Bedini SG
  • blackchisel97
    Hi everyone,
    Short update since yesterday. I made a simple adjustable switch -two bronze alloy spring contacts and 1/8" piece of copper, glued to the CD rotating with rotor. I'm getting nice small sparks on the contacts and discharging both caps once per revolution over another battery. Voltage is rising quick. This is 20Ah batt. and it went from 12.50 - 12.71V within 45min. Meanwhile main SCR cap pulser is pumping large battery. Extra load has no effect on the input side nor rotor speed. Nice
    Vtech
  • blackchisel97
    Hi folks.
    Charger is running steady since it has been built. Today I decided to use one of my spare windings (coil has six but I paralleled two thinner ones for trigger). I made two bridges/4700uF caps combos and connected to my spare windings. I can charge another two batteries (or one if I parallel bridges outputs). I also connected large 7" PC fan. Voltage measured over fan is 8.5V and current running through 0.078A = 0.66W. The best thing is that connecting load such as mentioned above has no effect on charger. Input current remains the same - 0.5A. I'm thinking of pulsing both caps to the input. I have 4400uF caps parallel with input. If I'll separate them from primary battery with a diode, so current can only flow one way, and pulse my output caps over the input caps?
    Vtech
  • blackchisel97
    Radiant Charger
    Hi folks,
    I just got my Radiant Charger with 555 and SCR cap pulser running. Despite a lousy rotor and only 12V this is working like a charm! I connected small LAB from my GoldWing. She was sitting @ 12.62 and went up to 13.80 within 45min.
    I'm trying different capacitors and dumping frequencies. Will post updates.
    Vtech
  • wwdotme
    Originally posted by nvisser View Post
    I found the thread where i got that misterious diagram from on the panacea bedini pdf
    It comes from the overunity forum:Fusionchip's Bedini Feedback to Source!!!
    This guy claims a self runner and batteries that overcharge
    The 1uf cap in the trigger winding turns it into a solid state ssg
    Interesting effect on the piggyback coil idea.
    I got 30V a/c off a solenoid coil I had.
    Can't wait to spend a little more time with his idea.
    sure changd teh freq. alot sliding the welding rods in the air core of my
    solid state coil while running.
    Oh well off to work
    ww
  • blackchisel97
    Mho
    I hope Peter won't mind me re posting this - I worked for Energenx when all of the larger rotating machines were built. All of the big machines, the 12 coil machine with the barrel rotor, the 10 coil machine with the large black rotor, the 6 coil machine with the silver rotor, were 24 volt systems! You will never duplicate what these machines do with a 12 volt system.
    These machines can be seen on this page.
    20 Bedini
    Look at the batteries. The picture of the large round batteries on the floor. They are 1600 amp-hour 2 volt cells, 12 of them wired in series. Look at the copper buss-bars connecting the batteries in series. The systems were connected to the control box with 00 (two aught) wire. This is a super LOW IMPEDANCE system. Total resistance of the whole battery bank was .002 Ohms! Due to these conditions, the Radiant Energy behaves differently.
    Every one of these machines was slightly different. Every machine was designed to TEST something specific. The variations being tested were the CONFIDENTIAL property of Energenx and its stockholders. A lot of information has been published, but a lot has not. That's business. Like I said, millions of dollars of investor's money has been spent developing these systems:
    Energenx, Inc.
    I am painfully aware of the how ill-prepared most people are to understand what John says or what Tom Bearden says, or what I say. There is not much we can do about that. The fact is, Energenx is a Public Stock company. Information was only published about systems that have no commercial value. The method of operation of the products on the products page above is TOTALLY DIFFERENT than anything you know about. It doesn't mean what has been published is worthless. It means John LEARNED something from these stepping stones and the designs progressed.
    Please don't be upset about all of this. It's business. What you have learned about this is SOLELY due to the fact that John is a generous humanitarian who honestly cares about the world. He was under no obligation to tell anyone anything about what was learned at the expense of his investors!
    Keep experimenting with your models. John gave you the place to start. But now you have to learn how to learn. Let the machine tell you it's secrets. They're right in front of you.
    Best wishes,
    Peter
    I'm painfully aware of that as well. I'm trying to learn this as I build. I don't have a way to make or order decent rotor or purchase few thousands feet of wire to make proper coils. So far all my projects work, including latest Solid State. My simple SSG oscillated between 0.85 - 1.2 C.O.P while battery became conditioned, and SSG is just a learning toy. We have been given hints, not a blueprints for commercial systems and I understand reasons, as explained by Peter. I have no reasons to mistrust John or those who work and built those systems with him.
    One more thing, an example from a different field - antique furniture conservation and restoration.There is a process of re applying finish -shellac based, called "french polishing - polissage au tampon". Anyone can Google this process and I can describe every step. Guess what - you'll fail first, second and even 10th time despite having precise description. Would you call me a fool and blame for your failure? I have had people arguing with me while holding a freshly purchased book, written by an expert and telling me that I'm wrong. But I was the one who did the job and they kept spraying nitrocellulose lacquer. BTW, I hold a master in this field since mid 80' and still have photos of my work. I know very well what the frustration is and had experienced many failures but I have a patience of a boulder and my first question is always - what I have done wrong and what is that I don't know?
    Vtech
  • baroutologos
    @ Baratoulogos - your opinions would carry more weight in this forum if you were to contribute experimentally, subject to scientific process and peer review.
    Love and light
    Sure dude. As soon as i am completed some replication i will post it here.
    @ Seph,
    Appreciated or no, i will continue posting my points. By Inquorate is right. I am gonna speak with replications on hand.
    Baroutologos
  • Inquorate
    Conditioning caps
    For those who haven't read this yet,
    http://www.energeticforum.com/renewa...rch-group.html
    You may find it useful. Ends up the experiments have led to investigating the conditioning aspect; the spontaneous part didn't work out...
    Love and light
  • Sephiroth
    Baroutologos... I have to say I am doing my best to stay calm when dealing with your posts since I have the utmost respect for the values of this forum.
    Bedini only recommended around 450 turns around 10 years ago... it was soon revised after that to many more windings.
    There is nothing in that photo that suggests it is a high resistance coil. The photo is rather grainy so the number of wires on each spool is unknown, and so is the wire guage. Also, what makes you think that this particular model out performs every other model bedini has made that uses (quite obviously) very low impedance coils. The most advanced motor that we know about has a total resistance in the milliohms.
    In the end it isn't a question of resitance since the inductance also has to be taken into account. It is the coil's overall Q that is important. So yes, you can use a high resistance coil as long as it also has a high inductance compared to that resistance.
    Bottom line the point is that no-one of us has achieved any results as claimed by Bedini and confirmed by various witnesses.
    Yes they have. You just refuse to listen to them. Repeatedly.
    The forum is well aware of your views of Bedini tech. You have made your point so please leave others to carry on. Your posts in the Bedini threads are not appreciated (at least by myself though I am sure others feel the same). You can not publically slate the technology, stating it doesn't work and that Bedini is a lier and all dedicated experimenters of the technology are fools, then think you are entitled to post how you believe the technology works (even though it doesn't).
    I understand you now believe the SEC is the way to go... if so great. Please concentrate on that a be constructive rather than disruptive. We all have the same goal and we are all following our own path to that goal. Please follow yours and leave others to follow theirs.
    Seph
  • baroutologos
    @Sephiroth
    One thing that frustrates me a lot regarding Bedini technolgy, if there is any such term, is that there is a LOT contradicting claims in it. The point is that i see what i see, and the coil i see is not a few windings one.
    If we are to accept this kind of technology bears any good as Dr Lindemann confirms, then we should base our coprehending upon our own experiementing and info presented deciphering.
    Bottom line the point is that no-one of us has achieved any results as claimed by Bedini and confirmed by various witnesses. So two things: The technology is a hoax and the witnesses unreliable or the way we try to make it work is wrong.
    you decide.
    Baroutologos
  • Sephiroth
    He also said that it is a 12 watt motor so each coil will be drawing 500ma... do those sound like high impedance coils?
  • baroutologos
    This is from Bedini's site.
    Does the coils of the cap pulser looks like 450 turns of 23 awg? No to me. More like 4500 turns.
    One other thing i pondered on the suggested high impedance..I mention Member Aaron's experience on cap pulser. Best results he said (underunity of course) came from a 2000 turns third winding capturing the pulse to large caps.
    Again, Bedini's fusionchip that claimed OU has to do with a recovery coil of 5000 turns and cap pulsing.
    When designing a Bedini circuit is of course counter intuitive to have a high impedance coil. By the way some evidence suggest this.
    Baroutologos
  • blackchisel97
    Radiant Charger
    @baroutologos - I never tried h. impedance coils except my pendulum (1400T #26 & #28.
    I spent all evening on Radiant Charger, similar to Solid State which I have finally under control. There are schematics variations calling for different discharging cap. I found 4uF 400VDC working best with Solid State, unfortunately I don't have another one. This circuit is very picky. With 80uF photo cap SCR stays on all the time. I found one schem. telling to use banks of photocaps from 100uF - 10 000uF or more. Circuit from FEG has 10uF in it Tuning cap pulser timer affects oscillating part. I had spare coil with 6 windings twisted #24 360T. I'm using only three windings right now. I put 20uF AC cap but I tried this before with Solid State and it didn't work well. I'll keep tweaking tomorrow, getting dizzy from watching rotor, scope and DMM's simultanously
    Vtech
  • baroutologos
    Something most uncommon with the circuits till today used.
    Every SSG noob, starts with the classic 850 turns 22-24 awg coil and an welding rod core.
    Results are not as expected and proceeds with more advanced setups as litzed wires, thicker wires, multi-trasnistors schemes per winding, multiple fast diodes, etc. Solid state is the final approach.
    I have been introduced by a member this page Catching_Radiant_Energy - Hyiq.org of a fellow Bedini enthousiast. He entrusts to us that although he started out normally the best results he is getting (in terms of COP and claims cop over 1) are with high impedance coils.
    The coil he suggests is a 0,45 gauge?? (means mm?) at 65ohms. This coil draws only 65ma at 10-12 volts.
    ANy oppinion/experience with high impedance coils anyone? Say 1 H.
    Baroutologos
  • nvisser
    fusionchip self runner
  • cody
    If the capacitor does the magic... could one put a cap at the front?
    If one charges a battery with negative charge, how do you get rid of the negative charge?
    So many questions I have.
    I not sure of all the reasons to put a cap at the front but i do know one purpose. You cant put the collapsing spike of the bedini directly back into the run battery but you can put it in the cap at the front. But to do this you need a diode between the battery and cap so current can only flow from battery to cap. Also you need an isolated coil winding: thats 1 trigger coil, 1 power coil, and 1 collapsing spike coil. Hook the collapsing spike coil up to the cap at the front with the usual recovery diode (1n5408 etc) and there you have it. It does not charge the run battery, but it allows you to draw less current from the run battery because the cap will be charged to a higher level than the battery.
    morpher44,
    I really like your idea on studying the coils with the formula and plotting it out. It would be nice to see someone do this so we would have an example to follow.
