Bedini SG
  • Farmhand
    Quote:
    Originally Posted by FRC
    Redeagle, sorry for coming in between here. Could you tell me what the difference is between the MJL21194 and the MJL21193 are.
    FRC
    '94 are NPN, '93 are PNP. If you put the pnp's in an ssg you would have likely fried your transistor first pulse !!
    faramog is right you need NPN transistors for a SSG. The 2N3055 is fine it will work good also TIP31c or TIP41c or even MJE3055 but they are only rated to 60volts so are easy to burn up. The others are tougher. Usally Most transisters have an opposite PNP complimentary transistor for pidgeon pairing.
    I don't like 2N3055 transistors because it's hard to solder to the collector, I prefer the one's with three leads.
    You can look up the datasheets on the different transisters and other componants diodes and such, in the link below by searching, clicking on the PDF icon to the lower right and then enlargen that. Just save the datasheets you want to refer back to. I've seached TIP41c for you.
    TIP41C datasheet, TIP41C datasheets, TIP41C datenblatt, TIP41C manual, TIP41C data sheets, TIP41C pdf - ALLDATASHEET.COM
    The datasheets can tell you all sorts of stuff from Current gain to trigger current, very usefull, you may not understand it all at first but it will come to you.
  • faramog
    FRC
  • FRC
    Redeagle, sorry for coming in between here. Could you tell me what the difference is between the MJL21194 and the MJL21193 are. The latter are the ones that i think I fried. I could not buy new ones locally so got two 2N3055
    to use for the basic SSG instead.
    FRC
  • redeagle
    @Rubberband I would suggest to either go with the simple monopole partial kit or the small 3 pole monopole kit. With the basic ssg kit you get a circuit board so that you can see how all of the parts fit together. but you have to design your own wheel and mount. I just received my three pole kit yesterday. i'm having a blast with it. it comes with everything but the batteries. both kits require the use of a soldering iron
    You can find a lot of basic build pictures on the monopole 3 group on yahoo after seeing what the difference in performance is from the modified pc fan from radio shack and the 3 pole kit. I probably won't my doing much more with my fan. If i had a larger fan motor i might would consider it.
    But if you feel that you have grasped the information well enough and would like something with more output, you might want to consider a multifilar coil. Keep in mind that John Bedini even recommends that one master the single coil monopole not only to understand the effect that the machine is producing, but what effect that it has on the batteries that you are charging. The key clue is that you are not charing the battery with the energy induced by the spinning of the magnets.
    As far as parts go I would recommend the MJL21194 for the monopole whether you are using the standard circuit or one that has been modified to switch with a hall sensor. You can push it pretty hard as long as you take care of it.
  • FRC
    Charging motor
    I probably can not help you. Could you be more specific about what you mean by an SG charging motor ? I thought all ssg were charging motors. As for Truth
    in Heart, I just finished frying the two transistors on my 5 inch fan kit. So am
    going to try the more basic Imhotep setup next. I also have the advanced SSG
    kit with solid state, but am not going to attempt that one yet. I also want to make the basic SSG bicycle wheel first. I have separate parts for those. What I
    would like to know is what is the SSG bipolar circuit option that potentialtec has. Can anyone answer these questions ?
  • Rubberband
    Hello Redeagle and all, I have built a Bedini SSG motor on a small scale with a small wheel and parts from Radio Shack, as well as a Bedini / Imohtep fan charger. Some other few small projects, now I am wanting to build a SG charging motor and have kind of figured what parts I will be ordering from Truth In Heart's website. What I would like if you guys will, is post me a list of the parts you guys know or feel would be best to order. I would like to place my order this next week, I do have a limited budget but still want to build with the best for it. Any help would be great and I will be doing the testings required to advance in these groups, Thanks,.. Wally
  • redeagle
    you could keep charging it in reverse. it would make a great conversation piece. On the bright side you are essentially reformatting the battery. If it survives it will help a long way towards conditioning it for this type of charge.
  • Farmhand
    This will be an expensive light show. You will damage the transistor!
    Yes most likely will. It's ok though I have spare's now, it's just a pain to replace them. All the time, i'm forgetfull, and make funny errors, I reverse charged a big battery by accident the other day, it was a junker After it was charging for five minutes on a solid state energiser when I check the voltage and wonder why it says negative 6 volts. Still not sure I can fix it.
    Cheers.
  • ren
    Redeagle,
    You can heatsink the MJL, but an MJ15024(G) works better. Otherwise make a "Sziklai" pair with an MJL21193 & MJL21194.
    John K.
    Lol, had to google that one John.
    My mate has been using a rather large IGBT to discharge the cap. Its seems to be working rather well for him. By large I mean in the kilovolt range and 100 of amps. His caps are discharging @ over 250v (not into a battery) and total capacitance has exceeded 1000uF at times.
    Ive found the MJ15024 to work well, or paralleled MJLs. John is right about the heat sink too, wack one in there for good measure.
    Have to catch up again soon John on skype. Love to hear what you've been up too. The aussie "meet" while the Convention is on sounds like a good idea (you mentioned it in another thread).
  • John_K
    Originally posted by redeagle View Post
    I am running a simple home made cap pulser with my bedini sg kit running in self oscillation. It is a MJL 21194 identical to the one that is running the monopole oscillator. Triggered by an optocoupler. Here's the interesting thing. The transistor for the cap pulser is running warm to the touch, but the one driving the oscillator is not. I have not yet measured the amperage in/out but it is looking quite promising so far.
    Redeagle,
    John K.
  • John_K
    Yes I do know what you mean I just got some new neons recently and WOW the difference is dramatic the new one's burn so bright it hurts, I can't wait to show someone. I got them cheaper by buying 30, I was taking them from old appliances to use, but I think they were made for 240 v and so they didn't protect some lower rated transistors at all. If there is one thing i will not skimp on in future it is the neons.
    Farmhand,
    John K.
  • redeagle
  • Farmhand
    I was thinking on your three starship idea, i'm not sure but i may have read that something different happens when you turn one's current horazontal plane 90* to vertical, output stops not sure, some one in the JT exciter thread did it with two pancakes and the lights go out from memory. Seems whichever way you would put the loop it's not possible to keep three horazontal. Probably not important. You have some very good video's by the way.
  • blackchisel97
    I've noticed I with four wire's I can use two parallel for power, one for trigger and use the other winding to power led's with unrectified raw radiant/some current if not tuned properly . And still get radiant from the charge output. It's happening in my Mini three pole vid.
    Cheer's
    Umm your input power would probably go up though, I guess.
    I can draw small amount. Also, charge a cap or two and discharge into batt. but cannot pull steady any more without consequences. I wonder, how I could wind this coil to have third winding 180deg from the other two. Would this work the same as winding cw and ccw on spool
    I tried another coil with core inside the starship. Core affects slightly main coil but I measured 13.5V. When I try to pull from it my input current goes up. I'll try different inductors and different core material. I have something else in mind, maybe was already tried, maybe doesn't make any sense; 3 SC spaced 120deg and another round (ring) coil running through their cores. SC pulsed with certain freq. (I'm thinking of harmonics but may be something else instead, don't know). I just want to find out what this coil can do other than spin a magnet, act as an antenna and speaker. EMF is very strong but concentrated in the air core part only.
    I'm not sure if further experiments should be posted in this thread. Don't want to hijack SSG into space.
    Update; I placed 2" toroid JT over the top of SC but in vertical position. This doesn't seem to have any effect on circuit. LED is as bright as it can be but this is only 1 LED. Almost forgot to mention - there is no battery in JT.
    I'll try to find some other ferrite and wind a coil which will fit the core.
    Vtech
  • Farmhand
    Well, I tried another Starship coil today. I made quad but only used 3 windings atm. in Litz fashion. I used the same circuit as per my last vid. except that I rectified output from the third, capped with 10 000uF and connected 12V/5W bulb to it. To my amazement input voltage remained the same but input current dropped from 1.45A to 1.36A. There was a slight difference in the waveform with additional ringing in the middle of horizontal part of "h". Spikes dropped from over 50v to about 46V. However, my amazement didn't last long when I discovered that charging became much slower. Oh well, nothing for free today I guess
    Update: I used litzed coil in "normal" bifilar self oscillating configuration. Waveform is nicer than my other coil and spikes are at 55V. Circuit oscillates at 10kHz and is charging well.
    Cheer's
