistance was 5.6 and 10 ohms, so knew it was correct, not short, i knew the pulse was not there to switch on the transistor, but i did not know why? so i left it as it was and did not sleep for 24 hrs , i had to get it right, something as simple as this had to work, well after some time of trying to sleep(which did not happen) sat in front of ssg and checked the magnets, guess what?they had lost all power!! nothing,! could not attract even a pin. that is when i realized should have followed instructions to the T. i was using alnico bar magnets, please everybody do not use those. i had some neo magnets that i had removed from old hard disk, i broke it into small pieces, 3mm sort of , stuck it on the hard disk platter and gave it a spin , and voila it started,
    watched it spin for some time and decided to charge the first battery. the voltage would not rise at all, i had done the adjustment using the preset, connected 1ohm resistor, voltage across it was less then 1 volt and it was not heating so i thought it was correct, why was the voltage not rising in the battery? even after 2 days. very slight maybe 1 volt or less , so what was wrong now, read this and previous post, tried cleaning the bearing, changed transistors, tried a different pickup coil , varied the triggering angle, the speed would pick up, but there was no output. volts. maybe the small magnets were not being repelled hard enough, so i took the neo magnet from another hard disk, really powerful, and stuck it on the core, which was the I section of a burnt out transformer, and the disk picked up speed, now is the interesting part, I connected the charging battery and watched the multimeter, the voltage was increasing slowly but steadily. i also observed that there was a slight hum coming from the circuit. and every time the resonance would phase there was an increase in voltage, the battery picked up 1 volt within an hour.
    so now i understand what tuning meant. you have to listen carefully and adjust the pot until you can hear a steady hum shifting very very slowly. i also noticed that when the voltage increased the resonance would change and the circuit would automatically try to realign itself. and when it did there would be another increase, i think the circuit was trying to match the impedance of the battery, and it did it brilliantly. no electronic circuit can come even close to ssg. electronic circuits are just desulfators. compared to ssg. i will observe and post further results. what i want to tell here is, listen to it to tune it, everything else will follow.
    another .5 volt increase by the time i wrote this . (the battery is 12 volt 7ah has not been used for more the 2 years , initial voltage was around 5 volts, got it up using a conventional charger then connected it to ssg)
    if this is in the wrong section please do the needful
    bye
  • minoly
    Originally posted by penno64 View Post
    Hey Patrick,
    I have not been able to get onto the group, but what is this magic
    paramagnetic material ?
    Regards, Penno
    Hi Penno,
    I don't think I'd use the word "magic"
    Here is what the guy who sent it to me said about it:
    "I am glad that I can help you out with your experiments.
    Basically, There is not much else to say about the minerals. I am trying to find the chemical analysis, but it has been quite some time since I had it done and I seem to have misplaced it. I will keep looking and send to you if I find it.
    The material is tailings from gold, platinum and molybdenem mines in Canada. It contains pretty much all of the Transition Metals and Lanthanoids on the Periodic Table. My purpose was to find a source of fertilizer trace minerals for plant growth - primarily molybdenum, but also for the paramagnetic minerals which I pulse at the Schuman Frequency.
    Very few of the minerals are for plant chemistry. Mainly I was looking for the energetic qualities. I screened materials all over North America with a Callahan Paramagnetic Meter to find the best source which measures above 30,000 cgs -- the sample you have. Enjoy!"
    "I wanted to let you know that I checked my other bucket of minerals today and found out that it is not the 30,000 cgs mineral, but a lesser grade of 4,000 cgs which is a very excellent plant fertilizer, but will not give you as "clean" a spike. In fact, the 30,000 cgs is too sharp for plant growth and I have to dilute with other minerals. With plants, I want a slower, more gradual ramp up and down. I am looking to produce a square wave, but with rounded shoulders instead of sharp spike. "
    so there you have it.
    Patrick
  • penno64
    We used stick 'n' seal - local hardware store $2
    use extremely little so it does not take up space and become an air coil :-)
    results are very interesting, it makes the rotor spin faster, you can use bigger magnets, but the cost (amps-in) is the same. I would have thought "removing lenz" would cost less in amps. In a side by side comparison - literally using the same coil and interchanging the core - same ckt resistances etc... the amps-in remain the same
    Patrick
    Hey Patrick,
    Regards, Penno
  • minoly
    Originally posted by Neight View Post
    I happen to have some powdered molybdenum and powdered magnesium (both on the list of paramagnetic materials). I just found my magnesium yesterday, so I haven't tried it, but here are the results I had with the molybdenum...
    IT DOESN'T MIX WITH SUPERGLUE.....
    I really need to go get some epoxy to mix this stuff in, it wouldn't mix with the glue for anything (great news for people who use moly in their motor oils ) forcing some moly down into some glue and doing what I could, it really doesn't produce any drag, though my first test was a real mess.
    I am going to get some decent epoxy and make a 50/50 mix of moly and magnesium, and try to inject that into a core with a bolus syringe.
    I also have a salt shaker full of iron filings, and I am going to try one mix with some of that in as well. not much, not even one full part, just enough to mix into the rest, see if it helps with core saturation and energy production while still having absolutely minimal drag.
    the coil I am going to try this in will be one of slider's multi-strand coils. I took apart a CRT monitor last night and will be getting the litz out of it and winding up a coil and using a paramagnetic core in it, see if I can't make anything fun happen that way!
    I will post any results i get. might take me a day or two to get it all done, but that is what I will be working on
    N8
    Patrick
  • Neight
    Originally posted by ZeropointEnergy View Post
    Hey Patrick,
    I checked it out and posted a message, is a great anomoly and needs further investigation.
    Looking forward to see where this goes and the potential applications and to our knowledge of magnetism.
    Zero
    N8
  • ZeropointEnergy
    Great work
    playing around with a paramagnetic core:
    http://www.youtube.com/my_videos?feature=mhee
    almost lenzless... the possibilities are endless... well not really endless
    Patrick
    Hey Patrick,
    Zero
  • ZeropointEnergy
    Impedance matching and reasonance
    Hey zero
    glad to hear you are moving along on your battery runs! takes time, but its worth tracking, I have learned a lot while cycling my batteries around.
    I am still working on learning this coil shorting, and have really had a blast messing with it all.
    Look forward to seeing what you come up with
    N8
    Hey N8,
    I was playing around with the "cap-pulser circuit" vs "Tesla Impulse Tech" and the result appear impulses is highly efficient way of obtaining negative/radiant energy.
    With a large cap 25V/30000uF set to dump to circuit at 22.6V and provided modest results only bringing the 12V/7aH battery from 12.22V-12.42V.
    In the same time period (2hrs) with impulses the battery reached 12.9V.
    This was a battery never exposed to RE and thus didnt expect great results with either way, I know to try HV/low uF for sulfated batteries, but this way just a test to gauge results.
    Finally, I have been testing various FWBR's ranging from 400V/1.5A to 1kV/50A, the 800V/35A provided the lowest voltage drop and more importantly generates the greatest AC voltage from the inductor.
    I still have to try my 1N5408 and germainium FWBR's I made, will test soon.
    Hope that helps if you did'nt try that many FWBR's
    If anyone has any input on different experiments using impulses and the potential for charging batteries/caps of multiple nodes in series off the power coil on the SSG, I'm open to ideas.
    Zero
  • ZeropointEnergy
    Tesla Impulse Technology Single FWBR
    Hey zero
    N8
    Hey N8,
    I took a few pics later and here it is running at 200mA+ draw and
    3200-3255 on digital tacho, on iphone sorry about quality and others
    will email you clearer.
    Zero
  • ZeropointEnergy
    Hey zero
    N8
    Hey N8,
    I have something for you to try, just need a capacitor, FWBR x 2
    and some hookup leads. (can use 1N4007 x4 or other made FWBR)
    I'm investigating this before go further , there is a relationship
    between the reasonate frequency of the circuit vs the load of
    the capacitor/battery in series with the coil and the FWBR.
    This is the basic set up with 2x FWBR's and a extra voltage node collector.
    If you want the basics, add a lead from top of power coil to your FWBR
    AC terminal, lead to bottom of power coil to other AC terminal, hook the DC
    output to battery.
    This will bypass the 1N4007 diode and output leads on my circuit, so easy
    to test, no need to unsolder/solder .
    Zero
  • minoly
    Originally posted by BillW View Post
    I'm trying to get my 10-coil kit running. The trigger signal, as 'scoped across the trigger coil is approx. 1v p-p. It appears almost sinusoidal. It does not seem to be strong enough to fire the transistors.
    Pri Bat = 12 v , 2nd Bat = 24 v Any thoughts about where to look? I had some difficulty sifting through which coil wire went where. If I made the wrong choice, could this be the problem?
    I could mount a timing disk with appropriate drive circuity and thereby control trigger amplitude, onset time, and pulse width. Would that be wise?
    Thanks!
    BillW
    2cents - start with one coil and only a few 3 strands. get that working, very basic. then move to all 8 strands, then add one coil at a time. Base resistance will send you guessing if you start with all coils at the same time never having experience w/ how it wants to act.
    Also, apply to Bedini monopole 4 at yahoo groups. you're an automatic in w/ the 10 coiler...
    Patrick
  • BillW
    10-coil trigger
    Thanks!
    BillW
  • minoly
    Paramagnetic Core
    Patrick
  • Neight
    Hey zero
    N8
  • ZeropointEnergy
    Posts
    Hey zero
    as far as I know, if you can hear the coil on an SSG and your rotor stops spinning, then it is running solid state. from what I have learned, this works, though not as efficient as a device that is made to be solid state.
    I never really did any testing when my coils were singing to me, though I should have....
    replicating that would be easy enough though, just use a bigger pot.
    5k pot will easily make a solid state out of an SSG. Might wire one up and try it, just to see how good it really does work, now that you mention it
    the noise I would get wasn't loud enough to make me uncomfortable, but it would get annoying after a while.
    and unless your coils or components start getting really hot, I don't think you have much to worry about, though it can be unsettling when things are making loud noises and they are not supposed to :surprise:
    and I really just post wherever people are talking, there were questions here, so I came to try and help answer them. if there are more posts in the thread I started, I will follow those just the same
    Hey N8,
    I'm trying lots of new things on paper and test circuits for the SSG now but have 2 runs to finish 20 so not going to mod it yet. When completed for group I will add extra coil, Tesla impulse series circuit, cap pulser and the list goes on.
    Will have my new Yahoo spec SSG running tonight or tomorrow if I put the few hrs into it and epoxy on the 18 magnets. (is 26 inch rim, so every 2nd spoke)
    I'll keep track of the few posts we are checking out
    Zero
  • Neight
    "the more resistance I use with my pot the faster my rotor goes until the resistance gets high enough to cause the coil to self oscillate which makes the rotor slow back down in a hurry".
    Hey N8,
    I was just wondering if you have obtained self-oscillations in the SSG causing a solid state function?.
    I have saturated my coil (not sure how, have 2mm welding rods, unless is the magnetic air gap distance, last variable to tick off.) during last test and the SSG started to generate a high pitch squeel then rotor slowed down.
    Then began to charge solid-state drawing 200mA (no meter on output)
    and seemed efficient. However, makes more noise than the fast pulsing 2400-2500RPM on SSG.(removed all noise, except the trigger pulses)
    The sound was so loud I hit my STDP switch just to ensure wasnt about to explode a component and if I was to create a solid-state model I would have to add sound proof case to tollerate being in the same room as it.
    Are you still adding to your "first SSG" post or just here now bro?
    Zero
    Hey zero
