Originally posted by selamatg
Other problem can be max volts to base - emitter, is possible that your trigger coil is working very very fine and can send a voltage higher than base - emitter 2n3055 can handle. But don't forget that Diode connected in (D1) Base - Emitter, is like a zener diode of 0.6 volts aprox. You can try limit current Colector with a Resistor between Coil and Colector. If you Back EMF is giving to you Back EMF very high voltage, you can reforce D2 with more diodes in series, remember that common diodes only control 1000 volts max, in series is 1000+1000 etc..
