Parallel Ground Test Results
Hello Everyone,
Last week I ran a test with the SSG's charging battery ground connected to the power ground and noticed an improved charging effect. I ran some additional tests on the 7Ah battery and ~12.1v power supply and the results were encouraging.
Tests 1-8 were run with no rest period after charging. Tests 9-11
had a one hour rest after charging. Load is discharged through 50 ohm resistor down to 12.4v.
Observations :
So what's happening here?
I would love to hear your thoughts and especially those of you with scopes try this test on your SG machines and see what you get.
Warm regards,
Mike
Hello Everyone,
HTML Code:
--------- Charging ------- ------ Loading -------- Cycle Mins W In Mins Wout COP 1 60 2.93 34 1.84 0.63 2 61 3.03 36 1.94 0.64 3 95 4.67 59 3.18 0.68 4 89 4.34 57 3.08 0.71 5 124 6.1 75 4.06 0.67 6 62 3.05 38 2.05 0.67 7 90 4.43 64 3.45 0.78 8 120 5.86 90 4.85 0.83 9 60 2.95 30 1.59 0.54 10 85 4.29 85 4.52 1.05 11 122 6 84 4.46 0.74 Notes : Average COP 0.72
- Wheel speed was 17% slower and slower to rise
- Tuning the pot was very steady with little current bounce
- Using the LED strobe, there are two pulses per magnet (vs. three normally)
- Pulse on time appears to be delayed somewhat, exactly like the video Lee posted with an inductor in the trigger circuit.
- Output Current increased to 140mA vs. 80mA when connected normally
- Test #10 discharged to 12.38v
Warm regards,
Mike
